Interesting! And very inexpensive.
I’m wondering if this is because in order for it to work properly, the driver would need a bleeder added.
Ordered 5pcs now
Yes, it’s because you need bleeder. Without bleeder biscotti driver goes to next modc memory (at least mine did).
You would have to experiment with bleeder values and tail resistor values to find a set that works for the biscotti driver without messing with the UI timings too much. I have not tried that for biscotti, I just know that the BLF-A6 driver works with all kinds of values and that the BLF X5/X6 driver is very choosy.
When doing mine, I’ve always just added the bleeder. I’ve never even tried without. Figured it would just take less time to add it rather than to monkey around and try without.
I have found right value long time ago
I just don’t remember it.
No need to change tail resistor values.
If someone needs I will post it when I get time to disassemble my lighted S2+
I always just drop in a 680 - 750 ohm resistor and haven’t ever run into any issues. But I usually only use the nanjg105c, BLF A6, and Mtn Fet+1. Then again, I also use PD’s Rev5.3 boards - not those with the LEDs down by the switch’s PCB. Those configs use significantly different resistors on the tailcap boards.
I checked and it’s 1k resistor on my biscotti driver.
If I remember correctly, lower didn’t work good.
Very nice find and a great price! I like that it also comes with an Omten switch. Too bad that it doesn’t have a double spring like the Astrolux switch, but doing a spring bypass isn’t too hard.
Cool find XXX-man.
Spring looks like its the same one used on the Convoy store 16mm Sw assemblies with Omten. Those springs are pretty stout for compression.
Anyone catch the LED color? I missed it if listed.
Washer is kinda different with the outer wall or recess. Great price for including washer and cap.
LED color isn’t listed, but I didn’t care
I believe it’s blue.
Washer is the same I got with my grey S2+
Got a “few” on the way. Thanks for the heads up on it.
This is my first try at this Mod and need lil help, i have the Rev5.1 version with the leds soldered onto the board with the resistors and leads, from PD first post he has a bottom board ? can someone tell me what board i need and for the bleeder resistor where do u guys buy them in different mixtures
While they can be more convenient, you don’t need a special bottom board. Just solder the leads from your top board onto your switch PCB.
You’ll need to identify the polarity of your switch board. Put your DMM in continuity check mode and make sure the switch is in the “off” position (no continuity when touching each side of the switch). Now put one lead on the spring and see which leg of the switch it goes to - this is the negative leg of your switch. Solder the negative lead from your LED board to that leg of the switch, then hook up the positive lead.
As far as bleeder resistors, I just bought a just pack of SMD resistors (from ebay? banggood?). For most of my setups, a 680 or 750 ohm bleeder has worked out just fine. Regarding placement of the bleeder, just let us know what driver you’re using and we’ll take a stab at where to put it. It needs to go from positive to ground, but that varies from driver to driver.
Thank u for the reply, im using a DD MTNElectronics driver in a convoy C8 and Eagle eye x6 hosts,once i do a few i might ass one to my L6
Here’s what I do (see bleeder at left-center). Spring side, scrape a little solder mask off of the grounding area that comes toward the center of the board. Solder the bleeder from the base of the spring to the area of the scraped-away solder mask.
Thanks I’ll be finding a pack of different bleeding resistors
Can anyone give me some tips lol I bought this tailcap mod with the LEDs soldered to the board and my switch is working to turn the light on in high mode only but the LEDs are not lightning up
Is there anyway to test the board to see if the LEDs are at least working ?
Yup, hook up a battery (li-ion) to it. Mind your polarity
Tailcop mod cant work without a bleeder from batt+ to flaslight body
