M4D M4X deals - Astrolux WP1 and WP2 LEP
Yes Please.
Would Emisar D4 Titanium be much heaver than the regular one? Would you know the weights of the regular one and also the Titanium D4?
Titanium is 65% heavier than aluminum. But an aluminum light has internal parts of aluminum, copper, steel, et cetera. So does a titanium light. And the same battery goes in, of course.
Don’t forget titanium is much stronger than aluminium and can thus be made thinner for the same amount of strength. Aluminium might be lighter (lower density), but looking at total weight for the strength needed titanium is the better option (except for cost of course).
None of this applies in this instance though, as the head seems to be made out of the much heavier copper for better heat sinking and dissipation.
the deals are to low for public eyes and seach bots ;)
please check my deal list or contact me if you are interested!
LUMINTOP Geek
XPL HD 350Lumens Multifunction USB Rechargeable Portable Mini Keychain EDC Flashlight
Nitecore TINI
XP-G2 S3 380LM 4Modes USB Rechargeable Mini Metallic Keychain Light
LUMINTOP EDC05
XP-L 800Lumens Magnetic Tail EDC LED Flashlight AA/14500
(please click the links for detailed product descriptions)
Lumintop hit it out of the park with that Geek! Too pricey however.
have you checked my price?
not as cheap as other competitors, but knowing Lumintop i think worth it...
The geek is too expensive for me and too red. I think in bare aluminum color or black it will be more stylish.
Hello my dear friend!
today i got a bunch of nice codes!
hurry up – they are limited…
Xiaomi Yeelight Children LED Ceiling Light
$69.99
$59.99 with the code: HeroRR
Xiaomi Yeelight Smart LED Ceiling Light
$69.99
DEAL FOR DACH: Code 1111de20 makes it €50,59
i wrote a small review yesterday of this one: https://m4dm4x.com/xiaomi-yeelight-ceiling-light-experience/
and i just bought 2 of the bigger ones too :D
Xiaomi Yeelight JIAOYUE 480 LED Ceiling Light 200 – 220V STARRY LAMPSHADE
$109.99
$95.99 with the code: XMY480
BRELONG LED Stepless Dimming Ceiling Light Stone Shape 180 – 240V-
$59.99
$39.99 with the code: StoneGB
IMALENT DT35 8500 Lumens High Power LED Flashlight –
$135.99
129.99$ with the code: MDT35
NITECORE NU10 Rechargeable LED Headlamp –
$15.99
$9.99 with the code: NU10QQ
HaikeLite HT08 CREE XPL 5000K 850Lm LED Flashlight –
$16.99
$12.99 with the code: HT08
Brelong Noise- making Cartoon Keychain with LED Light Pendant –
$3.99
$0.99 with the code: MonsterQ
MKA4 – 02 Multi-use EDC Tool –
$5.99
$3.99 with the code: MKA4ET
Ganzo G727M-W1 Axis Lock Pocket Knife –
$16.44
$11.99 with the code: G727M-W1
GANZO Firebird F708 Liner Lock Folding Knife with G10 Handle –
$17.56
$11.11 with the code: GZF708jx
FURA Water Ripples Folding Knife with Frame Lock –
$25.55
$24.11 with the code: FURAgray
HX OUTDOORS Poker ZD009 Pocket Folding EDC Knife –
$16.25
$12.99 with the code: HXZD009JJX
Hi Max, the code on Ganzo G727M-W1 is expired…
Nice review with lots of photos :slight_smile: I also bought the youth version and the kids version recently during the 11.11 and BF sales. My main issue is the lack of wall holder for the bluetooth remote, so I am constantly looking for it when I get into the two rooms where they are fitted. Have you come across any wall mounted holder that is suitable for the remote?
no (i have a shelf there) but i will forward that idea to the manufacturer if possible!
i have a new deal for that light on my blog which works worldwide ;)
There are ring magnets you can screw on the wall or furniture. countersunk ring magnets . Add a metal plate on the remote with double sided tape (or open the remote and add a magnet inside).
