11) If your flashlight gets hot, that's good. It means that your torch is putting out a LOT of light, and that the heat that said light creates is being dissipated through the body of the light. However, if only the lense is getting very hot, you may be destined for trouble. Look into better heat sinking, or at some point you will fry something in the pill.
12) The Pill means the internals of the light that include the emitter, the driver (electronics) and the stuff that keeps them together.
13) XR-E's, XP-G's, and XM-L's. Three generations of Cree emitters. XR-E's usually require less power, and inherently have tighter hotspots but dimmer spill. XM-L's emit more light than the others, can be driven harder than the others, but in P-60 use tend to be more floody than throwy. XP-G's are a nice compromise between the two, at least when it comes to throw vs. flood. But this is a very simplistic and general comparison. In specific hosts, there are distinct advantages to any/all of the three emitter types, and there are variations within the three groups that determine tint as well.
