Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Hi, i have my BLF Q8, but something wrong is with switch, if i use off then switch still lighting in Green kolor, please help, thanks
Not sure I understand… the green switch led’s are supposed to be on when the light is off. Is that it? And the switch led’s go off when the light is on.
Hi, thanks, sorry for my bad English, so… If i turn off Q8 then switch led still shiny.
Check this video at 4:30.
That is normal.
It can be used as a locator of the flashlight.
Ok, but she stay a few hours and leds in switch still is green, this is normal ?
Yes
Can be for years
Until the batteries last
PS. Mine has the switch shining for 55 days
Normal operation of the Q8 has the switch led’s stay lit when the Q8 is turned off. However, if you are using ramping mode there is a simple way to get the switch led’s to remain off when the light is turned off. I am not sure if this can be done with the Q8 set to discrete, non ramping, modes.
Turn on the light. Then ramp up or down and then very quickly click the switch to turn off the light. When done quick enough the light turns off and the switch led’s stay off too.
That might take some practice but I can now make the switch led’s remain off whenever I want.
I hope that helps you.
Thanks guys :slight_smile: , MtnDon i understand :slight_smile: but now I have another problem :slight_smile: In my second Q8 if turn off Q8 leds in no light ? So, maybe my second sweety have defect ? :slight_smile:
That is normal. I think it was said it will last for years with the indicator lit.If you would like to turn it off, do 4 short clicks. That locks it out, and you have to do 4 short clicks to turn it back on. I think there is somewhere in the configuration to turn it off, permanently.
Hmm, if i click short x4 then in both Q8 switch stop working, another x4 click and again works as earlier, so… i dont know ?
When your second Q8 is shut off the switch led’s do not come on? Do the switch led’s blink twice after you have the cells and screwed the body into the head? They are supposed to blink twice when the cells are first connected.
Also do the switch led’s blink if you do a battery check. (Click the switch three times quickly. The led’s at the switch should blink out the voltage. (Like 3 blinks,a pause and then 8 blinks for partially depleted cells; 4 blinks and a pause then 2 blinks for fully charged cells.) The main illumination led’s will also blink. Does that make the switch led’s blink?
Yes, led’s do not come on. Yes switch led’s blink twice. Voltage: First Q8 - 3 and 9, Second Q8 - 3 and 5 blinks.
Yes, that’s normal. The green light under the switch stays on, normally.
Ok, but in First Q8 if i turn off light, switch is Green, in Second Q8 is not :frowning:
It appears that the indicator led is turned off. Everything else appears to be working, and the indicator leds do work. Download the NarsilM Reference.pdf , look at the bottom under Advanced Configuration UI Operation It will tell you how to enable/disable the indicator led.
So the switch LEDs work.
Maybe you switched it off in the Advanced Config Settings?
The first one “Locater Led Feature” does this.
You can try to switch it on again or reset the lamp to the default settings.
Reset to factory in RAMPING:
The lamp can be OFF or ON:
3x, 2x, 2x, press&hold (for 1.2sec) till 4 blinks
Reset to factory in MODES:
Only from OFF:
1x, click&hold (for 2.5 sec), 2x, 2x, press&hold (for 1.2sec) till 4 blinks
There is a newer cheat sheet under
With few more notes on NarsilM.
you probably need Q8 v10
The Q8 v12 is for firmware version v1.2
Yeah try that ^ much easier
Or do a factory reset….
Restore to Factory Settings
This is a feature, undocumented in the user manual, that will restore all configuration settings to factory defaults, in the
state as originally shipped. It comes in handy in case there’s any doubts of how the light is configured. To access this
feature, while displaying the firmware number (dbl click for voltage display, then dbl click for temperature display, then
dbl click for version display), press&hold the switch until the light blinks quickly – this acknowledges the configuration
settings have been reset to factor defaults.
yes, do the simple restore to factory settings as stated above. After doing this, the green LEDs should be ON! If not, you have a problem as others have had.
