[short review and modding] Emisar D4
10 posts / 0 new
Lexel
Lexel's picture
Last seen: 11 months 2 weeks ago
I received today a Emisar D4 to change its XPG2 S4-5D LEDs with Nichia sw405 D240 CRI92 and spring bypass it
So I can take a look inside it
finished light
Size comparism
Spring bypass
I also noticed there is very little solder paste on the springs but they seem to hold fine
Threads are cut square very nicely
The light is build like a Tank shelf and all walls are very thick even the tube
The driver is so designed that the MCU and AMC have contact with the shelf, so temperature reading of the MCU should be pretty precise, I do the same on my Klarus XT11GT Repairs with Narsil driver
It uses a Infineon Power-MOSFET, BSC009NE2LS5 in PG-TDSON-8 (also know as Power SO8 or LFPAK56)
This FET looks pretty good from datasheet comparable with beating the Vishay ones in low Resistance 1.2mOhms @3,5V
I wish the side switch would have LEDs like my Q8
The LEDs are reflowed with very much paste, it would be better to give em a tap to push solder out to get it as thin as possible or use less
the LEDs are reflowed with Leaded solder
Reflowed Nichia SW405 D2450 CRI9050 in it
Used my temperature regulated heat plate
Gave the LEDs a tap to remove too much solder, so also a lot solder blobs are all over the place
carefully aligned the LEDs to the markings if they were off
Used a little weight to push the LEDs down while cooling the heat plate with water filled pot
Light is now drawing 15.8A at 4.1V Sony VTC6 battery
Compare to the BLF Q8 with one battery with same charge level and type as in the D4
I also looked at intl outdoor website again and noticed the XPL Hi are now +18$
Conclusion:
Overall well build light and UI.
Great optics and MCPCB.
Pretty short for a 18650 light, possible EDC in pockets.
The only downside in my opinion is that the switch is not lighted.
Edited by: Lexel on 11/25/2017 - 11:43
Agro
Agro's picture
Last seen: 46 sec ago
I was told that bypassing the spring is meaningless in D4. DBCustom even replaced the FET (and gained lumens this way), but didn’t do a bypass. I guess you don’t have a direct comparison, do you?
djozz
djozz's picture
Last seen: 1 hour 2 min ago
These are Be-Cu springs that have 0.45 the electrical resistance of pure copper, this so good that you will not see any difference from a bypass, but I’m sure that the quite insignificant difference can be measured.
CRX
CRX's picture
Last seen: 6 months 3 days ago
A very difficult mod but It can be done.
Flashy Mike
Flashy Mike's picture
Last seen: 2 weeks 4 days ago
@CRX:
Beautiful!
Would like to know how you removed the switch bezel without scratches.
CRX
CRX's picture
A thin tipped small flat screwdriver, slip it under the bezel and carefully twist/pry it off.
High risk of the switch boot being punctured at some point though.
Lexel
Lexel's picture
Replacing a FET that has 1.2mOhms with anything else does make no difference
I compared the datasheet to others and did not find any better
its likely the case of the FET is the limiting factor how far resistance can go down not below 1mOhm
Flashy Mike
Do I understand right: you did this from the inside of the bezel, not at the outer edge between bezel and casing? I don’t mind the boot, I’ll probably go for a transparent boot anyway if I find one (I’m more capable of doing electrical mods than mechanical ones).
CRX
CRX's picture
Yes mate, from the inside, placing the levering tool between the bottom of the steel bezel and the rubber.
The bezel has a lip on the top outside which you could prob get a blade under but would most likely scratch the ano going that way.
Just make sure you don’t press on the switch when prying as they are delicate.
Flashy Mike
Thanks for info, I’ll give it a try.
