…and helicopter surplus stuff…
Every LED is inefficient when driven with a high power density. The XHP70.2 is no exception there. The Luminus LED has much higher luminance and thus will get you more throw. It will produce an amazing beam, that most here are not used to.
It is the 3x3mm die that does the talking, a XPL has a ~4 mm2 die, a XHP70.2 4 times that: 16 mm2. So with 45% smaller die it produces just 32% less light than a XHP70.2 at maximum current (~20 A).
So it throws better than a XHP70.2, by 20%
(numbers scraped away from various places, correct me if I made a mistake)
When comparing them one needs to take into account that the XHP70.2 will be dimmer after de-doming. So the difference in luminance is larger. The XHP70.2 has been tested up to 145W, so I will compare both LEDs at this power.
XHP70.2 P2 - 20A - 7.25V - 8300lm @ 85°C with dome - 20% less without dome would be 6640lm - ~149cd/mm^2 (XP-L2 de-domed is 3.55mm^2, so the XHP70.2 de-domed is 14.2mm^2) - 46lm/W
CFT-90 - 38A - 3.81V - 5600lm @ ??°C without dome - 228cd/mm^2 - 39lm/W
I don't know what temperature the LED had in sma's test though. The real values might be a bit different.
So the CFT-90 has a roughly 50% higher luminance compared to the XHP70.2 at 145W. Thats a noticeable difference! Both have a very low efficiency at such high power levels. The difference between the two is rather small in this regard. Luminus has definitely caught up! When considering power density the CFT-90 is actually much better compared to the Cree LED.
The temperature is also important. The XHP70.2 has a thermal resistance of 0.9°C/W without the PCB and the CFT-90 has 0.45°C/W with the PCB. So in reality the value of the XHP70.2 will be a bit higher. Both have a maximum allowed junction temperature of 150°C. Lets say the heatsink (flashlight) has a temperature of 50°C @ 145W (maximum temp that is pain free). Here's a rough calculation (ignoring the LED-heatsink interface etc.):
CFT-90: (145W * 0.45°C/W) + 50°C = 115°C
XHP70.2: (145W * 0.9°C/W) + 50°C = 180°C
So with this heatsink the XHP70.2 would have a high chance of failure and the Luminus LED would have no problem even though it has a much higher intensity and is less efficient. That's a large advantage if you ask me.
At this power level the heatsink of the XHP70.2 needs to stay cooler than 20°C (to stay under 150°C). You would need powerful active cooling to achieve this. The heatsink of the Luminus LED on the other hand only needs to stay under 85°C. That will be difficult but doable.
last time i checked the price of sst-90 is very high, so i bet this led is no exception
It’s much more expensive compared to the SST-90. >100$, but I find this genereally reasonable. It is designed to replace Xenon short-arc lamps. In the long run it is much cheaper compared to them because they have a rather short lifetime and require more power. It is also by far the most powerful officially rated LED on the market.
Interesting. Burn 27A worth of power to get what the 70.2 can do with 8A or so. I have a 70.2 in my Convoy L6 making 9200 lumens off of 2 26650 cells, commonly available driver and the emitter is less than $20. Not really seeing the appeal of the luminus.
I’ve liked the CBT-140 for a while, but it, like other Luminus emitters, is so inefficient it’s hardly worth the triple digit price point.
Edit: Not to mention that the extremely common and cheap XM-L2 is capable of a mile in throw (actually a measured 815Kcd) from a reflectored light. At only 4.6A. From a single cell. Simple FET driver.
The XHP70.2 P2 does not produce 5000 lumens at 8A when de-domed, maybe 4000. The Luminus LED will produce much more throw. More than the XHP70.2. More than any XM-L2 de-domed. It beats them all. In addition to this it produces a lot of lumens. The XM-L2 will do up to around 1700 lumens when de-domed. That’s quite a bit less. So compared to a de-domed XM-L2 you will get a hotspot that is 2.5x as large and at the same time probably around 30-45% more Candela.
The CBT-140 is basically the 5-years old predecessor. The CFT-90 is new, much more efficient and has a much higher luminance.
The appeal is this: it’s the best. The best always costs a premium. If you want over 100W of power in a single power-LED continously and not worry about the reliability, this LED is the only option (because of the lower temperature, see my post above).
