D maglite switch mod
9 posts / 0 new
charlestt
Last seen: 4 years 4 months ago
Hi guys anyone have a good how too on dismantling one of these to connect it to a driver ?
thanks
Charles
 http://i776.photobucket.com/albums/yy41/charlestt225/Sig/A1200023-1.jpg" width="159" he
Huny74
Huny74's picture
Last seen: 5 years 4 months ago
Hi charlestt!
This is the best I found:
http://edcforums.com/showthread.php/50652-DIY-700-lumen-SSC-P7-3D-Maglit...
Hope it helps you like it helped me.
Good luck and have fun, Huny
Don
Don's picture
Last seen: 1 year 2 hours ago
This might help
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
charlestt
Cheers guys now does anyone know where i can get this stuff (in store not online)
http://www.arcticsilver.com/arctic_alumina_thermal_adhesive.htm
Huny74
Huny74's picture
It or something equivalent should be available in your local computer shop.
An additional tip (taken from the flashlight section of the german messerforum.net): If there is the slightest possibility that you want to swap the LED again in the future, mix the adhesive with normal thermal compound (1:1). It still holds the LED securely on place but makes it much easier to remove it in the future. Has also the positive side effect that it takes longer for the glue to set (10 to 15 min) so you are not forced to center the LED in a hurry.
charlestt
Cool thanks for that ill bare it in mind. i can get normal thermal compound easily but the adhesive type seems a lot harder to obtain.
In the past i've used some very expensive adhesive thermal conductive tape but not sure if this will be up to the job.
Don
Don's picture
Another thought is the adhesive pads used for CPUs. They run a lot more power than an LED so the stuff will be adequate.
charlestt
Cheers Don i actually have some of that stuff.
agenthex
agenthex's picture
Last seen: 7 years 11 months ago
Should be ok with a star, but with bare led's it's perhaps acceptable for xr-e's, but not mc-e's or above. Thermal interface effective is mostly based on thickness, so make sure that tape is the thin type. Also note that cpu pads are not necessarily adhesive on both sides  (or at all) as they're designed for something with a mechnical interface.
Reading this makes you smarter: http://lesswrong.com/
