cool!
Received my Q8 .
O. K.
Thank you very much (to the whole team).
Tested, All right.
2 Questions: 1st = is there a reward for tips that can lead investigators to your location?
2nd = where exactly are you (gps coordinates is preferred).
:money_mouth_face:
Oh no pushed back another day!!! Tomorrow it should arrive.
Nice to hear good reports!
JakeDjanitor well it ia close
Price Drop: Listed now at $79.95. 42 reviews, all 5 stars.
All five stars! Certainly well-deserved, but still very impressive!
I scrolled through the reviews and was impressed by the number of photos shared by buyers.
Awesome to see reviews in many different languages, and fun to see some familiar usernames! :partying_face:
Mine arrived today in Manchester UK.
All good, no apparent issues. Build quality seems excellent and it’s bright as hell. Hot as hell too!
Tried it outside in the dark and it hit buildings about 150 metres away in a built up area with lots of ambient light.
Thanks to all involved.
I’m having a lot of fun shinning the Q8 around. Can’t help on the double click!
However, since the switch leds are much brighter then expected - you can move around the house at night just with the green glow, did anybody estimate or measure the parasitic drain involved?
from post # 7351, Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light Tom E wrote:
I just confirmed the parasitic drain on the round #3 Q8:
with switch LED on: 135 µA
with switch LED off: 22 µA
not sure if he or anyone has measured a production light.
With one 3 Ah cell that is
3Ah/(135e-6A*24h*365d) = 2.5a runtime.
So the Q8 with 4 cells can light for 10 years the switch!
Assuming the production version has the same drain as the prototypes your talking years, so no worry.
As always, if your not using the light and it’s going to sit a long time, just twist the battery tube to break the connection.
Maybe someone can measure the drain on a production light that has the overly bright switch leds?
Just take a DMM and set it to measure DC current and use one battery then use just the head facing down. Touch the positive tip of the cell to the big ring then run the DMM wires from the cell negative to the outer ground ring on the driver. Should be pretty easy. You may have to wait 6 (?) seconds for the mcu to go to sleep.
Does this sound correct?
My local usps has it. I can tell because the sky is lit up down across town hahaha.
I’ll have an update tomorrow . I can’t wait to try this thing out. Ever since it was first discussed. I am the one that asked for low voltage protection and you guys put it into the list right away.
It is cool to have been a little small drop in the bucket of this light from back when you guys started discussing it. ( post #20)
Yes sounds good, only measuring µA can be a bit tricky with older multimeters.
My old one can’t, so I ordered the ANENG AN8008 , it can go down to 0.01 µA (some shops have them for below $20).
Man, I don’t come here often and this is my fist new light in a while, but I’m EXTREMELY impressed. The UI alone is a massive feat, with so many features that I haven’t even attempted to try them all. I just regret not buying as many as I could possibly order at $40, that’s just an absolute steal.
I want to thank everyone involved for doing such an amazing job on this!
Can’t wait for mine to show up! BG has the tracking number but I don’t know where to track them…. I even throw the whole number in google and tried each carrier. And none of them were correct… Same thing goes with my MF01.
Expected delivery date are 10/23 for the MF01, and 10/26 for the Q8 But I have no idea where they are staying now lol
Not sure about the reward on that one but I did have one in FL about 20 years ago and that one was for 167Mph but I settled that one out of court.
This was also posted in post #2.
I tested my production light and registered 20 µA with the LED off. Given it’s not a high end DMM and the variance is only 2 µA, I’d say production is the same as the test sample.
With any luck 1 of 3 will land tomorrow. I got notification that it was on it’s way from Dallas to my home town, so it should show in the morning as out for delivery.
Edit: That might be presumptuous of me, as there are multiple stock tanks and watering holes between here and Dallas it might want to check out on the way here. We’ll see. lol
