I think that should work. It looks like anything up to 67mm is probably okay.
Not sure that I can call the D1S “peak flashlight”, but it is unusually throwy for its size. You could also make it throw even more by putting in an Oslon Black Flat or dedomed XP-G2, if you don’t mind a smaller hotspot. Getting it focused properly may be a bit tricky too, because these things usually are.
When I take one with me, it’s usually the D4 or D1, or both, because their smaller size makes them more convenient. The D1S can fit in my purse too, though it’s a bit large to have in there all the time. But when I’m not concerned about convenience at all, I’ll probably use a BLF GT. That’s a lot closer to what I’d consider “peak flashlight”, considering that the whole point of it is to “turn it up to eleven”.
Got to thinking about the beam profile and output of the SST-40 in the D1, I changed out the emitters in my Q8 this afternoon as one of the XP-L2’s was damaged, so I used one of the 3 remaining XP-L2 V6 1C emitters in the D1 and it’s making 2387.4 lumens from a freshly charged Sanyo 20700A. Serious little monster it is!
What’s the maximum current draw of any configuration of this or the D1 or D1s? I’m guessing a 4 LED will draw more current than the XPL? So far I’ve seen that the D1S tops out at 6A with the XPL I haven’t seen anything on the 4 up configuration.
Actually, given DBCustoms’ comment about 12 Amps or more possible, What I really want to know is what’s the best 18650 to use in these beasts. The 3 best ones in HKJ’s review do fine at 10A but don’t like 15 A at all.
Quad’s can run up to 12A or more, where a single emitter isn’t usually so high. The new emitters are breaking new ground though, with the SST-40 capable of well over 9A and the XP-L2 also up there towards 10, surprising really.
The highest current draw I’ve seen to date in a flashlight is a triple XHP-70.2 I built, pulling 32.2A from 2 iJoy 21700’s.
Thanks! I edited the OP before I saw your reply. What do you think the best 18650 battery for these D series is given that the top 3 in HKJ’s review could handle 10 A but wouldn’t survive 15?
There are quite different current draws between the D4 (reports of up to 20A) and D1/D1S (6A). I would assume that the usual suspects 30Q/VTC6/VTC5A would be cream of the crop in the D4. Given the lower current requirements in the D1/D1S I would expect that performance with Sanyo GAs wouldn’t be too far behind the higher drain batteries. However this is purely theoretical - I’m sure others can chime in!
