a good water “resistant” to rain and splashing is easily possible, but make this “waterproof” as to an IPX standard will drive costs up not completely necessary to have it reach an IPX7 or 8 level.
Because the lantern will be of a lower amps draw/load, maybe even four fusible links between the four negative traces on the bottom cap PCB is possible? ( 5 or 10 amp flat SMD fuses are cheap, and if one cell manages to contact then the fuse for that leg can blow to open the short.
I do like this plastic riser to prevent reversed cells from contacting though, especially if one cell gets inverted accidentally at night. >> Q8 modding - #1202 by 5ar
Definitely agree with keeping the default modes simple!
Also while I think USB charging is really important in a lantern, I don’t think the ability to act as a power bank is that important if increasing cost and complexity. Actual power banks with quick charge are so readily available, light and compact that probably most people take one tramping, letalone car camping.
At the moment it’s mostly DEL doing all the work, designing a circuit which will handle light and USB in a SRK-style form factor. It may well be the hardest part of this project.
Physical host design seems like it’ll be a fair amount of work too, due to the USB port(s) and all the lantern-style adjustments to the head.
Since I’m doing firmware, I’ve got the easy job… all I have to do is port my FSM toolkit to the new driver and tweak the calibration and settings. Most of the work there was done months ago.
I am working on doing a modification to the prototype to make the head of the lantern more stronger, (using a center bolt to hold the head & globe/shade together) but testing with two LEDs. Also will revise the drawing design to show the change that works with o-rings. Also adding tripod mounts to the bottom as some mentioned that would be as good option, (for lighting up a campsite or back yard are on a tripod.
If the LED (s) will not be in the center, and instead a bolt will be there, I’d rather see three (or four) LEDs used, so the light doesn’t become bi-directional with shadow lines between the outputs of the two LEDs.
But you’re testing it, so I’ll trust you to come up with what works.
Pardon if I wasn’t able to check the earlier messages, but around how much would be the approximate price of this BLF lantern?
I’d be interested, depending on the price…
The specs have not been completely nailed down yet, so we don’t have a complete BOM yet, or a commitment from a manufacturer, so no final cost. The Q8 that this is hopefully going to be similar to had a group buy price of $40, “MSRP” of $80, and a coupon that brings it down to around $45-50 currently.
There are a lot of folks on the list under the heading “interested, depending on price”. Chances are good that it will be a great value though.
