Emisar D1 / D1S review
576 posts / 0 new
Thetasigma
I think the slight aesthetic oddity of the D1S is mostly the short length of the host relative to its head diameter.
For those who received their D1S in the US already, did your tracking give updates? Mine hasn’t updated since the first processed through notification.
Spud
Last seen: 1 month 1 week ago
Ordered mine from Intl Outdoors on the 15th in Aus, hoping for a tracking number as parcel theft is a major issue around my area.
Havenot been this exited for a light in a while, should be good after my Klarus shat the bed.
$88 Aud plus cost of cells in this country, still cheaper than some of my others for the output.
Rob_K
Mine got stolen together with one 18350 Sad
Says DELIVERED at/in mailbox but it wasnt there when i came from work
gehrmo
Yeah but mine had to go 65km further.
freeme
freeme's picture
Last seen: 1 hour 35 min ago
Has anyone measured its throw distance yet?
edit: 703m according to TK.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
yuhsin91123
Last seen: 4 days 5 hours ago
I have a D4 XPL HI 1A and a XPL HI 3A on the way here… debating if I want a D1 or not… Can someone post a few good outdoor beamshots of D1?
ledalex
ledalex's picture
Here are some outdoor beam shots from the D1S including a comparison shot from the Convoy L6. Very impressive:
https://imgur.com/a/8fNoI
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 8 sec ago
Hah, the money shot is at the bottom… Emisar D1S on the left, Convoy L6 on the right:
Both are a long way from the “Giggles” thrower, but it’s pretty good for something which can fit in a coat pocket.
stephenk
stephenk's picture
Last seen: 2 hours 30 min ago
A whole extra day from Brisbane to Bribie! Wink
Haven’t had too much time to play with the D1S, but I’m very impressed with the heat handling. Hotspot is around double the brightness of my Convoy C8. Will post a mini-review when I get the time.
Deputy Dog
Deputy Dog's picture
ToyKeeper
Wow, those beam shots remind me of the difference between my Olight M3XS-UT and my L6. It will be interesting to compare the D1s to the Olight when it arrives.
Bob_McBob
Last seen: 14 min 31 sec ago
I am really eager to see a full runtime for the D1S.
Geuzzz
Geuzzz's picture
Last seen: 8 hours 38 min ago
D1s is nice, but the Olight will blast it away. About 100kcd between them.
Deputy Dog
Geuzzz
Well at 4X the price it should, but… it will be fun to compare. Cool
-X3-
-X3-'s picture
Last seen: 14 hours 47 min ago
Not the same category at all though…
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
stephenk
stephenk's picture
Stingray wrote:
Are FET drivers simply adjusting to the maximum battery’s output? If let’s say a 18650 is limited to 6A, does it simply adapt to that value and follow the sag until cut off?
Pretty much, yes. A lesser rated battery will result in less output, though it’s a bit more complex than that.
Hikelite
Last seen: 7 months 5 days ago
Stingray wrote:
Ok, let’s say I use a low drain battery and swap the XPL-HI with a lower forward voltage bin (xpg or 219c) is it going to work fine?
Does battery protection just prevent over charging and under discharge, or it affect also the max current out?
XP-G2 does not have a lower vF than XP-L HI.
Battery protection directly affects current to the point it can trip over-current protection, varies on how it was manufactured/designed.
Do protected cells even fit in these flashlights?
DB Custom
DB Custom's picture
Last seen: 1 week 18 hours ago
The FET essentially allows for direct drive, so as the cell dies the output drops. It’s not about the FET itself, it’s about the capability of the cell.
Yes, the 219C will have a lower Vf and allow for more current draw from the cell used, it will also increase heat and lower run time. The XP-L2 emitters are also low forward voltage and produce much more light out the front.
ToyKeeper
ToyKeeper's picture
To answer Stingray’s questions…
Protected cells generally don’t fit in the Emisar lights.
FET-based drivers are essentially direct-drive, so the output on turbo depends on where the battery’s voltage sag curve meets the emitter’s Vf curve. The battery may be at 4.2V, but that value drops as amperage goes up, and it drops as remaining energy goes down. The emitter’s voltage starts at around 3V, but it rises with amps and temperature. Where the two curves meet is what happens in direct drive.
A low-amp cell sags more than a high-amp cell, so the curves will meet at a lower amount of current, and emit less light.
Lower Vf is not always a good thing. In particular, it is strongly recommended that you do not use a 219c emitter with a FET-based driver. The curves meet at such a high amperage that it kills the emitter. This can be avoided by using a very saggy low-current cell, but then it’s typically somewhat bad for the battery instead. It can also be avoided by using several 219c emitters per cell, but even then it has been known to turn emitters into smoke.
The bad-for-the-emitter vs bad-for-the-battery thing is similar to going down a mountain in a car. Riding the brakes wears out the brakes quickly, but generating resistance by putting the engine into a lower gear is hard on the engine. The brakes here are analogous to the LED, while the engine’s gearing is analogous to battery choice. The difference between battery voltage and emitter voltage is the slope of the hill. Does that make sense at all?
I haven’t tried it, but one potential option for safely running a 219c direct drive would be to use a LiFePO4 cell. Instead of going from 4.2V to 2.8V, those are more like 3.6V to 2.8V. It might work well for low-Vf emitters without having to worry about damaging the LED or battery.
