This item is out of stock now, so we don't plan to promote it now, there are many good deals above for black Friday, you can check if you are interested in them
I submitted a brief review on BG of this. I got two in at this $39 price. One I tested so far performs well under the specs as advertised - just under 900 lumens and under 200 kcd. It's driven at only 2.55A, and this is on a good LK cell.
It's a great quality light though, branded as Galuxia on the light and box. Reflector and lens look pristine. The glass has blue AR coating, but the spare lens is not coated. Amutorch is only mentioned on the manual, which is in Chinese. The website galuxia.com is listed but doesn't exist. There is mention of Galuxia here: http://maxtoch.com/c/galuxia_0022, and here: https://shadow.vn/.
So it's affiliated with MaxToch. Shadow is printed on the driver.
The modes are different than listed - lo/med/hi and strobe accessible via double click. It has mode memory.
The best feature of course is the wide head, wide reflector for this size and cost. 72 mm head diameter is rare for a single cell light, for under $40, nothing else comes close accept the old Courui D2, but it always under performed for it's size.
Should be able to achieve at least in the 300's for kcd with a full mod.
Thanks for the info !
Please tell me is there any step down at the strongest mode after some time ? If there is no, I assume that lumen output is not quickly drop since light is large and it should have good management of heat ?
