Astrolux MF03 - new pictures + video
You know they can’t push them that hard due to the poor efficiency.
The Imalent DX80 does 8 x 70.2 at 4,000 lumen each which is about 5A (6v). That’s about 32,000 lumen at 40 amps.
If this light had 8 x 70.2 at 8,500 lumen each that’s about 16A. Which is about 68,000 lumen at 128 amps.
You get double the output, but triple the power consumption.
Would we need to triple the batteries? Load it with 24 18650 cells? 6S4P.
The Imalent draws maybe 10A per cell on 8 cells.
This light would draw 32A per cell on 8 cells. So you’d need to at least run 16 cells to get it down to a more manageable 16A per cell. So at least 16 18650 cells. That’s a long battery tube.
I haven’t even mentioned the heat. You’d probably be triple at over 750 watts.
These are the reasons we are not seeing manufacturers push things so hard. The light would be so big and bulky and expensive to produce. It would not be practical at all and would therefore not sell well.
Kawiboy, I’m sure you know all this already, but I wanted to explain to all the newer folks the major hurdles involved.
^ Good information. The 5000 lumen Q8 is one of the harder driven lights stock but thanks to the non-bypassed springs the leds are not in the really inefficient region (they are with bypasses!). And the body size of the Q8 is quite in balance with the leds/currents, unlike i.e. the Acebeam with 25,000 lumen in a comparable package, that needs ultrafast stepdown (but is still IMO the coolest light around).
I get your idea. Highway for the heat to transfer to flashlight body and surrounding, not just adding thermal mass.
JasonWW, I think KawiBoy said he rather see 3*XHP70.2, not 7*XHP70.2.
But I prefer they drive the LED at the maximum spec to have better efficiency. Or maybe 125% of maximum spec, for example from 4A to 5A in Turbo.
This light in stock form must surpass any old flashlight out there except DX80(it is not old by the way). Else it will not gain much interest due to its big size. So I think two options below will be very good options:
1.30000 lumens, 250kcd, for at least 5 minutes
2.16000 lumens, 600kcd, for at least 10 minutes
Can we have a vote? Lol
I vote option 1
For a light that big, it needs the massive lumens to justify its size. And 250kcd is no slouch, should be able to see things at good enough distance.
If I need to see things further, I’ll take out the smaller tn42 or even smaller olight m3xs.
I was thinking no vote needed. If all are 12V leds, then we just pick our option for 7*XHP70.2+1*XHP35 HI or 8*XHP35 HI or buy both.
He was actually suggesting 8 x 70.2. 3 with a deep reflector and 5 with a shallow reflector. I used 7 in my example so it would compare better to the Imalent light.
I see. Now I got it.
I think giorgoskok already mentioned it would be about 30k lumen. Or someone did, I’m not sure now.
I seriously don’t think we have any say in this companies business. Maybe freeme can suggest software changes to make the modes better spaced, but that’s about it. This isn’t a BLF designed light.
About the 2 options you posted, are those realistic?
I think the DX80 can do turbo for 5 minutes (?) and is about 30,000 lumen. Does anyone know what it’s candela is? Is it close to 250kcd?
How would you get 16,000 lumen and 600kcd? 8 xhp35 at 2k lumen each and shallow little reflectors? Would that actually produce that distance?
Lumen wise they are all feasible, no doubt about that.
I know 250kcd and 600kcd are tough. I think it all depends on the reflector design. Since they are still at prototype stage, I hope reflector dimension and flashlight size are still not finalized.
DX80 hit around 100kcd although some members measured 140kcd I believe.
You could be on to something. The MF-01 fins certainly resemble those on the SC01. Being that both brands’ lights are more budget friendly, it wouldn’t surprise me if some designers and engineers are contractors and bounce from company to company.
please never pm me again
since it says you blocked me from replying, ill have to tell you here
heres what this wolfdog just PM D me with a few minutes ago
” wolfdog quote ”
Hi hahoo I mean NO DOUBT,
,the funny thing is I have you on IGNORE list at CPF. Wink
I never read any of your illiterate, stupid, provoking and childish comments that you post on my threads,or any other for that matter…Too bad they do not have that option hear!
I should feel sorry for you, being that INCEST is rampant in your family and MOST of the south!!!
NOW GO FUCK YOURSELF,SOLDIERS WILL BE COMING TO YOUR RESIDENCE. IT MAY TAKE A FEW MONTHS BUT WE WILL FIND YOU!!
this guys mentally unstable so it seems
unbelievable….
Only 100 kcd to 140kcd? Even with shallow little smo reflectors I doubt you would ever hit 30k lumen and 250kcd. You need to greatly increase the head diameter to get bigger reflectors in there.
To keep the current head diameter, maybe use 7 little aspheric lenses like Led Lenser used in their X21R.2 beliw. Maybe even custom TIR lenses?
I really have no ideas for getting 16k lumen and 600kcd. That seems too difficult. Maybe a really big head like on the BLF GT, or bigger, with lots of medium sized reflectors?
I just realized the Imalent DX80 has 8 emitters, not 7. So I rewrote post 92 above. The numbers are more accurate now.
If someone posts rude things, you can always mark it as rude. I don’t know how they do things at CPF, but here we all try to get along. This should be a positive and inviting forum.
Anything is possible… modified fenix rc40 with the 6 * xhp 70.2 hit 27,000 lumen and 265k lux…
Wow, there you go. I see the RC40 has a 108mm head diameter in order to get some decent sized reflectors in there.
I don’t know what the head diameter of the MF03 is, but it looks pretty close in size.
265k is over 1,000 meters.
For comparison, my L6 hits 830 meters with about 8,500 lumen.
So for the modded RC40 to go only 200 meters more, but with about 3 times the output, it means the hotspot must be bigger than on my L6. That’s pretty awesome. It must have a ton more flood light as well. That is a light I think would sell better than what the MF03 seems to currently be.
I cant wait for more news about it……
I love top flooders, I hope it beat the dx80 in quality and output :heart_eyes:
I’m okay with similar output, but I do hope it’s better quality.
We know it won’t use a battery pack, so that’s a plus (in my opinion).
In Maukka review, Acebeam X65 hits 587kcd with 10k lumens.
It is using 5*XHP35 HI.
“X65 Review”: To 10k LM and beyond: Acebeam X65 & X60M review
