The lowest output is about 2 Lumens with either chemistry. As near as I can tell the only difference is in the brightest turbo setting. Where 14500 gains the full ~750 OTF. On an eneloop the brightest turbo is around 375 OTF.
IIRC these lights have a low voltage protection… so you can’t run dead alkalines (or any battery for that matter) completely dead. Someone please correct me though.
The light does have lvp but it’s not voltage based alone as it will run fine from 2.5v-3.2v without problem as long as the battery can provide the power. If the voltage sags too much and fails to deliver the expected current the driver shuts off.
Re problems: reviewing back through the thread does not confirm wether or not the problems are switch related. The problems are all related to using the switch and in some cases changing the switch solved the problems. But there has not been enough reports to indicate what is the status after changing the switch to confirm for certain that it is the switch.
One theory I have is that the problem may be related to how the driver handles reading denouncing of the switch. Different switches have different response images even with the same switch model so if the driver is not calibrated to a wide enough variance there may be problems even if the switch isn’t technically faulty. If this is the case, changing the switch may help or it may not
Well, light #3 has arrived this morning and this one is misbehaving. Fortunately I have the two good ones to compare to, and I may have learned something.
The drivers on these lights have two solder points showing on the battery+ side. On the two good lights, the solder points are precisely horizontally perpendicular compared to the external ‘flat’ on the head housing that the switch is installed in. On the third (misbehaving) light, the solder points are slightly off the perpendicular, being rotated a few degrees clockwise.
Now this third light does work, sort of. I did manage to get it through the programming cycle, and that seems to have remained in the drivers memory - but it’s sometimes reluctant to come on, and reluctant to shut off. Sometimes it gets to ‘low’, one level above moonlight, and then stay there. It’s definitely not working perfectly.
I’m wondering if others might check the alignment of the solder points on their drivers. It could be that the drivers need to be exactly perpendicular to the switch aperture to function properly. Unfortunately I cant seem to rotate the driver - there are no pinholes to twist by, and I can’t tell if it’s glued in or not.
thats interesting…
on both of my lights the solder points are all squared up and parallel with the flat of the switch.
My driver boards are also loose fitting and not firmly attached. I can rotate them a little and when I touch them there is some rattle. So the battery tube needs to be tight and secure… FWIW. I think its always been this way, I never paid much attention though.
Yeah its lowest program mode is brighter with a 14500, although in person its not as pronounced as my pics above make it appear. I really don’t believe its 10 Lumens.
I have a Ssurefire E2L Outdoorsman, its low mode is rated 3 Lumens otf.
On a ceiling bounce comparison the E11/UT01 14500 program-low is visually about half as bright as the SF.
the E11 you see in the pics above is a neutral white, but its by far the warmest “Neutral” tint I have ever seen. Not a bad thing mind you.
I did some testing on this driver today. The switch is definitely part of the problem but I believe the heart of it is the way the firmware/driver reacts to different switch characteristics. Specifically, high resistance switches without a good clean click will cause the light to malfunction. So this is why some lights will not function with the switch off center but do when the switch is rotated to center. The user is able to click the switch more cleanly and the driver is happier this way. I was able to eliminate the problem entirely using certain switches with a definitive “click”. Swapping switches back and forth, I was able to repeat the results. So this seems to be the case in my light atleast.
Thanks for sharing your observations and conclusions, LightRider.
I suspect that the problem with my light is somehow related to the MCU. I’d wondered about an issue with debouncing, but didn’t really know how to diagnose more fully. Or something to do with the power supply and management for the MCU.
In my case, the switch is well centered. Still waiting to see what Gearbest is going to do about a replacement before I try anything intrusive.
I think most people are using unprotected 14500 cells in UT01 because the protected ones don’t fit (easily).
An unprotected cell such as Sanyo UR14500P (second from left in the below photo) is about the same length or maybe very slightly shorter than an Eneloop AA.
I just received a new one today at the $9.99 price and it looks good. Works on alkaline and 14500 no issue. No odd behavior. I had to add a magnet to a Sanyo UR14500P though - but that’s not something new regarding battery length sensitivity.
I had repaired 2 UT01 switches with one from Mouser, they worked with new switch again,
The original switch is not reliable, sometimes it works when pushed in different angle, but normal operation is not really possible when the switch develops a problem
For 14500 I advise adding a solder blob or brass button on top of the battery
If you are able to reflow things with hot air its a 15minutes repair
