Different Looking Samsung 30Q
15 posts / 0 new
vince
Last seen: 1 year 4 months ago
I've just received a lone 30Q from a local retailer that looks a little different from the other ones that I have. All of my other 30Q have a second thick clear wrap over the pink wrap, this one didn't. Also the external pink wrap extends beyond the button top.
Is this just a difference of batches?
NB: I'll stick it on an analyzer at some point on the weekend. I'm just curious about the inconsistency in appearance.
FPV
FPV's picture
My 30Qs from Gearbest and other sources have no second clear wrap. Just one pink wrap and the white “disc” around Bat+.
Mine are new and unused but at least 1 year old (at storage voltage/never charged).
g_sintornillos
g_sintornillos's picture
Last seen: 6 months 4 weeks ago
Photos?
Sorry for my bad English (gogole transtorla)
vince
FPV wrote:
My 30Qs from Gearbest and other sources have no second clear wrap. Just one pink wrap and the white "disc" around Bat+. Mine are new and unused but at least 1 year old (at storage voltage/never charged).
Cool, it sound like minor manufacturing changes. I'm not really suspicious of counterfeits from either vendor, just more curious of the inconsistency, as all of my Panasonic 18650s are 100% alike.
RobertB
RobertB's picture
Last seen: 2 weeks 4 days ago
I’d be suspicious of that 30Q too. They come from the factory as a flat top wrapped with printing on the wrap. The factory doesn’t install the button on top, third party people do.
sac02
sac02's picture
Can you clarify, are you comparing flat top or button top 30Q?
Flat tops should be as they were when left the Samsung factory, with flat top, pink wrap, no clear overwrap.
Button tops or raised tops do no come straight from Samsung – the extra button top is added by a third party, and there are several (many?) of them (none of whom are battery OEMs). As such, they will typically have an added clear overwrap, and some variation in appearance.
Pete7874
Pete7874's picture
Last seen: 1 hour 58 min ago
g_sintornillos wrote:
Photos?
+1
Let’s see it.
ChibiM
ChibiM's picture
Last seen: 3 days 31 min ago
+2
Sirius9
Sirius9's picture
Last seen: 3 hours 58 min ago
He is probably comparing protected and unprotected cell…
Pete7874
Pete7874's picture
I’ve never heard of a protected 30Q.
But he might be comparing a flat top and a button top. Smile
r1derbike
I received my 30Qs (8, Banggood) with button tops overwrapped with clear. Haven’t done any cycling to check discharge/charge curve.
Seem to work the bomb (really, no pun intended) in my Fenix TK-75, however.
lawallac
lawallac's picture
Last seen: 13 hours 27 min ago
My 30Q button top cells, that I got from BG, came with a heavy clear plastic over them. First thing I did was cut it off so I could use the cells.
vince
sac02 wrote:
Can you clarify, are you comparing flat top or button top 30Q? Flat tops should be as they were when left the Samsung factory, with flat top, pink wrap, no clear overwrap. Button tops or raised tops do no come straight from Samsung - the extra button top is added by a third party, and there are several (many?) of them (none of whom are battery OEMs). As such, they will typically have an added clear overwrap, and some variation in appearance.
Yup! That's exactly what it is. I saw your post, and thought "I'll check that again when I get home". Not sure why I just assumed that all of the 30Qs were button tops - I'll order a couple more now though, because the flat tops are a much easier fit into battery holders etc.
Cheers!
Sirius9
Sirius9's picture
This days anything is possible Smile
vince wrote:
I’ll order a couple more now though, because the flat tops are a much easier fit into battery holders etc.
Just be advised, flat top cells don’t work with flashlights that have physical reverse polarity protection like nitecore lights have.
r1derbike
I’ve used ultra-thin neodymium magnets between flat-top cells for spacing, but the danger in this is obvious.
