Blazer296
(Blazer296)
October 19, 2017, 6:39am
16
Now that I have read through things a bit more, I am liking these even more.
When you can get to them,
(2) 30mm 2S NarsilM LDO 65°C, SD=6V, PO=(NO), lighted side switch, LED wires, no spring
shipped w/tracking please.
Not sure on the wire length, as I dont have the hosts (Convoy L6 ) in hand yet. Seems common enough I trust your judgment on that, just let me know.
Thanks,
Jim
Lexel
(Lexel)
October 19, 2017, 6:42am
17
Blazer296:
Thanks,
Jim
I can do this in this batch, but I have to wait to stock up parts and 30mm boards
Blazer296
(Blazer296)
October 19, 2017, 6:45am
18
Sounds good. I am in no rush. Got several others in the works right now to play with.
JasonWW
(JasonWW)
October 19, 2017, 8:48am
19
Lexel, on the 2S boards for the L6, are you still using the 4700k resistor for the switch light?
JasonWW
(JasonWW)
October 19, 2017, 9:05am
21
steel_1024:
4.7K ?
I use 20K
20K~30K are fine?
Yeah, I use 15k to 30k.
I was just gonna suggest Lexel increase the resistor value for these 30mm 2S L6 drivers since everyone usually uses 2 leds.
JasonWW
(JasonWW)
October 19, 2017, 9:04am
22
I had another question. Is this accurate?
When it comes to NarsilM and a 2S driver, you can only have 2 of these 3 options:
Temp protection
Low voltage protection
Indicator function
Could you sacrifice temp protection in order to get LVP and the indicator function?
Lexel
(Lexel)
October 19, 2017, 9:12am
23
temp does not need a pin, the other 2 does
The 4.7k is the minimum resistor, other values are possible, of course rewire the switch board for diodes in series increases the efficiency
JasonWW
(JasonWW)
October 19, 2017, 10:28am
24
Lexel:
Temp doesn’t need a pin? Is that only in NarsilM?
I remember on the older Narsil that I had to choose between temp or lvp.
I chose lvp and no temp. I’m a little confused about this.
The Convoy L6 switch LEDs are parallel. It would be a major undertaking (cutting traces and adding wires) to make it series.
Lexel
(Lexel)
October 19, 2017, 11:54am
25
This was the choose between v1.2 and 1.3, 1.3 does not support LVP in 2S, but got a lot of functions like temp sensor readout and use
JasonWW
(JasonWW)
October 22, 2017, 12:19pm
26
Just a heads up, Lexel. It looks like the 2nd generation of Astrolux MF01 have a new wiring pattern on the mcpcb (along with a new driver design). We will have to see if the TA driver can be compatible with it.
[image]
[image]
I just got a my nichia 219c out of the mailbox.Looks great not a mark on it.Here are pics of the new driver and mcpcb. Alot different that’s for sure.Igot 10701 lumens with 10100@30s. on fresh vtc6.I’m going to check again after while to be sure i got it right.
Lexel
(Lexel)
October 22, 2017, 12:45pm
27
you would have to modify the MCPCB
Lexel
(Lexel)
October 23, 2017, 3:31pm
28
Narsil can be set up for modes with different mode groups
21mm fits my H03
Lexel
(Lexel)
October 24, 2017, 3:23pm
29
OK today 200 AMCs got delivered, so we can start to build drivers
Flintrock
(Flintrock)
October 24, 2017, 11:16pm
30
6S LEDs? and holds 4 batteries? Not without ledboard modifications. Not a chance.
DoNkEyConN
(DoNkEyConN)
October 30, 2017, 12:14pm
31
hello, am i able to order a 30mm driver for an Convoy L6?
Lexel
(Lexel)
October 30, 2017, 1:02pm
32
I got 30mm for L6 in stock
just I need the settings you prefer and I can flash and test it the same day
DoNkEyConN
(DoNkEyConN)
October 30, 2017, 1:36pm
33
hmmm mybe im in a lil over my head. i know i would like the bistro ui but alot of the other info in the first post im struggling to understand.
I would like to get max power out of my L6, any suggestions?
Nicolicous
(Nicolicous)
October 30, 2017, 1:37pm
34
Nasil firmware have the ramping brightness which is better than bistro UI.
JasonWW
(JasonWW)
October 30, 2017, 1:46pm
35
DoNkEyConN:
A FET driver will get max power (10A). Unprotected high drain batteries will get more power (12-13A). A 70.2 swap will get even more power (17-18A). You can get up to 8,500 to 9,000 lumen.
I’d suggest NarsilM firmware as it’s really nice.
See here.
