It's very important with the above to use a plastic or other non-conductive sleeve. Also, be very careful to put both cells in facing the same direction. You will get a direct short of both cells if they are not put in oriented correctly.
Yes, ImA4. Very important to make that clear
This pipe
BTW, ImA4Wheelr, You posted for the first time in that thread almost 5 years ago now. Made quite a splash right from the get go with your idea for that mod.
At the time I was an “old timer” with a whole year under my belt on the forum :laughing:
Now you have twice as many posts as I do, with a whole lot more flashlight knowledge :student:
today they had about 30 pallettes covered with black plastic tarps and signs that said “no peeking until black friday”
a few tarps had been partially pulled up, saw some drill combo sets, some dewalt tool boxes etc, but they were mostly covered.
These appear to be Coast FL85’s. I went out and purchased a pack this morning. I’ve been using both the Coast FL75 and 85 for over a year and they’re really nice. 20 bucks for 2 is crazy!!! Thinkin they’ll be gone before they go on clearance.
Hmm I think my HD is broken. Most of the lights from the huge thread above are not even showing up. I think there was only 3 types of flash lights and one type of lantern.
Going out tomorrow to take a look at the other HD, it is a bit bigger but this one should have had a bit more.
For this being a 4xAA light, it is pretty darn huge. Here it is next to the 3xC Defiant and Convoy S2+.
I haven’t done any measurements, but with a naked eye, light output from this 500 lm Husky seems pretty close to the 1000 lm Defiant. However, the Husky has a more intense hot spot. It also has mode memory, so I like its UI better than Defiant’s.
From negatives, the Husky has some ugly green tint right outside of the hot spot.
