The fenix zoomies are more like the opposite, they are “un-zoomies”
Instead of focusing the beam into a spot, they do the opposite and make the beam super wide flood.
In their “focused” position it is about the same as a regular TIR or reflector beam profile, with a hotspot and spill.
It’s not, unfortunately.
Led Lenser has started making 18650 and other standard li-ion flashlights, however I don’t really like their new style.
That product page didn’t look right. Ledlenser P7.2 doesn’t have smart light user interface (just momentary boost, high, and low using resisters). Emitter is XP-G2 not Q5. Looks fishy!
POP lite copy Led Lenser. I know member Jerommel bought one and was not impressed for the price. I think it should be easy to find an original Led Lenser P7 or something similar for under $50.
yeah, i got a Pop Lite…
The problem it has (besides the antique LED and no driver) is that the head is adjustable just within the middle range, where even Led Lensers project rings…
It’s waiting for me to open the head (which has glued bezel) so i can increase the head travel.
Hum, didn’t know this one! But I’m with you, I don’t like that design so much… Don’t know about the specs, but the other series seem to be more pleasant to the sight!
Hum, you’re probably right! I didn’t notice those details! But there are things in AliExpress that are not correctly written in the specs. Some lights use different batteries from those written on the specs, other have different LEDs from those advertised…and let’s not talk about the advertised lumens as well :person_facepalming:
On this particular light, I read the comments from the different sources and someone said it was not “completely original”, something about the battery compartment. I always thought this would be a “factory” price or something like that, but…maybe my guess was wrong about this one.
If I had to choose a zoomie light, I’d probably get one from the Convoy line (BD04).
Brynite has regular aspheris lenses which is cheap but not very efficient solution.
I can’t recommend any LedLenser flashlight, they’re not worth the price and their zoom system is overrated. I had one before and all I can say that beam from a regular reflector (of Fenix’s zoom system) is much more versatile. Flood in LedLensers is very poor, it’s brighter on the edges which messes with your eyes, it’s also blueish in the middle.
While this is true, the thing out throws every reflector light with the same diameter.
What’s Renix’s zoom system?
That’s strange though, because it would just be a matter of how close the LED can get to the central lens in the optic.
The tint shift is normal though.
Every zoomie i have (had) is cooler in the middle / warmer on the outer perimeter when in flood position.
But then again, normal reflector lights also have a lot of tint shift in the output.
If you want to avoid that, you want a proper fixed focus TIR optic.
I’m often wondering how long this Led Lenser patent is supposed to last…
I did find 40mm diameter Led Lenser (like) optics though, but i have no use for 400 pieces, so i didn’t order…
If you really want to know the Led Lenser optic, then I think you should get a Led Lenser. A clone may look like a Led Lenser, but the optic/led can be of a different quality, and you’ll never know for sure.
