You could be on to something. The MF-01 fins certainly resemble those on the SC01. Being that both brands’ lights are more budget friendly, it wouldn’t surprise me if some designers and engineers are contractors and bounce from company to company.
please never pm me again
since it says you blocked me from replying, ill have to tell you here
heres what this wolfdog just PM D me with a few minutes ago
” wolfdog quote ”
Hi hahoo I mean NO DOUBT,
,the funny thing is I have you on IGNORE list at CPF. Wink
I never read any of your illiterate, stupid, provoking and childish comments that you post on my threads,or any other for that matter…Too bad they do not have that option hear!
I should feel sorry for you, being that INCEST is rampant in your family and MOST of the south!!!
NOW GO FUCK YOURSELF,SOLDIERS WILL BE COMING TO YOUR RESIDENCE. IT MAY TAKE A FEW MONTHS BUT WE WILL FIND YOU!!
this guys mentally unstable so it seems
unbelievable….
Only 100 kcd to 140kcd? Even with shallow little smo reflectors I doubt you would ever hit 30k lumen and 250kcd. You need to greatly increase the head diameter to get bigger reflectors in there.
To keep the current head diameter, maybe use 7 little aspheric lenses like Led Lenser used in their X21R.2 beliw. Maybe even custom TIR lenses?
I really have no ideas for getting 16k lumen and 600kcd. That seems too difficult. Maybe a really big head like on the BLF GT, or bigger, with lots of medium sized reflectors?
If someone posts rude things, you can always mark it as rude. I don’t know how they do things at CPF, but here we all try to get along. This should be a positive and inviting forum.
Wow, there you go. I see the RC40 has a 108mm head diameter in order to get some decent sized reflectors in there.
I don’t know what the head diameter of the MF03 is, but it looks pretty close in size.
265k is over 1,000 meters.
For comparison, my L6 hits 830 meters with about 8,500 lumen.
So for the modded RC40 to go only 200 meters more, but with about 3 times the output, it means the hotspot must be bigger than on my L6. That’s pretty awesome. It must have a ton more flood light as well. That is a light I think would sell better than what the MF03 seems to currently be.
I don’t mind it use battery pack for this kind of high power configuration. Without battery pack, it might be safe for experienced users, but it is not safe for inexperienced users.
I was looking at some reflector based throwers and I see the Acebeam X65vn that Skylumen sells has 5 xhp35, produces 11,000 lumen and does 640 lux or 1600 meters throw. It’s $550, though.
Official Acebeam specs are 12k lumen, 423kcd and 1300 meters throw.
I see he also has an RC40 modded with 70.2. This must be the one Newlumen mentioned. I bet it’s over $500 as well. Probably over $800 since it has a custom finish on it.
I wonder if a big head, 5 or 6 xhp35, reflector light is the way to go? Do a $200 copy of the Acebeam X65. Over 5k lumen for over an hour. No battery pack, just 8 individual cells. I wonder how that would sell?
Maybe Astrolux can make an MF04 based on this same MF03 body design. Just change the head design a little and change the driver. Idk, maybe the X65 design is too last year or maybe it would conflict with the MF03.
16A per emitter is awfully inefficient, but totally worth it for all that output as long as it has more reasonable modes beneath it. I’d love to see a driver that could handle all that power.
A 3 volt driver, like in the Q8, would need to handle 256 amps. That’s not gonna happen. If you ran it at 12v then you’d be at 64 amps. It would not surprise me if the next big mega light used 12 cells and ran them all in series to get the voltage up and the amperage down.
They would probably use multiple drivers built on a single pcb or even a stacked pcb. One mcu could control it, but you’d need multiple fets or coils, etc… Similar to how the MF01 used 3 or 4 drivers combined.
One important thing is to keep the amps down so you don’t fry the electrical traces on the pcb. They can only be built so thick.
- Please kept me informed about this MF03 (7*XHP-70.2 + 1* XHP-35 Hi).
- This is the best idea, combining flood with throw.
- Any chances to make the head diameter bigger, say, 120mm (reflector 110mm), like BLF GT, better then Thrunite TN-40 and 42, better then Acebeam X65 ?
- What is the reflector diameter of the XHP-35 Hi, and each of the XHP-70.2 ?
- How long can the light stay in The TURBO mode ? Only few minutes like others, or any breaktrhough in the heat dissipation tech that it can stay in turbo mode for at least, 40 minutes or so ? Can the HIGH mode be 70% from the TURBO mode ? Can the step be 100% (40 minutes), 70% (100 minutes), 50%, etc ? (Olight X9 never exist, using small fan alone might not be a good idea, but a combination of water-cooled pipe and small side fan like Acer laptop might be a breakthrough).
- Hopefully it can make over 27000 lm and over 1700m throw.
Can the flashlight be flexible, giving choices to users of using 8 x 18650 or 12 x 18650?
