temp does not need a pin, the other 2 does
The 4.7k is the minimum resistor, other values are possible, of course rewire the switch board for diodes in series increases the efficiency
Temp doesn’t need a pin? Is that only in NarsilM?
I remember on the older Narsil that I had to choose between temp or lvp.
I chose lvp and no temp. I’m a little confused about this.
The Convoy L6 switch LEDs are parallel. It would be a major undertaking (cutting traces and adding wires) to make it series.
This was the choose between v1.2 and 1.3, 1.3 does not support LVP in 2S, but got a lot of functions like temp sensor readout and use
Just a heads up, Lexel. It looks like the 2nd generation of Astrolux MF01 have a new wiring pattern on the mcpcb (along with a new driver design). We will have to see if the TA driver can be compatible with it.
you would have to modify the MCPCB
Narsil can be set up for modes with different mode groups
21mm fits my H03
OK today 200 AMCs got delivered, so we can start to build drivers
6S LEDs? and holds 4 batteries? Not without ledboard modifications. Not a chance.
hello, am i able to order a 30mm driver for an Convoy L6?
I got 30mm for L6 in stock
just I need the settings you prefer and I can flash and test it the same day
hmmm mybe im in a lil over my head. i know i would like the bistro ui but alot of the other info in the first post im struggling to understand.
I would like to get max power out of my L6, any suggestions?
Nasil firmware have the ramping brightness which is better than bistro UI.
A FET driver will get max power (10A). Unprotected high drain batteries will get more power (12-13A). A 70.2 swap will get even more power (17-18A). You can get up to 8,500 to 9,000 lumen.
I’d suggest NarsilM firmware as it’s really nice.
See here.
ok, sounds like Narsil is the go. is there anything else i need to consider?
Not really. Let Lexel do all the default stuff.
You can choose what the driver does when it first gets power from the rear switch. There are 4 options. Nothing (fine if you have a lighted side switch), 2 faint blinks (good choice, the Q8 has this), moon (seems odd), or turbo (I have this on my L6 and it gets annoying after a while, still it’s good for blinking SOS or something).
Is there a working bistro UI that has been released for e-switch? I'm running it now(unreleased) and I love it. It's not as smooth, but I always can change it and know which way it's going to go and how much current it's using.
Anyway, you guys are discussing NarsilM vs bistro "ui" as if there is a choice, and I think until I release this in the next couple of days there's not, and nobody other than myself has even tried it on an e-switch, unless I'm missing something.
DoNkEyConN suggested bistro on the L6, but he is not familiar at all with driver designs.
I’ve never personally researched bistro so I didn’t know it was clicky switch only.
The L6 does have a forward clicky rear switch. Maybe bistro could work with that? Idk, I’m just guessing here.
Thanks for all the advice JasonWW,
I have put in my order. Cant wait to turn my L6 into a beast!
Can you do a driver for haikelite mt03 II?
I did in the past mod normal SRK drivers for MT03
as I have only one SRK driver board left I did a dedicated MT03 Design on Oshpark
list updated with more details
