Iām having a lot of fun shinning the Q8 around. Canāt help on the double click!
However, since the switch leds are much brighter then expected - you can move around the house at night just with the green glow, did anybody estimate or measure the parasitic drain involved?
Assuming the production version has the same drain as the prototypes your talking years, so no worry.
As always, if your not using the light and itās going to sit a long time, just twist the battery tube to break the connection.
Maybe someone can measure the drain on a production light that has the overly bright switch leds?
Just take a DMM and set it to measure DC current and use one battery then use just the head facing down. Touch the positive tip of the cell to the big ring then run the DMM wires from the cell negative to the outer ground ring on the driver. Should be pretty easy. You may have to wait 6 (?) seconds for the mcu to go to sleep.
My local usps has it. I can tell because the sky is lit up down across town hahaha.
Iāll have an update tomorrow . I canāt wait to try this thing out. Ever since it was first discussed. I am the one that asked for low voltage protection and you guys put it into the list right away.
It is cool to have been a little small drop in the bucket of this light from back when you guys started discussing it. ( post #20)
Man, I donāt come here often and this is my fist new light in a while, but Iām EXTREMELY impressed. The UI alone is a massive feat, with so many features that I havenāt even attempted to try them all. I just regret not buying as many as I could possibly order at $40, thatās just an absolute steal.
I want to thank everyone involved for doing such an amazing job on this!
Canāt wait for mine to show up! BG has the tracking number but I donāt know where to track themā¦. I even throw the whole number in google and tried each carrier. And none of them were correctā¦ Same thing goes with my MF01.
Expected delivery date are 10/23 for the MF01, and 10/26 for the Q8 But I have no idea where they are staying now lol
I tested my production light and registered 20 ĀµA with the LED off. Given itās not a high end DMM and the variance is only 2 ĀµA, Iād say production is the same as the test sample.
With any luck 1 of 3 will land tomorrow. I got notification that it was on itās way from Dallas to my home town, so it should show in the morning as out for delivery.
Edit: That might be presumptuous of me, as there are multiple stock tanks and watering holes between here and Dallas it might want to check out on the way here. Weāll see. lol
I got my q8 today. ( Expected delivery date is wed.)ā¦ so happy with this lightā¦ I donāt find anything wrong with this light so farā¦ I am using Samsung 30q button topā¦ so much lumen from this small lightā¦thanks for the great deal to blf and banggood.
You may have missed the point here. We know the driver draws 22uA, it was the brighter than normal leds that we were wondering about. Since they are so much brighter than the prototype, we were looking for someone to measure the combined drain to see if it is much higher than 135uA.
