Heh, yeah, I have a video on my youtube page that shows me “smoking” paper with it in seconds. So, yes, it will literally smoke stuff!
Yes, lithium-ion powered lights aren’t for everyone. Luckily, this light uses them in parallel and has low-voltage protection for safety. But, good 18650’s can be hard to get at times. It’s not as easy as loading cheap alkaleaks into a dollar-store light and throwing them away when they’re done.
For people that have never used rechargeable batteries, I’d probably start out with something fail-safe, like Eneloops. You’re limited to about a thousand lumens on a 4xAA light, which is still pretty good for anyone that’s only ever used maglites.
Yeah, nothing in the docs about how to do it, but the last paragraph says “Switch Indicator LED - TBD…”, so I was hoping there might be a secret command…
Go into battery-check mode, by doing 3 quick clicks while the light is off.
Do a click&hold, then release.
The light will blink twice rapidly, then blink once.
Click once (before the light starts blinking the next configuration setting).
Wait a few seconds, the light should blink 4 times.
Done.
Or, what I prefer to do, it just disable it temporarily:
From off, press and hold the switch to start ramping up the light.
Then, let go of the switch, and quickly click it again.
The light will turn off, and the switch LED will remain off.
It will come on again the next time you use the light.
I got 4 batteries from illumn at the same time, but they came in pairs and are the same part number. Is it ok to use these in the Q8 even though they came in pairs and not 4 in one box?
Just to know the Q8 works with 1, 2, 3 or 4 batteries. So, if you run it on one battery, is it still going to give you the same lumens in all modes and divided by 4 for how long it will run in each mode compared to using 4 batteries?
I’ve used it with 1 battery. On a Samsung 30Q cell, it will give about 50% output compared to using 4 cells. I also tried an old laptop-pull cell (low drain), and it gave about 40% output for a couple of minutes, before stepping down to about 20%.
I think most of the drop in output is due to the large voltage sag you get when trying to pull all those amps from a single cell. I was a little surprised a single 30Q cell (which is supposed to be rated at 15 amps) only gave 50% brightness. I guess the voltage sag is more than I expected.
Thought there would be quite a power loss. I only have protected batteries at the moment, so I'll always use 4 of them. I have the stronger protected keeppowers for the Q8, but I wonder how the regular NCR1860B would fair in that flashlight? I have four of them as well I could use for backup if need be.
I think the NCR18650B should be fine, if you’re using all 4 cells. It would only be using about 4 amps per cell, at most. You’ll probably lose a few hundred lumens at max brightness, compared to high-drain cells, but that wouldn’t even be noticeable.
