It is a bit underwhelming what working on a bit light means for Vinh, bare LEDs with nothing to collect and at least give a mediocre 2candelas per lumen, and just using a couple of BLF direct driver 17mm PCBs hanging by the wires or insulated in kapton take inside the host.
All this hype has finally faded for me, it seems the throw of this thing will be quite small like under 500M. Maybe I will pass, after a while flood gets boring.
LEDâs are getting all about lumens & numbers, just add more & more, no wonder itâs cheap. If this thing had a 1600-2000M throw with considerable spill/flood I would be all over it. I remember the days of aircraft landing light mods like LK14 with their amazing wide far throwing beams. I had wished LEDâs would go in that direction just further.
I saw vinhâs 40000lumen video & its just like these videos of 50â light bars., too much close range light that is boring.
Still a crazy amount of light, i think this is the realm of enough for a hand held light. They need to work on massive throw.
How about gettin the X7R Marauder (12k lm) for 165 euros, which is 72.3 Lumens per euro?
which translates to 190$ , so thats 63 lm/ $
think it was a pretty good deal all in all, right?
About price per lumen
Recently many brands have broken the record
Like astrolux mf-01, which is about 12000 lumen/78$, which is about 153 lumen per dollars
Crazy, right
Exactly. You canât turn it on to the brightest level. You have to double click, pause, then double click again to get to turbo 2. Itâs like a safety nanny. They wonât let the 2 higher levels be memorized. That does not work for me.
I would much prefer an MT03 or MF01. They work better stock. The work super great when upgraded with NarsilM FET drivers. Even upgraded, itâs still cheaper than the X7R.
Are you asking about the upgrade I mentioned?
Lexel makes new drivers using the ramping firmware NarsilM. Itâs a FET driver so you get more output on turbo. The user interface is really nice. Itâs ramping so you can set it at whatever level you want including being able to memorize the brightest level. You can set the turbo timer to what you want or set it to a user defined temperature. Youâve got battery check where it blinks out the battery voltage. Iâm a big fan of it.
Not me. I would prefer a sling to carry it.
Using a sling makes it not only easier to carry - especially for a prolonged period - but you can put the light away and have both hands free without the necessity
to put the light down somewhere.
Itâs a fantastic looking light though, makes me droolâŚâŚâŚâŚbut Iâm afraid it will cost a small fortune.
