Not any moreā¦
Meaning?
The pic canāt be seen
Ah sorry about that. I changed the privacy policy of my albumsā¦. accidentally in batch. Fixed many but I posted like hundreds of pictures, missed this one too. That was stupid, changed the policy back to itās original state didnāt fix it. I have to do it manually one by one.
As for the picture, itās not relevant anymore since the final designs are those in the OP. Iām still making my own test rig so donāt have to always overload Djozz with my test requests.
- Clemence
Yes, I would like to see final product. I enjoy nice pics so when someone says āEye candyā but the pic is not available that is kinda let down
Shipment released from the custom! :laughing:
- Prototypes received, OP updated with the preview
They look Great! Sorry to hear they are super expensive. Once they are up on the store Iāll be picking up a few regardless as I have some projects that could benefit.
16mm single 144
There is no space to place the insulating gasketļ¼
With such flexible options in 16mm you donāt have much room left. You better use kapton, electrical tape, or epoxy to make needed insulation.
They look very attractive! I will surely be in for some, no matter what price they will be, more of course when they are affordable
Just when we though they couldnāt be more pricey, then the custom added some 40% more to the billā¦ā¦
Iām still trying to simulate your Djozz test here. The only datum to your test is the S3030 VirEnce board, 144AM sm653 R70, and the TASI meter test. Will report the test ASAP.
- Clemence
Amazing #1 test result! Check the OP
- Clemence
Theyāre so pretty. Canāt wait to order some!
Final touch by Texas_Ace
Awesome results, really excited to finally have a good option for 144A and E21A!
Great results!
These boards are also nice for an Oslon version, because the thermal pad of Oslon Blackās (that is connected to led-minus) can then be electrically insulated from the body of the flashlight.
Created many centering/positioning jigs, spent two VR16SP4 boards, some E21As (fortunately the R70), and one full day without success. Only later, I remember I didnāt stir the thermal paste after left in the fridge for weeks. Now the reflow works flawlessly. No gimmicks, just simple drops of solder paste and light tapping using flexible bamboo stickā¦ā¦and voila! The said to be difficult to solder E21A moved themselves to the correct position. The ultra thin solder mask do works. Perfect quadtrix board!
Many manufacturers gave up on E21A because it has very little to no self aligning behaviour during reflow. Thus requires very accurate PNP and solder dosing machine. But with very thin solder mask the self align effect restored back, even at very little solder paste applied. Thinner solder bond line, easier manufacturing, at the expense of fragile solder mask.
I use Sn96,5Ag3Cu05 (max. 260C @30seconds), with Sn63Pb37 reflow should be far easier.
I still have few hours before my flight, will post later.
- Clemence
OP updated with the latest test results of E21A
- Clemence
Iām still wondering how in parallel config those E21As performed significantly far more efficient. Iāve never seen anything like this before. Tested some XPGs 219Cs in single and quad parallel, but the difference between the parallel vs single config were never as high as E21A.
In parallel, the current divided into 4 lower current paths hence the boost in efficiency. But look at the chart below. Itās not lumen, just measured lux from my lux meter. At the same power level (near 3A), the output already doubled. My guess is E21A is super inefficient above 2A, while in low current its the other way around. To the eye 4p was indeed much brighter than the 1s config (at the same power).
The lower voltage also a good thing, most likely due to the lower resistance not only due to the hotter 4 cramped LEDs. The voltage reduced from as low as 100mA where heat is unlikely to affect the output.
Any idea?
- Clemence
