Yep…. The 5V fans had a resistor wired in line to knock the 12V power supplied down to 5V.
The 12V ‘replacement fans’ were just wired straight with no resistor.
In one of the Opus chargers, I installed a 12vdc fan salvaged from a PC power supply. I drilled several holes at the bottom half of the charger, spliced off a connector from another Opus charger, then installed the connector in place of the stock connector (which is still connected to the stock 12vdc fan but no longer connected to the pcb as shown).
The new fan now sucks through the numerous holes, drawing ambient air through the cells and down the 4 rails and the pcb below, and much quieter now, making the cells just warm enough to trigger the charger’s temp. termination requirement.
The new fan still kicks in automatically as required by the sensors.
And yes, the stock fan is 12vdc, left untouched.
Below shows the original connector I got from my other Opus is connected to the new fan, then connected to the original male terminal, leaving the Original fan and connector untouched. So in effect the bigger fan is still controlled by the charger automatically.
Btw, those long rectangular raised strips, surrounded by my drilled holes, are also open on its side (air can pass through too), just cannot be seen from this photo angle.
Lastly, this mod is just for fun, (and an improvement with regards to noise and cooling), but actually, the stock fan is enough for the cooling needs of this charger.
FLAW in Opus BT-C3100 2.2,at least mine is flawed!
I have discovered that It is NOT 26650 friendly after acquiring 2 X 26650 torches.3 out my 4 26650’s do not make contact on the positive end. After evaluating the problem, this is what I discovered.
1. The positive contact does NOT have a nub[nipple] on it like my other 3 chargers.
2. The positive contact is recessed a bit and not robust like my other chargers.
3. The battery well is not deep enough resulting in the BT/FT to rise above the chargers positive contact resulting in NO contact.
If I manipulate the batteries , sometimes I can get temporary but precarious contact.
I went and bought some Neodymium magnets[HKJ recommended] and they did not help becuase it is a flaw in the contacts design where these bigger 26650 rise above the positive contact.
These batteries do Not work.
1. Xtar 26650 4000mAh-
Look how RAISED the positive contact is and it still does not work because it hovers above the chargers Positive contact because the well is NOT deep enough!
2. Orbtronic 26650 5750mAh-
I have Three of these. I put solder blobs hoping that would help,it did not. The size of the batteries positive end makes NO difference, the positive contact of the charger is flawed!
3.Ijoy 26650 4200mAh
The Vappower 26650 4200mah is the only one that works!
ALSO: The Thrunite 26650 5000mAh w/ Brass BT is iffy. Battery needs to be manipulated in order to make contact.
Photos below:
s I am still waiting for my NEW OPUS from Henry. I have not heard from him since last September. I emailed him a few months ago and again today to let him know about this issue.
Put a Piece of foil between the contact point—- better yet a strip of copper or brass —- but foil does work— fold a piece about 4-5 layers thick about 1/2 ” wide x 1- 2 ” long so you can hold it in place until the battery clamps it in
