Man did I have a brain fart last night lol . Now I understand why you guys thought it took a month and a half for me to get my light. I just seen that I said September instead of October. The light was shipped on the 28th of October so it was pretty fast shipping really.
I also wanted to say that the delay problem in the Ultrafire C3 SS might also be caused by the cap #C3 which I added the bleeder resistor to. As I was solving the memory issue with my light I had noticed that C3 had 2 caps in parallel. These caps were staying charged for quite some time after the light was off so I figured they would be responsible for memory function since they were connected to the input pin of the cpu and the light had to be off for a long period for memory to work so I removed one of the caps that were in parallel and tried the light and boy did it act stupid! Sometimes it would come right on and sometimes it had a delay at turn on and sometimes it would switch modes properly and other times it would just come on in one mode after a delay and wouldn't switch modes at all. The cap I removed was 10mfd out of circuit and the total capacitance of both caps while in circuit was 15mfd. So all you guys out there with a Stainless 93mm C3 with a red driver board that has the delay this might solve your problem. And without a doubt the 100k bleeder resistor across c3 will solve slow memory function!
My old (DX) C3 SS 93mm have also the red driver, but no problem with the memory. Remember the last mode used last only 1.5 to 2 seconds...may be a defect in this production run.
My rubber button is also shaved, although this has not solved the short delay in the On.
Is seen that all the flashlights bought in China are different. lol
Agenthex maybe it is pin 8 I really didn't look too closely at the board or the parts really and I didn't examine it in that much detail as there are so few components. Some component manufactures mark the first pin on there IC's and some mark the last pin on there IC's and I didn't look up a data sheet on the IC. I'm pretty sure the pin in question was the one that was marked and I just figured it was pin one but as I said I really didn't pay much attention. It only took me all of 5 minutes or less to decide what approach I was gonna take to try and fix the memory issue. The cap in question though is marked on the board as c3 and if you are veiwing the atmel chip the chip will be right side up and the cap is located to the bottom left pin of the atmel near the black wire. I have found out there are at least 2 red drivers being used and a black driver with "wy" printed on it but I think it is in the 98mm version. Here is a pic of the one in my light. Notice the trace in the top part of the red if your light don't have that it is different and so my instructions won't work.
Well I don't know how to upload a pic so if someone will tell me then maybe I can be of more help.
To insert a picture, click the "picture" icon next to the anchor icon in the post box/bar. It does need to be a url, so if it's on your hard drive only you need to upload it to some free image hosting service. If can't get it to work, no prob. Your description is decent.
Well I uploaded a pic to freeimagehosting.net and used all 6 of there different links to post the pic and none of them will work so here is a link to where i think the photo might be veiwable lol....http://www.freeimagehosting.net/image.php?7488e5e3e6.jpg
Right click on the actual image in the browser and choose something like "copiy image location". You're probably pasting in the html page url above instead :)
Agenthex I don't have that option in my right click menu. I really am not this stupid to figure out something so simple. When I uploaded the pic to that site it gave me the code to use but none of it worked so I don't know.
You can resize the image by going to the image posting dialog's advanced properties and using a smaller size (like 800x600).
And my driver looks the same as yours. Both my two irons are broken (missing tip on one, cable to station glitchy on other) so I won't be able to do anything until I get some parts for them.
Some of the red drivers don't have the circuit trace like yours and my light and I suspect that those are also the drives that burn up when using a 3.7 volt cell.
I'm sure you will have no problem locating the capacitor. But if you are in question about the cap location and are going to mod your light you can post the pics and I can point out the cap. I would be happy to do that! That will keep me from having to disassemble my light to take the pics.
Ey guys! wait a moment, I see that photo and the driver is the same than in the my TrustFire F20 which destroyed when a 14500 batt was used. Has the red trace...
Thanks Fran82 for pointing out that this style driver got fried. You probably saved my light. I only tested a 3.7v cell for a short time in my light (all I have right now is 18650's that will just fit in the head then I jumped the negative pole to the case with wire just to test it) and I had read that some ppl's were fried nearly instantly so I figured the other driver wasn't safe for a 3.7v cell. But it seems you never can tell with these chinese lights!
Thanks Vectrex for the link to the picture tutorial.
Ok took my light apart so I could take some pics of my mod to solve slow memory function.
First two pics is the location of the capacitor that needs to have a 100k resistor bridged across it.
Your light my only have one cap but mine had two stacked on top of one another. I guess the ran out of the one they needed so they used two.
Like I also said these caps just might be the fix for the delay at power on as well so maybe the additional cap was a factory mod to fix the delay....who knows?? All I know is my light never had a delay just took forever for the memory to kick in. But now it's perfect!!
Notice in the pic below the SMT Resistor I placed between the two capacitors. Also note my light came factory with the two caps. As stated before anything between 47k ohm and 200k ohm should work fine. I used a 100k and my memory is almost instant.
Thank you very much Agenthex! I have lots of practice! I love to build things with electronics so fixing up these budget lights is quite fun. I need to buy more so I can learn the circuits as I would like to be able to speed up the strobe mods on the lights with the slow stobe and slow SOS at least if the have to have those mods it would be nice for them to work like I think they should! My C3SS has super fast strobe and really fast SOS too which makes it more bearable lol.
Ey! Definetively that driver is the same than the one in the F20, which destroyed with 14500. Now I see both sides of the driver I can surely afirm that is the same
