So they raise the price from $68 to $78 because they are not making any money then they sell them for $64 after I have already bought three. This crap pisses me off.
A lot products are selling way below cost price for marketing purpose. All 10pcs were snap up at a instance, this showed that buyer appreciate its value greatly.
Does anybody know of any good holsters that would fit this light? I bought a holster that was meant for a Manker M34? Not sure, but anayway, my astrolux MF-01 does not fit in it, itās tiny bit small for the astrolux. Iāve been searching online all over, but I cannot seem to find a holster would fit this light. It would really be helpful if astrolux would include, or recommend a holster for this light.
Change point in V2.(left is V1,right is V2)
Illumination will not turn red at TURBObeam.
The color of the spring is different&double.(My stuff is Phillips head screwsā¦)
The endcap is black.
The tube logo is unchanged.
Changes in wiring are visible.(Driver is also different.)
In TURBObeam V2 looks slightly darker even by visual inspection.
The color temperature is V2 is slightly lower.
Chrome(web browser) does not display color correctly.
I was able to confirm that imgur.com also changed color.
Therefore we will display from Yahoo!.
Camera settings, battery (Samsung INR18650-30Q 3000mAh), battery holder are using the same thing.
Of course it will be a comparison after charging.(left is V1,right is V2)
CONTROL
TURBO
HI
MID
LOW
MOON
Like Tally-ho,Iām a disappointed is 219C V2 :cry:
I do not know whether it is dispersion of 219C or ASTROLUX change.
However,S42(219C) also has dispersion.
Russian roulette 219C?
Since I want to purchase again, can I have a freeme code?
Got my second MF-01 today. It is v2. The tint is a little less pink, more yellowish compared to v1, though the difference is really small, I canāt see it on photos.
Donāt have an integrating sphere but my impromptu meter (luxmeter in Xperia Z3 Compact + ceiling bounce) showed (med1 / / med2 / / high/high after stepdown / / turbo) 43 / / 82 / / 201/120 / / 625 lux. On nearly drained battery it was 26 / / 64 / / 181 / / 420.
12cm fan with 9V placed close to light was enough to keep it on turbo without much reduction in brightness: The brightness during discharging: Imgur: The magic of the Internet (in a slightly different place, so the lux values are slightly lower). The batteries werenāt fully charged, I have realized it after starting testā¦ I will repeat it after with 4,20V 30Qs
I donāt exactly know if the overdischarge protection works well - after inserting nearly depleted batteries (3,05V without load) breathing light started on green, only after turning on suddenly dropped to blinkling red. And still was able to get 2/3 of total turbo output, so the voltage on load should drop below 5,8Vā¦ unfortunately canāt measure exact voltage on load. But it should be ~0.5V drop at leastā¦
