As long as you don’t keep it powered on past the point of where it is unbearable to hold are you usually not going to damage anything (even when modded)? Another way of asking this… Will the parts in the flashlight fail due to heat first or will it become too hot to handle first?
Law Enforcement work. I have the TK16 as my primary light. This will just be used occasionally when I want to search an area for somebody in a field or forest etc.
This is just about as big as I can get. I throw this in a sling on my belt. Anything bigger than this and I will have no place to hold it when I need both hands.
Too hot to hold first. Lights like the Thorfire S70 will step down after 3 or 4 minutes to keep people from burning their hands, but the Convoy L6 was programmed not to step down. You have to use common sense not to burn yourself. And of course it is designed to handle the heat internally. I think it gets up to 80°C, then as the batteries drain the heat goes down.
One thing that might help is a narsil driver. With ramping it has 150 brightness levels so you can choose what you want instead of being limited by high or turbo.
I do security work with mine. It’s so bright, I can sweep an area in like 3 seconds. I use it in short bursts usually no more than 10 seconds at a time. If I need to keep it on longer, I adjust it down a little.
Another thing to consider, it seems like the various bins of the XHP70.2 vary significantly, looks like between 1520 to 2015lm according to the cree data sheet. Where does one buy top bin XHP70.2 already mounted to the MCPCB?
This is the only one that I found already mounted to a MCPCB but I have no idea what bin it is from:
That’s funny I found that same site just before you posted it. I like the color rendering I get from the 5000K XHP70 so I’ll stick to around that. Looks like 4000K would be better than 5700K. Would you agree? Seems like I can pick up stuff faster with the warmer light (at least when comparing to my much whiter Fenix.
I don’t think he’s looking for a thrower. I know I wouldn’t want to hunt for somebody in the woods using an L2 or a C8 light. You want good spill lighting to see all around you plus a decent sized hotspot to better identify things.
The larger head of the L6 with a smooth reflector will give best throw, use a buck driver at 5.5A or 6A to the XP-G2 and de-dome it, should get some 1100 lumens and a tight pencil beam.
It depends. If you’re surrounded by birches for example, a big spot or bright spill will blind you from the reflections. A small spot goes right between the tress.
I use that to my advantage in the house. Lately, I’ve been plagued by either fruitflies or gnats. I got one of those electronical tennis-racquets that zaps ’em, if I see ’em. A nice bright floody beam doesn’t light up the background all that much, but when the critters are close by, they light up like they’re on fire. Zap!
It’s also the same reason foglights are generally poopooed when it’s not foggy. Sure, they’ll light up the road immediately in front of you nice’n’bright, but that brightness almost blinds you to what’s way out there that your regular lowbeams would light up just fine, but is now relatively in the dark.
The L6 has significantly more output than your TK16 (~3500lumens vs ~1000lumens) and significantly more beam intensity (~75Kcd vs ~14Kcd). But because of the way our eyes perceive light, even a factor of 3 or 4 increase in intensity doesn’t seem like an incredible increase in brightness. This is probably the reason for your disappointment in the brightness. The 26650 cells you use could also affect the brightness. If they have too high an internal resistance it will limit the brightness.
It sounds like you want a bit more throw power, so I would recommend for you to dedome your XHP70 and increase the current. I actually would not recommend the XHP70.2. The throw with the XHP70.2 will be worse, for a given current, than the XHP70. It has a lower forward voltage so it is more efficient, and if you use a FET driver it can be very very powerful and bright, but in that case it really uses an excessive amount of current which makes it not practical for your use.
Removing the dome will increase the beam intensity by a significant amount, up to a factor of ~1.8, and narrow the beam some. With most LEDs we remove the dome with the help of a solvent such as gasoline, but with the multi-die LEDs like the XHP70 it is more difficult to use this method, though it has been done successfully. Instead we can remove the dome simply by slicing it off with a razor blade. See here for some info on increasing the throw of the L6. If you go this route note that it is important to slice the dome as close as possible to the LED die surface. If you don’t slice very close the increase in beam intensity will be less.
Changing to the smooth L6 reflector will also help with the throw, but when used with the XHP70 there will be a “donut hole” in the beam. This doesn’t make it unusable by any means, but some people are sensitive to this sort of thing.
To increase the current you could do a resistor mod as described in the link above, or you could get a FET driver like the TA driver. There are FET drivers from mtnelectronics that will work in the L6, for example this one. If you go this route you can get the D4 firmware which has a really intuitive and powerful ramping user interface. Using a FET driver will send more current to the LED in the max mode (although you can choose any brightness you want) and might increase the brightness by an additional factor of ~1.5 or so.
As far as your heat failure questions they are sort of difficult to answer both because what fails first depends on several factors, and most of us turn off the light or lower the output before something actually fails, so there is not a lot of actual data. But the components in a flashlight are pretty tough and would most likely not fail even if left on high until the 2x26650 cells ran out. As mentioned above, the light will become too hot to hold well before anything is damaged. Metal becomes too hot to hold with the bare hand at around 55C or so, which is not very high for LEDs or components on the driver.
Note, however, that when LEDs are dedomed or sliced this can leave debris or inconsistencies on the surface of the LED die which can burn and ruin the LED. So keep an eye on the LED surface for the first 10 minutes or so of being on high. A burn will show up as a black spot.
First of all, what is a “normal” amperage though the LED on the stock L6? I just measured 5.43A initially and 5.23A after roughly 30 seconds.
I am using “26650 KeepPower 5200mAh Protected High Discharge Flat Top” batteries. Item number 2239 on ILLUMN. Should have a 9.5 max discharge rate. Those are fine right?
Why would the 70.2 be worse? Seems like the LED’s inside the dome have less of a gap, so there should be less of a donut hole. I ordered one yesterday so I am hoping it wasn’t a wrong decision.
My current plan is to stick the 70.2 in with a SMO reflector. Also do a resistor mod with a R120 resistor. Although now I may go with the FET driver you linked. What amperage should I expect out of that? I don’t see anything listed on the website.
I don’t necessarily want a true “thrower”, just a slightly more focused hot spot with a similar.
With the D4 firmware thermal protection will the light just cut out completely at 60C or will it just tone down the intensity to prevent damage? I couldn’t find much information on it.
