What is it your talking about? A reflective collar? Iâve never heard of this.
Wavien collar, search BLF Jason
Agro, ooh patents are such a difficult topic idk if it is worth burning our fingers on.
JasonWW, search on âwavienâ at BLF and elsewhere.
Lemme try, I donât know much: the idea is to surround an emitter with a mirror that sends some otherwise lost photons back to further energize the phosphor.
If anyone can find prior art for the general idea, that would be good to have publicized.
Okay, Iâve seen those before. That seems useful only for an extreme thrower. We already have the GT.
1. That is useful for any thrower regardless of size. What I find the most appealing is zoomie that fits in pants pocket, but puts 800 lm in a 500 kcd hotspot. With SST-40. (Though I have some unsolved problems with it, thatâs why you havenât seen me mentioning it here).
2. Frankly, I think that flat LED itself is a prior art (assuming itâs earlier than the patent). The flat silicon-air boundary reflects more of side-facing light back to the die, further energizing it. But even if it is indeed prior art or we find another one, patent invalidation is very hard and costly.
I have made a 3d design for someone to experiment en test with it.
So the idea is out there.
From what Iâve seen, patent lawsuits generally fall in one of two categories: settle for money (ideally lots from a large company but a little from many small business is just as well for patent trolls) or block your competition from delivering their product (megacorp patent war).
So Iâd say the risk for small scale Chinese manufacturer of flashlights is very near zero. If they were selling, say, millions of dollars of street lighting equipment, then someone might try to block import of their product. For a few flashlights sold directly to customers? Good luck trying to do anything about it.
When it come to copyrights and patents, China is like the Wild Wild West. Thatâs why they copy and clone pretty much everything, including iPhones.
There is a light that Iâve been dreaming of for a while:
- zoomie
- good throw, OK (or better) flood
- big-edc size (think B158 or a little bigger). 45-50 mm lens, 21700 battery.
- e-switch
I spent quite a lot of time thinking through several obstacles. Today I made the fist sketch. It uncovered other ones.
First, some numbers. A focused zoomie with a lens that has f-number of 1 collects only 20% of light. All the rest hits the flashlight body.
I wanted to improve it and I evaluated several options.
#. Mirror adds rings to the beam around the emitter image.
#. TIR lens should be similar
#. Precollimator lens increases the projected emitter size without significantly affecting throw.
It also greatly narrows the flood beam. Maybe it should be defocused together with the main lens to get rid of that effectâŚ
Itâs relatively cheap. It can recycle nearly all of the lost light.
#. Waiven collar. It makes the image of the same size, but brighter. Itâs less good at improving efficiency, can recycle only about a third of collected light. The rest is wasted either by not being reflected (as far as I understand it reflects only the most promising frequency) or not re-emitted (and probably ending up as heat). It also reduces beam width, though slightly less than a precollimator.
#. 2-stage collar. A part of the collar is mounted on LED PCB and a part near the lens. It should collect slightly more light than a regular one, but the main advantage is that it has smaller effect on the flood beam. Since the near-led part doesnât have to collect a lot of light, it can have wider opening and thus:
- block less light from the lens
- be slightly lower, allowing deeper de-focus
2-stage collar acts funny when zooming. It comes out of focus very quickly, making the beam lose a lot of intensity in the initial zooming stage and much less later.
2-stage collar seems like the best option as it allows a fairly wide beam and extreme throw distance in the same light. Though the legal challenges may make it infeasible. Legalities aside, itâs going to be costlier too. For the budget we can have either a good thrower or a good flooder. Or neither. But I see no way to do both (though maybe some precollimator defocusing would help).
When it comes to the emitter / driver I see 3 good options:
1.Dedomed SST-40 with buck-boost driver to keep it exactly at the current that we want. FET wonât work because 21700-30T will blow the LED.
Very high throw, good efficiency, the highest price.
2. XHP35 HI with a boost driver. Less throw, less price, easier to manufacture, better efficiency, better flood. But throw is much worse and thereâs the dark cross in the middle of the focus beam.
3. XP-L HI. Oldie, but still a good option. Paired with FET+1 for a good price.
Now, my drawing:
For the purpose of drawing, I used a 50 mm lens. I guess a 45 mm would be better really. And I certainly made some parts too thin. And tolerances too tight. Itâs a sketch, you know. Also, the drawing uses a 2-stage collar where the moving part is Fresnel style. Being Fresnel style is not important, I just liked to draw it like that.
Problems:
- I failed to account for the threads for battery insertion. Easy fix.