The xhp70.2 needs about double the Voltage, so you should look at U × I = P (Power in Watts).
I wouldn’t compare the numbers at the peak output. The inefficiency is indeed terrible. But at around 30A it’s much better in this regard (which doesn’t make it good actually). And it will still out-throw nearly anything on the market. And certainly anything close to its output.
I don’t see the point comparing it to XHP70.2. It’s much more powerful and efficient, but much bigger. XHP50.2 is much closer, actually pretty much the same size. And max output is close too, 5000 lumens with the dome. 50.2 leaks light to the sides, so it’s much less throwy with the same output. Efficiency? ~80W@5000 lm for XHP50.2 (with dome) and ~110W for CFT-90. Dedome and you’ll arrive somewhere in the 4000-4500 lm range with the same 80W consumption. Scale CFT-90 down to this level, it takes ~70W@4500 lm and ~60W@4000 lm.
The only thing I can see this LED being easily used in is a Big Aspherical Lens/ Fresnel build, can’t see a massive reflector with a massive aperture being cost effective.
$200.00 for LED/Driver with active cooling in an Aspherical Light with the cost of materials, machining and powering up to 40A….I don’t like aspheric lens lights, so it’s not attractive to me.
But I hope some one with some $$$$ bucks goes forward with it…. :+1:
Oh, don’t get me wrong… I’m not saying I wouldn’t like to try it out and see, but at the price point, the offset COB design, and the extremely high amp requirements, I don’t see myself doing anything with this one for quite a while.
When you want max throw, you can throw efficiency out the window.
The point is to get the highest possible numbers, and this is currently #3 on the list of highest intensity LEDs.
What’s so cool about it is that it can do this while also outputting a huge amount of lumens, which the first two don’t do.
Perfect LED for applications such as moving heads, which are starting to transition to LED:
And sky beams which are currently all short-arc:
Neither of these are “flashlights” and neither of them are “budget” so the majority of people on this forum won’t really get excited by this LED
So hypothetically, what kind of numbers would be seen in a BLF GT sized reflector?
2.3Mcd, ~3km throw
~4k lumens in spot, ~1.2k in spill.
265m spot diameter at 1km
10 degree beam divergence.
I indeed did not take the domelessness (is this a word? :innocent: ) of the CFT-90 into account in my calculation, that makes a big difference.
If any host is suitable for this led it must be the BLF-GT, in fact its bulkiness and that it takes 8x 18650 batteries makes it more tailormade for the CFT-90 than for the XHP35, as if the GT temporarily is fitted with a XHP35 but in reality was waiting for this led .
High thermal mass doesn’t necessarily mean high thermal dissipation, if this LED was driven anywhere near its max in a GT it would overheat instantly.
I wouldn’t recommend it for any ‘normal’ flashlight form factor, more for something with AT LEAST a fan cooled heatsink, or preferably liquid cooling.
Mind that a well-fixed Q8 runs at over 20A already, at a comparable voltage, so half the current of the CFT-90 at maximum output, and does that for 3 minutes without getting worryingly hot. With its larger mass and surface area the GT should be able to run the CFT-90 at over 40 A for three minutes too before stepping down.
First of all, the heat from a Q8 is spread out over 4 points, the CFT90 is a single LED so the junction temperature will be 8x higher than a Q8 (since it will be producing 2x the heat output).
For this reason you would need to use a large copper base heatsink, or a TEC.
Second, the surface area of the GT is probably close to 10% that of the heatsink used in SMA’s test. Heatsinks have tens or hundreds of times more surface area than a flashlight like the GT with its few shallow fins.
Third, the mass doesn’t matter at all for heat dissipation, it’s just an energy reservoir.
If all you care about is a few seconds of high output then sure, the GT will work, but for practical purpouses and actually using the light for more than a few minutes on max it needs to have much higher thermal dissipation.
Personally I think any light that can’t maintain its max output for long periods of time is basically useless, it may as well not have that max setting.
Which is why I hate lights that are direct drive.
^ It is an ongoing discussion on BLF how desirable high output/fast stepdown flashlights are. For maintaining the high output of the CFT-90 for longer time the GT will not suffice, but I’m sure someone will do the mod and I’m curious what runtime on max it will have
