Quick battery question. Earlier this year I purchased six LG INR18650HG2’s (rated 20A but tested at 25A I think it was?) to replace all my aging batteries. Would it still be recommended to use the Samsung 30Q over these LG’s? Or am I fine until its time to replace these? I have three “good” flashlights, all three are BLF A6 driven, and two have XPL HI’s (mid 2016 C8’s) and the last is a BLF A6 (3D) with assumed XPL HD purchased earlier this month. All from BG.
Reason I ask:
Earlier this year I looked at bat reviews and could not distinguish any meaningful differences between these two brand/models of batteries, but went with the LG because it won in regard to better capacity at lower amps 5A/10A and I got 6 for only $36. So I decided not to buy the Samsungs at that time. But now I see the Samsung 30Q recommended here at BLF. Does that mean its better for the BLF A6 driven Flashlights over the LG’s? I’m not an e-cig smoker so maybe I should not have read that review… lol
Will I even notice a difference between these bats? Thanks
Both of those batteries are excellent and I own and use both and there very little difference. I typically go with 30qs when I have a situation when I need them in series because they are readily available in button top form. For single cell applications there is almost no difference.
By the way, does anyone know of a decent 17500 battery I could try? I have a AA flashlight that I want to mod with one of these drivers, but it actually has a 17mm x 100mm battery compartment so it would be perfect for two 17500 bats. Right now I use two eneloops in a 17mm OD tube. The flashlight has a 2012 XML or XML2, I cant remember, but the reflector and lens are of high quality and the driver of my own design. It also had spring bypass surgery. Thinking of a BLF A6 and XPL, but not sure any decent 17500’s exist…
Thankyou Lexel i did try one from my convoy C8 and found it did fit, but sort of bulged out the top. would prefer a better fit but will use the convoy ones if need be.
Rather than reading all 883 posts I wish to ask about a problem I have. The light was functioning quite well for maybe a month when all of a sudden I was no longer able to shut off the light via the tail button. I took off the tail and saw what looked like a small area of thread in the tail cap that seemed to be missing some anodyzation OR it had a very small piece of metal shaving debris now wedged firmly between some threads which I cannot get out. I cannot say if this is the cause of the light now not being able to be turned off normally or not.
If your A6 still has the original switch, the biggest problem you will have is changing it
You take out the one you have and put this one in its place
After the change it will work in the same way
The switch mounted on the FT set (Omten 1288) is of better quality than the original A6
The negative is that it comes with a only spring and the A6 has double
My A6 is immediately going into low voltage protection mode with a fully charged battery. I’ve tried a couple of Quality batteries (LGChem, Samsung Q30, Panasonic) and they are all the same, so i’ve ruled out a bad battery. I’ve also double checked the voltage of the batteries with a multi-meter and they are ~4.1v so near enough fully charged.
Tried removing the tail cap and directly shorting battery to the tube to turn it on. Still does it so it’s not the tail cap.
I considered replacing the driver, but can’t work out how to get the LED board out (is it call the STAR?)
It seems like a great flashlight and it was for about 2 weeks before it started shutting down constantly.
Any suggestions on how to solve the issue or how to disassemble the light?
Don’t want to throw out a near new flashlight
The only thing I can suggest is to make sure the driver retaining ring is tight, the spring in the head is not oxidized, and the body tube end is clean. But you’ve probably tried all that. Other than that, I can only think it’s something in the electronics. Unscrew the retaining ring and take out the driver and replace it?
It is a great budget light. My only complaint about it, which is the same complaint for almost every budget light, is that it is not regulated and dims as the battery voltage goes down. For me, that means that most FET-driven lights are really only good for the top 50% of a battery charge, essentially cutting my battery’s useful capacity in half.
But for $20 or $25, what can you expect? Personally, I’d just buy a new BLF A6 to replace it, but if you’re comfortable messing around with it, replacing the driver is a good bet to try.
It sounds like there’s some large source of resistance somewhere in the head end of the light, or between the head and the tube. As suggested, try cleaning and loosening/tightening everything.
On a different note, the first three modes don’t use the FET at all, so they don’t dim until the battery is almost empty. Anything over ~140 lm uses the FET though, at least partially, and will change brightness with battery voltage. Mode 4/7 only uses the FET a little, so it doesn’t dim very much. This means four of the seven modes keep pretty consistent brightness, and only the top three are really prone to sagging.
