Personally I find the strobe to be completely useless. However I will be having a little fun trying to turn a drunk into a spinning dog next time somebody has a little too much down at the local bar.
I think the vast majority of people will scoff at this idea because yes, it seems ludicrous and the scenario is 1 in a few hundred thousand…but let me suggest it. I have paid keen attention with all the rat scum terrorist attackers in the US the last couple years. Las Vegas concert got me thinking about how a rat scum can try to open fire on people anywhere from 10 to hundreds of feet away. If a nearby stander was 1) outside the range to engage, or 2) in a location they didn’t have firearm…what if they strobed the scum of a bitch with 500,000 candela? Now they could be 300 feet away, and if ANYTHING, at least reduce the attackers thought processing/ability to acquire “other” targets. Of course 2 major problems exist…one being it would have to be in lower light conditions and two being the source of the momentary strobe can become a target. Call me crazy, I know, don’t laugh…but I have thought of this scenario.
I’m not sure I’ll get this right. But, IIRC, a ‘tactical’ strobe is one which flashes in the frequency range which is most effective to disorient people. Better is a randomly changing frequency which varies within the disorienting range of frequencies. And even better still is a light with randomly changing colors (at the right frequency). If everything is perfectly calibrated, it can make a person completely disabled momentarily.
I have bought many and sold this to several doormen. Bars / discos.
They are very satisfied and the strobe works very well is the feedback.
on unwanted agression…
Yes, would be good in a 18650 tube light with sensible output levels (such as S2+). Momentary strobe functionality is a popular requirement from light painting artists - few lights have single frequency momentary strobe.
Andúril is for lights with an electronic switch, but it has a nice momentary function that stays active until power is removed. It only works with steady output modes though.
I’m headed over to ToyKeeper’s E-switch UI thread to ask if the code could be modified to allow momentary strobe as well.
Yeah, I agree with using strobe for signaling traffic. As far as a ‘tactical’ strobe, for most of us civilians, the best use would be to disorient an attacker. Though, IMO, full power 1000+ lumen strobes become increasingly less useful the brighter the light is. The strobe on the MF-01 is a prime example of this. Tactical-wise, the up close reflected light is almost as blindingly bright for the user as it is to the assailant. For signaling, it’s too blinding and distracting, unless whoever you’re signaling is a real good distance away
Even if you ‘conceal carry’, most anything offensive any of us civilians would try would, as you noted, just make for another target. I’ve thought of similar situations, as well. Realistically though, in such extreme situations, almost anything outside a police or military response would likely be futile.
I understand why some people hate it and some people like it. I only use it to signal the wife unit when she comes out of a store to where I parked or if I am pulling up to let her know “I am over here!” It is the only time she is ok with disco lights. LOL.
Personally, I don’t really use tactical strobe at all. I use a motion-freezing party strobe though, because it’s fun with moving water and such.
For light painting, a custom build would probably be helpful. Features like momentary tactical strobe aren’t typically useful on general-purpose lights. I added a ‘todo’ note for it in the code though.
Also for light painting, I’ve been making a rainbow (RGBA) driver lately for lightsaber use, and it’s designed to paint pretty patterns in the air while swinging a sword. I think it could be adapted for momentary use pretty easily, though the current code doesn’t directly support it unless the brightness modulator is turned off (which is boring). It flashes in whatever patterns the user tells it to, with a momentary “overdrive” function which could potentially be used to make the whole pattern work as momentary. Normally it’d be used to make a bright flash while blocking another saber or deflecting a blaster bolt or something, but it might work for light painting too.