You can fix that ring magnet even on the underside of a shelf
Or you glue a strong magnet under a nice pice of wood and fix that on the wall
There are DIY solutions
Google for: magnetic knife holder diy
Thanks, will look into it. :slight_smile:
Also found this MiLight Remote Controller Holder - WHITE on GB website. Looks like this was made specifically for the Yeelight Bluetooth remote?
Hello my dear friends!
today i got a nice code for the new
Lumintop HL18
XP-L HD 950Lumens Headlamp USB Rechargeable Magnetic Tail Mini LED Flashlight
Deal is available via M4D M4X DEALS or mail ;)
Features:
● Utilizes XP-L HD LED with a lifespan of 50,000 hours
● Compatible with 18650 or two cold-resistant CR123A batteries
● One switch controls 5 output levels plus Strobe, SOS and Beacon
● Max 950 lumens output and 18.5 days max runtime under Moonlight
● Micro USB rechargeable, with charging and low voltage indicator
● Silicon headlamp holder makes a comfortable wearing
● Detachable reflective and anti-slip sweat-block headband
● Detachable stainless steel clips allows more wearing manners
● Magnetic flat tail cap with tail standing ability
● Multifunction serve as a headlamp, angle light or flashlight
● Made of aerospace-grade aluminum with premium Type III hard-anodized anti-abrasive finish, more durable in use
● Floodlight design creates a smooth and comfortable flood beam
● 5 years free repair, limited lifetime warranty
● Operation:
- General mode: Press the switch for ON, another press to cycle through Low-Med-High-Turbo; long press the switch for 2 seconds for OFF. Next time you turn on the lamp, it will memory and enter the last used output level.
- Moonlight: When the lamp is OFF, press and hold the switch for 1 second to enter Moonlight, another press to enter general mode.
- Flash mode: Under Moonlight, double press the switch to enter Strobe, press to cycle through Strobe -SOS-Beacon.
- Lock-out/Unlock: Under OFF, long press the switch for 5 seconds till flash to lock the lamp. Under lock-out statues, click or long press the switch can momentary light up on Low until release. To unlock the lamp, just loosen the tail cap and cut off the circuit.
Package included:
1x Lumintop HL18 XP-L HD 950Lumens Multifunctional Headlamp LED Flashlight
1x Silicon holder,
1x Headband,
1x User manual,
1x Warranty card,
1x Spare O-ring
1x Clip
Thanks Martin! Looks pretty good. Wish someone would make 18350 tubes for these sort of lights…
Mahalo!
As i see , old low prices of lumintop lights are gone …
yes - no more 50% :(
Astrolux Ti3A Titanium
Nichia 219C 85LM 4Modes Mini EDC LED Flashlight AAA
Code: MTI3A price: $16.90
Nitecore T5s
Cree R5 3 - Mode 65lm AAA Battery Mini LED Flashlight
Code: NT5SGIFT price: $14.99
zanflare F6S
Rechargeable EDC Flashlight Cree XP-G2 200 Lumens IPX8 waterproof
Flashsale: $9.99
Utorch UT02
Cree Large Flashlight 1300Lm 2A Quick Charge
Code: UtorchDeal price: 35.99
Nitecore TM15
3 x Cree XM - L U2 2450lm 18650/CR123 LED Flashlight
Code: GB11LUCKY price: $89.99
JETBeam E40R
LUMINUS SST40 LED Flashlight USB Powered 1150Lm 6500 - 7000K
flashsale: 36.99
today i got some nice deals for you:
JETbeam Mini-1 TI
Titanium XP-G2 130LM USB Rechargeable Mini LED Flashlight
Klarus Mi1C Cu
XP-L HI V3 600Lumens Compact Mini EDC LED Flashlight
Klarus Mi1C Ti
HaikeLite MT07S HI
Upgrade Version 3000Lumens CW/NW Long Range LED Flashlight 1200M
you can contact me for the deals or just look into M4D M4X DEALS