- There is no switch. And the only sensible way to put an e-switch that I see is to FW3A it.
- Cooling is bad. I mean really, really bad. And I see no way to fix it.
At the end, Iâs also point out one potential obstacle. Collar needs to be positioned very precisely. Will various abuses that EDC light will endure make the collar lose focus over time?
Thoughts?
For zoom to flood, you canât really beat led lenserâs optics.
Canât use a collar with it though, but it does collect 100% of the LED light when zoomed, which is the main problem with normal zoomies.
It is half TIR and half aspheric.
A precollimator makes the beam diverge more and create a bigger spot, it does not make it narrower.
A wavien collar does not change the beam divergence, it slightly more than doubles the lux and lumen output, increasing the efficiency from ~25% to ~50%.
(assuming the lens collects all 60 degrees of light coming out of the collar)
Two stage collar is an interesting idea, that would give you basically two different lux measurements and spot sizes.
Only problem is that it would cost at least several hundred dollars to get the small collar made, and probably ~1000 for the secondary one.
Agro:
For better heat management I think you need to make the tube much thicker where it contacts the zooming part. IMHO this is the only option to make it better. Thick tube like 5-6mm walls and bigger diameter for zoom threads. The lightâs thickest point still will be the head so I think it is acceptable.
Or to make it even better The tube can have 3mm holes in almost full length and we can insert 6-7 3mm thick round heat pipes in all length and those will send the heat to the tailcap part. Also at the tailcap it can be some fins to help the heatpipes.
YesâŚitâs an interesting optic. But Iâm yet to see a light with good throw (per size) and this type of optic.
Even if it canât compete with collar, it still may be a great option.
The way I understand is:
Before the main lens, precollimator narrows the beam significantly. After the main lens it becomes wider.
Thatâs in focus mode.
In flood mode, the narrowing means that light hits only a small part of the main lens, creating a narrower beam. I actually did some basic ray tracing of this and thatâs where it made the beam narrower than blocking the light directly (with collar) would.
I guess you mean a custom collar made from glass and custom coating tuned to reflect the desired frequency, right?
A regular aluminium reflector already reflects ~90% of light. May lose some more by being less smooth. But the price in volume shouldnât be a problem.
Being tuned to the light will help recoup some of the loss. If it captures more light than the stock collar would, itâs likely to be a win.
Thanks for the suggestion. Iâll look into it.
BTW, Enderman, do you have an idea how much would a top-notch collar cost in volume?
isnât it just a reflector with a very large hole and a specific wider curve?
I donât see why such thing would be very much more expensive then a reflector
OK, did some tweaks:
- added a switch
- added threads for battery insertion
- enlarged zooming threads a bit
- switched lens to 40 mm EFL one. This is a big change. It freed a lot of space all over the light.
Not done: I should redo the collars as now one blocks the other. This would lead to redoing the head. Outside dimensions wouldnât change much, so I skipped this step for now.
A note about collars vs. other techniques:
Collar is the only optics that actually improves beam intensity over a simple lens. Otherwise, to get the same effect you would have to increase lens diameter. The zoomie above has a 50 mm lens and does 400+ kcd with SST-40. If it was collarless weâd have to scale it up to 70 mm to achieve the same effect. Body length would increase by nearly 20 mm as well.
I havenât found any 14500 or smaller flashlight that can do 250m throw for 4h on max like my P5r.2 can do.
If you put a more powerful LED in it you can probably get 500+m throw out of that tiny thing
Itâs not really a beam until it exits the light, the precollimator just reduces the output angle from the LED.
The spot created by the flashlight will always be larger when using a precollimator.
It collects more lumens, and makes the spot larger, essentially leaving the same intensity.
There are other things such as glass transmission and surface quality that will affect the performance though, so you can probably expect less lux when using a precollimator.
Adding a precollimator essentially reduces the focal length of the dual-lens system (this can be mathematically calculated), and as you probably already know a shorter focal length will mean more lumens collected and a bigger spot.
Itâs called a cold mirror, and they typically reflect 99% of light in the visible range.
Some people were discussing in PMs about getting some aluminum ones machined.
A typical aluminum reflector like you see in flashlights is 75% reflective, not 90%.
If you want to get 90% you will need an electroformed reflector, which is also expensive, especially since nobody produces them at the size that would work for a collar (yes iâve checked).
A custom job will cost several thousand dollars because they need to produce a mandrel for it.
No idea, it would depend on what manufacturer you go to, and how many you want produced.
A single one will cost about $1k.
Thanks, I need to get some basic optical design knowledgeâŚ
Where did you get this number?