Bob_McBob
I received my D1S today and used it for a hike this evening. First impressions are quite positive: tons of throw, lightweight and compact (but a large head), and the price is certainly right at $40 or less. The ano is very rough compared to the D1 and had rubbed off in a couple of spots. I like the tint of the 4000K emitter, which goes nicely with my Wizard Pro warm for night hikes. Time will tell whether it can convince me to give up the flat regulation and longer battery life of the Manker U21, which is now slated for an emitter swap for sure.
Note: when I received the light, the thermal limit was set to an internal temperature of something like 40°C, which translates to about 30°C at the head. That meant the light throttled down almost immediately on turbo and was at practically moonlight output by 10 minutes trying to maintain such a low temperature. I used the thermal config to set the limit to 71°C (~60°C at the head), which is pretty toasty but largely eliminates throttling. In the winter it will never actually get anywhere near that hot when used outside anyway. Here’s a quick plot of the head temperature at the original setting with a shift back to turbo at 10 minutes.
ToyKeeper
ToyKeeper's picture
Interesting. The default sounds like it was too low, but that’s why it’s configurable. In my testing, the default didn’t really try to reduce the temperature at all. I think this is mostly just random variation in the MCU’s internal sensor, which isn’t calibrated. I get very different temperature readings from one attiny to the next, in identical environmental conditions.
aginthelaw
aginthelaw's picture
Last seen: 2 days 3 hours ago
Anyone know how to contact Neal? I haven’t received my D1s ordered November 5th, or received any notifications. My emails have gone unanswered.
never fear shadows…it means a light shines nearby
xCentrino
xCentrino's picture
Last seen: 2 years 5 months ago
Same boat, But haven’t tried emailing yet, Was going to give until end of week Flat Stare
Gr8Swammee
Last seen: 1 day 11 hours ago
I just pasted the body of the email confirmation to a message on BLF and he shot me the tracking info within a day
Coscar
Coscar's picture
Last seen: 1 hour 22 min ago
I ordered the 4th and did not receive any updates until I sent him an email via reply to the original order confirmation email. He replied immediately with tracking info but that has not been updated since …………
November 12, 2017, 11:42 am
Processed Through Facility
GUANGZHOU EMS, CHINA
Your item has been processed through a facility in GUANGZHOU EMS, CHINA at 11:42 am on November 12, 2017.
Origin Post is Preparing Shipment
November 9, 2017, 6:22 pm
Acceptance
CHINA
I was going to give it at least 3 weeks before getting restless
Im not a Pessimist …. just an Optimist with a lot of experience
A little John Prine
Gr8Swammee
Acceptance
CHINA
there was an 11 day gap of tracking being updated between leaving china and getting in to NYC, but then updates resumed until it was delivered, YMMV
Thetasigma
Well that some reassurance, 11 business days since the first and only tracking event…
Acceptance
CHINA
goshdogit
goshdogit's picture
Last seen: 1 hour 56 min ago
I captured some beamshots of the Emisar D1S and several other lights at three locations.
I wanted to compare the D1S and D1 to help others decide which to get, or to convince D1 owners to get a D1S as well. Big Smile
I also included the Emisar D4, EagleEye X6R, and Maxtoch Shooter 2X. The D4 is obviously the floodiest of the group, and the Shooter 2X the throwiest. My X6R with a TA driver performs almost exactly like a Kronos X6.
The D1 and D1S both have XP-L HI V2 3A 5000K emitters.
The D4 is an early model with the 219C 5000K ~80 CRI emitters, not the newer 90+ CRI ones.
The X6R has an XP-L HI V3 3B emitter.
The Shooter 2X has a factory-dedomed XM-L2 U4 1A emitter.
Above, from left to right: D1, D1S, Shooter 2X, X6R, D4
In all three locations, each light is mounted at waist height with the camera positioned directly above it.
Location one is a forest trail with the lights aimed straight ahead at the tree trunk in the center.
Location two is an open field with the lights aimed straight ahead at the evergreen tree in the center.
Location three is an open field with the lights aimed upward at the tree’s leaves to accentuate hotspots and reduce spill on the ground.
The trees in each location are 115 feet (35 meters) away.
Emisar D1S vs Emisar D1:
These smaller .GIFs comparing the D1S to other lights are clickable to view larger:
Emisar D1S vs EagleEye X6R:
Emisar D1S vs Maxtoch Shooter 2X:
Emisar D1S vs Emisar D4:
The original photos’ thumbnails are clickable to view larger. Here is a link to the imgur album.
Left to right: D1S, D1, X6R, Shooter 2X, D4
Back when my D1 arrived, I posted some comparison beamshots of the Emisar D1, EagleEye X6R, and Astrolux S3 (Kronos X5) in another thread.
EDIT: Added emitter information near the top. This info was previously only included in the photos.
-X3-
-X3-'s picture
Amazing shots, thank you !
Now I can’t wait to have my D1S !
Thetasigma
Great comparison shots, but you aren’t making this wait any easier!
Does the range increase correspond in poportion to the candela increase?
Coscar
Coscar's picture
Nice job goshdogit………. thanks man!
A little John Prine
