Interesting. Though I got too many chargers….
Strange why 21700 is not in the list of supported battery.
i assume they just did not test because that size is quite new ;)
looking at the wires i think the extra 5 mm will not be a problem
1300Lumens Long Shots LED Flashlight 18650/26650 (link is external)
Is there a 2 cell version of this? Dont much care about the guts, just want the host.
Basing on the pictures and item description, it appears to be the CPF Italia Cometa 2016 (but “forbidden” to label as such due to some ‘controversy’, which is why there’s no brand indication on the item listing).
see various reviews here:
Folomov A1 preordered !
That Folomov A1 looks really nice, and compact, but so is a Nitecore F1, which also blinks out the voltage.
I guess this will still fit where a solid charger won’t though.
One of those semi-rigid earphone zip cases is ideal to keep this and a USB cable together and protected.
A spare 18650 fits in the ones I have as well, but the Nitecore won’t.
limited units!!!
Model =my Link | Code | old price | DEAL price |
Sofirn SP31 | HSP31 | $19.95 | $10.40 |
Wuben T046R | HT046 | $49.99 | $29.99 |
Klarus Mi7 | HMI7 | $64.95 | $39.70 |
Folomov A1 | HFOA1 | $7.99 | $6.50 |
XANES KT | HXKT | $23.95 | $14.85 |
Nitecore TIP SS | HTTIPSS | $34.95 | $19.93 |
Eagle Eye X2R | HEX2R | $17.98-$18.48 | $14.2-$14.6 |
AMUTORCH JM70 | HJM70 | $69.99 | $48.99 |
Rofis R1 | HROR1 | $69.95 | $45.47 |
On The Road U16 | HU16 | $32.95 | $26.40 |
GOLISI O2 | HGLO2 | $14.69 | $11.75 |
GOLISI O4 | HGOO4 | $22.99 | $15.99 |
Golisi S2 | HGOS2 | $19.95 | $14.96 |
IMALENT DX80 | HDX8 | $379.95 | $208.97 |
HaikeLite SC01 | HSC01 | $59.50 | $39.70 |
Thanks for A1!!
Hello my dear friends!
i added some new items to M4D M4X DEALS
LUMINTOP EDC05
XP-L 800Lumens Magnetic Tail EDC LED Flashlight AA/14500
Features:
• XP-L LED (CW and NW for options) with a lifespan of 50,000 hours
• Max Output: 400 lumens(Ni-Mh), 800 lumens(14500)
• 4 output levels plus Strobe, SOS and Beacon
• Most efficiency constant current circuit, max runtime up to 171 hours
• Size: 86.2*20mm (length*diameter)
• New weight: 44.5g (excluding battery)
• Aerospace-grade aluminum boy, premium Type III hard-anodized anti-abrasive finish on the surface
• Aluminum alloy OP reflector creates a smooth and balance beam
• Toughened ultra-clear glass lens with anti-reflective coating
• Titanium coated stainless steel clip
• Magnetic suction tail cap with tail standing ability
• Waterproof to IPX-8 (2 meters under water), impact resistance to 1.5 meters
• Applications: hiking, camping, traveling, EDC or tools etc.
• Operation:
-When off, one click to access Moonlight, another click to circle through moonlight-low-medium-high. Long Press for off.
-When off, long press to access the memory output last use (except Moonlight), one click for circle.
-When off, double click to access Strobe, one click for circle: Strobe-SOS-Beacon, Long press for off.
-When on, double click to switch between general modes and flash modes.
Package included:
1x LUMINTOP EDC05 XP-L 800Lumens Magnetic Tail EDC LED Flashlight
1x User Manual
1x Lanyard
Nitecore DL10
Xp-l Hi V3 1000Lumens Under Water 30M Diving LED Flashlight With Red Light
Features:
Diving light specially designed for underwater sport
Utilizes a XP-L HI V3 LED with 1000 lumens max output
Integrated red auxiliary light for underwater photography
Crystal Coating and Precision Digital Optics Technologies for extreme reflector performance
Built-in threads for connecting the scuba diving pointer
Reverse polarity protection
Toughened ultra-clear mineral glass
Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
Tail stand capability
Package included:
1 x Nitecore DL10 XP-L HI V3 1000Lumens Diving LED Flashlight
1 x Scuba diving pointer
1 x Diving lanyard
1 x Spare o-ring
Imalent MRB-186P30
3000mAh High Power 18650 Battery
Specification:
Product: Imalent MRB-186P30 3000mAh High Power 18650 Battery
Brand: Imalent
Model: MRB-186P30
Capacity: 3000mAh
Voltage: 3.7V
Charging Current: Recommended 0.5A (Maximum 1A)
Weight: 48g
Size: Diameter 18.5mm, Length 69.2 mm
Package included:
1 x Imalent MRB-186P30 3000mAh High Power 18650 Battery
Some more deals for today!
limited units available...
Fitorch MR35 | HMR35 | $76.25 | $38.90 |
Fitorch P20R | HP230R | $54.99 | $29.10 |
Fitorch P26R | HP26R | $103.29 | $48.55 |
Fitorch EC10 | HEC10 | $38.59 | $20.84 |
Fitorch P30Z | HP30Z | $50.49 | $27.26 |
Fitorch P30R | HP30R | $63.79 | $35.00 |
LUMINTOP Tool AA | HLTAA | $21.00 | $17.22 |
Convoy S2+ | HCS2 | $15.95~$17.95 | $13.24~$14.89 |
New Convoy L2 | HCL2 | $39.99 | $29.99 |
JETbeam Mini-1 TI | HJTM1 | $35.95 | $20.85 |
CooYoo Fermion | HCYFE | $58.95 | $17.68 |
Lumintop Prince Copper | HLPCX | $54.00 | $21.60 |
XPL Magnetron | HXPLM | $18.95 | $6.80 |
Do you have a xiaomi power bank coupon code that is recent and works, thanks
Tried all the codes, couldn’t get one to work
try Bfriday210
for https://www.gearbest.com/power-banks/pp_600939.html?wid=83?lkid=11586067
Says coupon not for this warehouse
after the (still running) member gaw i have another for the facebook users...
Folomov looks like amazing deal—only downside—The Folomov cannot do NiMH as the similar Olight charger can.
thats right
but Olight is twice the money and cannot be used as power bank (1A)
and olight has only 750 mA charging current
BOTH are not good chargers for cels below 18350 !
so one can choose what is useful and buy either one :)
I pre-ordered a couple of the Folomov A1. Looks good!
Emisar D4 Titanium
i hope we get that to sell :)
