I believe the consensus is that all the "(Whatever)fire" brands were made in various places and aren't a brand as such, hence the enormous variability in quality etc. I'd guess that the two above came out of the same machines, or at least from the same drawings. The main difference seems to be that the Uniquefire one uses Helvetica Bold rather than Helvetica for its font.
Most of my recent lights have been P60 hosts and they do seem to be better made than some I've bought in the past. I'd guess that the current stuff is extensively Surefire compatible - I have a Solarforce L2 body coming to test this hypothesis as it is known to be Surefire compatible. In fact the only recent 18650 light that is not some sort of Surefire clone has a faulty switch. It is a Raidfire Spear clone. AFAIK Raidfire is not a "whateverfire" brand. Looking at the switch assembly this would appear to be a matter of fixing the switch more securely to the board.
But not as recessed as the K-106 for example. It is firm and positive - I've never had a click or half click do anything I don't want it to. A half click to change modes only needs light pressure, a firmer click is needed for on or off. As clickie switches go, it is quite loud - at least in my quiet study. Feels exactly the same as the switch on the 504B - at a guess, because it is the same switch. The light will tailstand, but it is still possible to operate the switch with the ball of your thumb. I have quite small hands though and prefer to use the top end of my thumb. Someone with a really big thumb might find it more difficult.
This is the nicest of the P60 hosts I have. It is actually airtight, let alone watertight when screwed together and would probably survive quite a bit of drowning. The dropin that comes with it isn't bad and it will (just) tailstand. Unfortunately no P60 light can be used as a candle but it works pretty well in here as a light when bouncing it off the ceiling.
The Solarforces have a big following on CPF - I have a Solarforce L2M body in the post just now from Hong Kong. This may, or may not revise my opinion. http://cgi.ebay.co.uk/Solarforce-L2M-SD-Flashlight-body-4-Surefire-3P-6P-9P_W0QQitemZ270490322739QQcmdZViewItemQQptZUS_Flashlights?hash=item3efa7ac733#ht_2772wt_941 $18 or thereabouts including postage but this is for the body only.
Al of the ones with dropins in them I can recommend as giving plenty of light - the R2 in the 504B throws well, the R4 in the Seraph clone gives a lot of light and has respectable throw and a lot more spill - and 70% or thereabouts more total output.
Will do a comparison of various P60 host bodies at some point. Problem is my camera stinks at close-up stuff so will have to beg/steal/borrow a better camera first and throw some serious light on the matter. Pity I don't have one of the old Colortron light systems I used to sell in the 80's but they did need 3 phase power which is not a normal thing to have in a house in the UK. They also consumed several kilowatts. And when they got old they tended to turn their casings live. 440V AC is bad for you.
Found a holster that works with this. And all my other P60 lights. Pity it is in camo finish but a few minutes with a black Sharpie marker will sort that out.
http://www.dealextreme.com/details.dx/sku.29355
This guy has a bigger head than most so fits best head up but all the others are quite happy head up or head down.
Oops! - put this in the wrong place I thought I'd posted this in the Uniquefire R5 (The Seraph clone) thread. It does have a bigger head than most, the L2 doesn't.
I've just ordered one of these holsters for each of my P60 lights.
The large variant (29356) will hold a P60 light but is aimed at something with a very wide body and not too large a head - the Ultrafire C2 body which gets used for quite a lot of lights doesn't fit as the head is too big.
With a Solarfore L2 with forward clicky and flat SS bezel. I don't think the spiky bezel would be good for the holster. Also tried it with a Solarforce lanyard ring and it did fit, just a pain getting it out till the elastic loosens off
Really not sure what sort of light it is aimed at - see if anyone on DX has found a light that actually fits in it. Nope!
It sorta, kinda holds a P60 light but is clearly aimed at something of that sort of length with a fat body. But not a large head.
It wan't take an Aurora AK-P7 (Ultrafire C2 body and head). The flap won't make it over the head.
Nor will it close on the Piritlight SG-L8 (Raidfire Spear clone with an MC-E in it). Again the flap won't make it over the head though it is nearly long enough. Nor will it quite fit in head down - this one isn't elasticated.
It will hold an Ultraifre WF-504B with room to pack your lunch in as well. Head up it rattles around in there, head down it stays put.
Well there was talk on the other side about the SF and UF light coming from the same factory.....If i could find one without the camo then im in for one. Would be nice to take the clip off my L2M and keep it holstered.
Five minutes with a Sharpie colouring it in while I was on the phone
I may invest in some black dye and dye them properly (I have 6 more of these coming for my P60 lights) but this will do for just now. Colouring in is quite fun really. Like you Al, I'm not fond of camo finish ever since I tried to shower off cam cream in a cold shower in Germany. Felt really sorry for whoever in the Mess ended up washing the sheets and pillowcase.
I have a rather large piece of unfinished leather (but it is quite thin). May try to make some holsters for the more oddball sizes but my previous attempts weren't very successful. At the worst all I need is a belt loop and some sort of ring to hold the light.
Could do with one Aurora SH-032 sized - the 18650 sized one is too big and a longer version of the AA holster for the Trustfure F22. Something around the size of the one that came with the Smallsun ZY-C85 but a little smaller in diameter would be fine.
