Test/review of TrustFire IMR26650 3400mAh (Red-gold)
Official specifications:
  • Battery Capacity (Mfg Rated): 3400 mAh
  • Battery Chemistry: Li-Ion
  • Battery Feature: Rechargeable
  • Battery Form Factor: 26650
  • Battery Maximum Voltage: 4.2 V
  • Battery Minimum Voltage: 2.85 V
  • Battery Rated Voltage: 3.7 V
  • Anode material: LiNiCOMnO2-C
  • Discharge Rate: 20C
  • Maximum discharge current: 68A
  • 300-500 times rechargeable
This 26650 cell is fairly low capacity, but high current.
The discharge curves looks good, it can deliver up to 20A with nearly constant capacity.
Conclusion
This looks like a fairly good battery for high current application, but capacity is fairly low by todays standard.
Notes and links
Compare to 18650 and other batteries
Thank you for this review Henrik. It demonstrates that not all xxFire batteries are total crxx.
And if this fairly low capacity battery has a fairly low price, things fall into their right perspective.
Good to know some of them are good.
