thatās a nice aluminium case! i like it
Good mod by the way
Thanks! This one will be fixed to a printing press. Often clear coatings must be applied to the labels which is difficult for the press operators to see and register to the images. A small amount of optical brightener is added to the coatings formulation (usually less than 0.5%) allowing it to glow when viewed under UV. This lamp will be an upgrade over the fluorescent blacklight lamps that weāve used in past. Those tube lamps donāt produce enough UV to make some colors of optical brighteners to fluoresce.
Thanks, sureā¦ Hereās the Amazon link.
The bandpass filter would be a nice addition. I looked at filters briefly a few weeks ago, but wasnāt able to find one with the correct dimensions or one that wasnāt outrageously expensive. Maybe thereās a ZWB2 film that can be applied to the glass window? I havenāt looked into that yet.
If this lamp does works well, Iāll have to assemble several more. Next time I can mix it up with the SST-10 LEDās and do a comparison. Iāve been wanting to play with the Luminus UV emitters since they starting releasing these less expensive variants.
Can you link the Luminos Emitter?
ZWB2 filters should be cheap availiable in rectangular sheets
Im home alone tonight so I decided to mod my H03 side LED because dont like red colour as itās not efficient.
Blue colour
Green colour
white colour without rubber boot
i also made AA vampire light from plumbing parts fits perfectly (just plug and play)
The light can run on dead AA bateries people throw in the bin and it will run about 2 weeks continuously
Forward clickie fit in perfectly.
no machining is needed
Plug and play. Your either a genius or an idiot. Hows the water leak?
Hey MDsDNF
Itās not water proof and I donāt intend to put in water rather use it as night lamp to drain dead AA batteries.
Although I can silicon seal the gap and put O rings but too much hassle
Sorry, I meant the water leak where there is now a hole in the wall where the tap was. . Just me being silly.
Here is the head MRsDNF
Had a spare XP-L 3D from the Astrolux S1 and decided to swap it to the Lumintop Tool AA.
Hereās the ceiling shot of Eagletac D25a Ti CW and Tool AA with XP-L 3D. Sorry about the cell phone photo as it does not capture the true color.
Good tip Firelight2. Iāve noticed with some of my bypasses that the solder has worn and has flat spots, but not too much to be concerned. If anything, the flat spots seem to help with conductivity. But I suppose at some point, the solder will eventually wear away too much, and then it will start to wear against the bypass wire or the spring.
Made my first attempt at āDe-Anodizingā a light.
I turned my black anodized A6 , into a shiny , black āhighlightedā A6.
Nice, diggin' the black & metal.
I reworked the Olight TC-10 Ti spare battery case again today. It's been a few different versions, MT-G2, XM-L2
Now it is XP-L2 HD V4 3C 5000K 80CRI.
I filed out the tube to take a 16340 cell and enlarged the bezel hole for a reflector. I used a pill module from an OTR M3 with lighted switch this time, 2000k resistor feed for the green electronic switch LED. Still turns red when the LVP warning kicks in.
DTP 20mm KD MCPCB, magnetic tail with copper and lockout function. Around 730lm on turbo.
Made my first 3D printed lens cap. I want to make for every flashlight of mine above 35mm head diameter.
First I made one for my Emisar D1 because it is small and I not wasting too much filament with setups. I made 4 rings of the top 3mm to test fitment and then made the final product.
I think I will try to make diffuser for my Q8 but I need to use it with low power not to melt it.
Pretty dang cool Zozz! Like it! Does the name show up in a beam profile if you sine it close?
Yesterday afternoon I tinkered with my Q8.
Made some changes to the light to allow the use of 4 20mm SinkPAD mcpcbs and on these I re-flowed 4 Luminus SST-40ās. With 4 x 22ga ground leads and a single 18ga positive, the light makes 11,247 lumens at maximum, on 4 Sony VTC5Aās with copper button tops. Was quite a bit of fine tuning, including opening up the emitter opening in the 4 reflector cups. Lowest mode is just under 5 lumens, so it works pretty good for my purpose. I have TKās latest Anduril with flickering candlelight and lightning displays. Gotta tell ya, lightning bursts from this power level are very impressive!
Through a paper yes but with pointing the light to something no. Even from 1cm it shows full green spot. Maybe if I made big difference in thickness of the letters and the area around them.
Now I made one for the BLF Q8 too.
It making the tint so so warm. I will design a diffuser to it.
Oh now thatās nice!
Itād be really sweet on my Dadās virtually stock Q8 (birthday present next week) but my own Iād have to be super careful not to melt it.
Very very cool, great work!
Edit: That warming of the tint would be Awesome with TKās candlelight mode in Anduril. Might have to see if someone can make me one, the candlelight flickering alone is worth the effort I think.
Thank you!
I made a sample so now I can make any size in about a few minutes and then print.
Would it be feasible to send one to Texas? :heart_eyes: (or 3?)
