When I use the NarsilM V1.0 3C1S for Manker U11 quad LED.
Forget to set the temperature control first.
Burned one LED. and then below 350mA can not light.
Small flashlight, poor heat dissipation, perhaps need to limit the current?
ok so i readded the comment to ask for max and then commented out the line that defines it as 255. this generated a table that i think will work. i just needed to change the last 7135 value from 0 to 255. Ill have to test it of course but cant see why it wouldnt work
Looks nice! too bad you have to rip into it. Ya, i would think you would need to set the thermal reg pretty aggressive with that set up. I have a u11 kit ready to go. only problem is i dont have a u11 to put it in.
It should be very difficult to burn up a typical LED when mounted on a copper MCPCB. If they were low Vf LED's like XP-G3 or 219C's, then the risk is higher, but you have other things that can be done easy - use thinner LED wires, don't bypass the spring, use a lower performing cell, etc.
I used thermal grease on the contact points where that pill comes into contact with the housing - think it helps. But quads in a U11? Oh boy, not really made for that kind of heat - that pill design is pretty poor. I got a single XP-L2 NW in mine and love it though - it's my favorite 18650 EDC light.
And under 3 channels, there are two separate tables, depending on what compile switch is set, TRIPLE_3_7135 or TRIPLE_8_7135.
So, you have to have everything set up properly in the "Setups" header file you are using.
I am probably assuming wayy too much knowledge to do all this setup and configurations, but what you are trying to do is pretty advanced customization, and I did build in a lot of provisions for customizing things withkeeping the main source code in tact.
Just finished all the bug fixes and couple features/enhancements for the next release. I need to get more testing in on it, but so far all the changes tested ok.
Of course it's not everything I wanted to get in, but running out of time at this point. Here's a brief list:
ADDED : (from MAD777, maybe others) if strobes are disabled, a 2X click from 2X turbo should restore the previous level you were at
FIXED: 4X clicks in modes operation engages lockout - not supposed to
ADDED: operation change: make click&hold in MODES or STROBES wrap from 1st mode to last
FIXED: in LVP switch LED control: the LED sometimes is left on after an LVP drop, and is not blinking the way it should be. The "bug" is that I'm trying to control the switch LEDs from multiple places so it's getting turned off quickly after turned on, and left on when it should be left off. It's a timing thing, so has sort of a random pattern - sometimes left on, sometimes left off. The 8 sec LVP blink need to be qualified better, and should not be calling Setlevel() as is because it wants to control the LED
FIXED: temp stepdown should not happen right away from turn ON. Delay it by 15 seconds
FIXED: for temperature stepdown, in moon mode, a temp stepdown is actually done because moon mode is marked as special level 255, which is considered as a high level of output instead of very low. The stepdown results in the light switching much brighter. This should only happen id the temperature threshold is set to a low temp, or the light is still hot and not cooled down when moon mode is chosen. It can also result in an immediate jump to the stepdown level as soon as the light is turned on in moon mode. Might appear as a bright flash when ramping first starts.
There's more previously implemented:
ADDED: momentary/tactical mode via 5X clicks - only active til a power reset 2X or 5X clicks exit tactical mode (full turbo only when switch is held down)
full BLF GT buck driver support
capability of setting max ramping to less than full max FET (Hi mode), while the 2X click still goes to full FET turbo. This is being used for the GT buck driver configuration.
added more compile switches, little better custom configuration of the source in header files
Wow, once you drill out the driver screw holes and put decent screws in there, extend the LED wires to 67-70 mm, the Q8 is one of, maybe the easiest light around to upgrade firmware with. I find it easier and quicker than even driver retaining rings.
The 2nd round production Q8's should be easier with the screws, but looks like they shortened the LED wires in some, maybe all, so I haven't tried one of those yet.
That’s a nice list of updates! Do you have it available yet? It would save me trying to finish trying to mod the code for ramping to less than full max. I’m close, but flashing testing, flashing testing to fully figure it out could take me a while yet.
Ahhh, got the source code pushed to my google share drive, but was hoping to get more testing time in. Actually could use whatever help I can get. Hoping Lexel and anyone else. Don't have any official type manual update on it yet though.
It's v1.2 because v1.1 was used in the BLF GT proto. The default code/hex file are set to the Q8, meaning 2 Channel, 1S cells, indicated by "2C1S". This is my new convention for header files.
I've only tested it so far on a couple Q8's, so didn't even try a "3C" configuration yet, but should work.
Again this is early, it might still change, but if you do want to give it a go, let me know how it works out. Again, I tested the LVP and temp regulation issues on the list above, and all seems to be working well. The strobe mode wrap around works well, and also applies to MODES operation.
Ok. Thanks Tom! I’ll let you know how it goes. If I have any trouble I’ll probably just go back to v1. I’m using it in the m3 clone and thinking about it, there won’t be any reflashing once the light is put together so I’ll need to trust whatever firmware I decide to use.
Hhhmmm - might pay to wait til I try out a triple - think your M3 clone is a triple channel, like my M3. I got a couple test lights, easy to dnld to, like the SupFire M2-Z, SupFire L5, etc. Got quite a few lights running Narsil that are not so easy to dnld to, many have the old e-switch or early Narsil versions.
I still left some open issues on the triple channel ramping tables in my notes, but think I resolved those issues by re-gening the tables - not sure now. I know the mode sets for MODES operation are not the same as 2 channel setups.
Ya, I’m using a triple channel. 1+3+FET. I’ll try to pay attention to the possible problems. Actually, I think I’m going to build two drivers. One to test with and one for the final use. The final driver won’t be reflashable unless I solder leads to the MCU pins. Hmm? That would be possible but probably still easier to make two drivers. I’ll be able to use the extra driver in another light soon enough anyway.
