I think this thread is best used for generic discussions about future projects. It will be a whole lot easier to keep track of your new design if you create a dedicated thread for it. That way, none of your early design notes will get lost in this thread.
Good suggestion, thanks.
Continued here:
My only real desire for a future BLF-light is too underwhelming to gain enough traction, I mentioned it once, and here again, one can hope :innocent: :
a 3 xNiMhAA-in-series light (batteries side-by-side) with common lineair driver like the BLF-A6 FET+1 driver or a Narsil driver. Short, tube-style with a quad (to keep the length as short as possible) low voltage led (Luxeon V is the current lowest voltage led that fits a Carclo quad, that should be a great choice) . The dimensions should be as low as L=80mm, D=34mm, which is very significantly lower than any 4xAA lights out there. The output will be very efficient and over 1500 lumen for most of the runtime. At around 4A current draw the light does not need a stepdown to prevent self-destruction, it can be handy though to keep the temperature low enough to hold.
So extremely safe, high efficient output, great small size, and it takes the most common alkaline battery in the world as backup,
I personally think this is an excellent idea. :sunglasses: I was pleasantly surprised to see in HKJ’s review that you can actually shove 10A through an Eneloop. A compact light that pushes the capabilities of NiMH is certainly interesting in my opinion.
I’d buy that in a heartbeat.
Finding a nice and decently powerful light that is safer for my son and non-flashaholics would be very welcome.
Same here, I might buy 4 or 5. There are a whole bunch of use cases where NiMH is a better choice.
I think it is a great idea too, and would be a multiple buyer, depending on price.
:+1:
Still some interest in a 3xAA light. It is also interesting because the overhead voltage between a modern low voltage led and 3xNiMh-in-series is close to ideal again for lineair drivers (7135 based) or even FET-drivers: good efficiency and still good runtime in regulation.
I did a test holding a 3xAA carrier with switch (phosfor-bronze springs) against the head of my LuxeonV-modded D4. The Eneloops were not quite full but it gave me a steady 1250 lumen for the 10 seconds that I managed to keep the parts in place in the entrance hole of the sphere.
It would be an ideal high performance light for people who aren’t necessarily flashaholics.
I want the long version of that very light, with the three AAs placed nose-to-tail. I know it would be about 200mm / 8 inches long, but I like long lights
Of course the various 4xAA lights out there fill that niche as well (D40A, EA41), the merit of this one is that it is exceptionally thin and short.
@Phlogiston: 3xAA in a tube would work just as well (even a bit better because the resistance in between the batteries is virtually zero), that is of course a matter of preference, I like stubby lights, you like long and thin.
But this one would be less expensive than either of those I imagine.
> Three AAs nose to tail
You can do this by combining tubes from a SK68 clone and a “3W Police” flashlight (see the lego thread)
I’ve still got a Brinkmann 3AA tube light in the “do something with this someday” bin.
Google finds a lot of other 3AA flashlights (limiting search with /Tools/verbatim, and then choosing /Images)
I’d like to see a djozz-inspired 3AA BLF light myself.
Now this is weird. Two emitters, one spot and one flood — and an infrared beam to decide how far away the subject is to balance power to the emitters.
What will they think of next?
(I’m waiting for the flashlight design where you click the button and the light head extends little propellers and flies over to hover and illuminate your target, while you control it from the battery tube)
I don’t know if it has been mentioned before. But I would love to see a BLF head lamp.
I would too if only I’m not allowed to wear a headlamp at the risk of divorce
It just might be impossible to make those things look cool. :person_facepalming:
Super handy though. I love my Zebralight headlamp.
Heck yea!! i’ll take 3 or 4 of those 3xAA lights…maybe mor, make great gifts too.
I’m not sure it would be cheap, I can imagine it being 30 dollar, structurally it is not unlike the Q8, 4 high power leds, and a battery tube for 3 cells (bored out for 3 cells with a rotating tailboard, my preference, or with battery carrier). One advantage: with 1A per led a DTP board is not needed.
