Lexel
(Lexel)
October 16, 2017, 5:35pm
14
The Indicator LED blinks out after you stopped ramping which bank is active
You can add extra AMC7135s
The ramping table is a good start and gives good results on most lights,
it depends also how much the FET current is, like a single LED can draw on 17mm 2.45A from AMCs and 6A from FET
while a quad board draws 2.45A from AMCs and 12-15A from FET
for quads the ramping in FET will be proportional bigger,
the SRK sized have 5.6A AMCs to about 20A FET
but the steps in FET are the same its still smooth
dekozn
(dekozn)
October 17, 2017, 11:12pm
15
ok thanks for explaining.
So I’m stil up for
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 16AMC
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 8AMC
Blazer296
(Blazer296)
October 19, 2017, 6:39am
16
Now that I have read through things a bit more, I am liking these even more.
When you can get to them,
(2) 30mm 2S NarsilM LDO 65°C, SD=6V, PO=(NO), lighted side switch, LED wires, no spring
shipped w/tracking please.
Not sure on the wire length, as I dont have the hosts (Convoy L6 ) in hand yet. Seems common enough I trust your judgment on that, just let me know.
Thanks,
Jim
Lexel
(Lexel)
October 19, 2017, 6:42am
17
Blazer296:
Thanks,
Jim
I can do this in this batch, but I have to wait to stock up parts and 30mm boards
Blazer296
(Blazer296)
October 19, 2017, 6:45am
18
Sounds good. I am in no rush. Got several others in the works right now to play with.
JasonWW
(JasonWW)
October 19, 2017, 8:48am
19
Lexel, on the 2S boards for the L6, are you still using the 4700k resistor for the switch light?
JasonWW
(JasonWW)
October 19, 2017, 9:05am
21
steel_1024:
4.7K ?
I use 20K
20K~30K are fine?
Yeah, I use 15k to 30k.
I was just gonna suggest Lexel increase the resistor value for these 30mm 2S L6 drivers since everyone usually uses 2 leds.
JasonWW
(JasonWW)
October 19, 2017, 9:04am
22
I had another question. Is this accurate?
When it comes to NarsilM and a 2S driver, you can only have 2 of these 3 options:
Temp protection
Low voltage protection
Indicator function
Could you sacrifice temp protection in order to get LVP and the indicator function?
Lexel
(Lexel)
October 19, 2017, 9:12am
23
temp does not need a pin, the other 2 does
The 4.7k is the minimum resistor, other values are possible, of course rewire the switch board for diodes in series increases the efficiency
JasonWW
(JasonWW)
October 19, 2017, 10:28am
24
Lexel:
Temp doesn’t need a pin? Is that only in NarsilM?
I remember on the older Narsil that I had to choose between temp or lvp.
I chose lvp and no temp. I’m a little confused about this.
The Convoy L6 switch LEDs are parallel. It would be a major undertaking (cutting traces and adding wires) to make it series.
Lexel
(Lexel)
October 19, 2017, 11:54am
25
This was the choose between v1.2 and 1.3, 1.3 does not support LVP in 2S, but got a lot of functions like temp sensor readout and use
JasonWW
(JasonWW)
October 22, 2017, 12:19pm
26
Just a heads up, Lexel. It looks like the 2nd generation of Astrolux MF01 have a new wiring pattern on the mcpcb (along with a new driver design). We will have to see if the TA driver can be compatible with it.
[image]
[image]
I just got a my nichia 219c out of the mailbox.Looks great not a mark on it.Here are pics of the new driver and mcpcb. Alot different that’s for sure.Igot 10701 lumens with 10100@30s. on fresh vtc6.I’m going to check again after while to be sure i got it right.
Lexel
(Lexel)
October 22, 2017, 12:45pm
27
you would have to modify the MCPCB
Lexel
(Lexel)
October 23, 2017, 3:31pm
28
Narsil can be set up for modes with different mode groups
21mm fits my H03
Lexel
(Lexel)
October 24, 2017, 3:23pm
29
OK today 200 AMCs got delivered, so we can start to build drivers
Flintrock
(Flintrock)
October 24, 2017, 11:16pm
30
6S LEDs? and holds 4 batteries? Not without ledboard modifications. Not a chance.
DoNkEyConN
(DoNkEyConN)
October 30, 2017, 12:14pm
31
hello, am i able to order a 30mm driver for an Convoy L6?
Lexel
(Lexel)
October 30, 2017, 1:02pm
32
I got 30mm for L6 in stock
just I need the settings you prefer and I can flash and test it the same day
DoNkEyConN
(DoNkEyConN)
October 30, 2017, 1:36pm
33
hmmm mybe im in a lil over my head. i know i would like the bistro ui but alot of the other info in the first post im struggling to understand.
I would like to get max power out of my L6, any suggestions?
