Will have to check fischju, I did not notice much different ,but I was not paying attention tbh. When I was using it last night, my uses were all pretty short and it never got hot, just warm. I would expect up to a couple of mins (depending on ambient temp) at max output. After a few uses at 100, I dialed it down quite a bit and was more than sufficient with no heat issues. TK made a great point (might have been the D4 thread). Where as with the D4 or other floody lights, you don’t need to ramp these up anywhere near to see more due to the reflector over optics. So where other lights I need it ramped up(D4 or other optic types), this for most of my uses is set lower if makes sense. But damn that double click to 100, that is very addictive!
I don’t know when the D1S will be available or exactly what the price will be, but I’ve heard rumors that it could be this week (because Neal already has some, I think) and that the price may be either the same as the D1 or slightly higher. I haven’t heard anything official though. It’s just speculation, as far as I can tell.
Yes, I am use to double click for turbo, many of my lights have it. However for me, the size and how the switch just sits at my thumb waiting to be pressed……makes it easier than normal for me! The UI is a master piece …………simple to operate yet rich in features……genius Guess I am trying to say, the D1 and D4 make it almost impossible to use without at least one double click
From their China site. I believe Hank will list them on their site by this week. Price is the same as D4 and D1!!! Available in grey and black colors, and 3 tint options like what other members have mentioned.
Considering TK says her throw number could be low it’s a safe bet it beats the P30. Against the UT02 will probably want to compare beamshots and everything since it’s a different emitter and battery so not really a 1:1 comparison.
My lux measurements always seem a bit low compared to everyone else’s. Also, my D1S has a slightly off-center emitter that I haven’t fixed yet, and it might cause a small drop in lux. I think the official spec is 130 kcd.
If you want a tight fit (clip won’t spin), the washer thickness may vary from light to light. You may need to file down a washer, or select a piece of wire, on a per-light basis to make it fit well. In general though, it should be somewhere between 1.0 mm and 0.5 mm.
