Samsung LH351D color testing
14 posts / 0 new
maukka
maukka's picture
Last seen: 5 hours 41 min ago
Kiriba-ru sent me a Samsung LH351D for testing.
The emitter tested is a model number SPHWHTL3DA0CF2R1W2 with 5000K, CRI70 and rated luminous flux of 460lm at 1050mA. It fits on a XP/219/319 MCPCB. Now I’d like to test the higher CRI options, which are also plentiful.
I tested it with the small OP reflector from the Reylight Pineapple. It was sitting on an MCPCB, so no heatsinking and no stress testing at high amps. I’ll put it later in some light
Visually I’d rate it close to the Nichia 219C 5000K R8000. Very nice and neutral white tint (4900K, duv 0.002), no bad sudden tint shifts, rings or discolorations in the beam, mostly a big pure white hotspot that fades quickly. Just a bit cooler on the outer edge. The warmer/yellower corona is not very noticeable, much better than on the new Crees.
Tint with output current of 100-1000mA
Tint in different parts of the beam
CRI data on rated current of 1050mA
Edited by: maukka on 11/29/2017 - 14:33
maukka
maukka's picture
On the other hand, it doesn’t play nice with a big SMO reflector from the Eagle Eye X7. Wide and very visibly green corona around the nice hotspot.
kiriba-ru
kiriba-ru's picture
Last seen: 1 day 14 hours ago
Texas_Ace should get a couple of same leds in a week. I would like to see dead test. I know they are good under 1A (better than XP-G3?) but probably far away over 5A.
maukka
maukka's picture
Got some LH351D 5000K CRI90 emitters (SPHWHTL3DA0GF4RTS6 from digikey) and they’re really good as well. I put them in a Wuben TO10R triple with a clear Carclo. There’s just a hint of green on the highest mode, but I wouldn’t complain. Thanks to the smooth and evenly tinted beam, it’s easy to correct with a filter if you’re going to run these very hard.
CRI and tint data in ascending current order.
firedome
Nice test! Thanks! Thumbs Up
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
djozz
djozz's picture
Last seen: 1 hour 10 min ago
Thanks, those are great tests to evaluate how good these leds are!
maukka
maukka's picture
Output in a sphere. Strange that the output tapers off at 6A while in TA’s test on the CRI70 version went much higher. Maybe my reflow wasn’t perfect. At least the performance up to 4A is very good.
djozz
djozz's picture
Thanks for the test, indeed 1200 lumen at 4A is really good.
Strange things sometimes happen with led tests. I have done tests on the XHP70.2 that have a maximum at much lower current than TA and Koef3, I blamed that on for my (for that immense power) insufficiently cooled ledmount, but it could have been something else too, I never really found out. Perhaps in your case the thicker phosfor layer which also has a different composition is to blame.
MascaratumB
MascaratumB's picture
Last seen: 8 min 21 sec ago
I don’t know if it is a “fair” comparison, but how are these comparable to the XP-G3 5000K 90CRI used in the Wuben flashlights? Are they less green or so-so?
Thanks in advance!
maukka
maukka's picture
My review of the TO10R and TO46R: http://budgetlightforum.com/node/60934
With the XP-G3 the center of the spot might be fine, but the tint is all over the place and severely green on the edges. This can be remedied with d-c-fix and a minus green filter. The LH351D is much better out of the box. You don’t lose output but throw does decrease, larger emitter area = larger spot.
MascaratumB
Thanks for the answer maukka! I have DC-Fix on my TO46R due to those shifts of the XP-G3 (even if they are better than the CW 70CRI from the stock lights). The DC-Fix did help to improve a lot. And that was the reason I was asking, to check if this would be less green. And you confirm! Thumbs Up
This said, I am still fascinated by the 4000K one you’ve shown above in comparison Blushing
Let’s see if the FW3A will have it Cool
maukka
maukka's picture
djozz wrote:
Thanks for the test, indeed 1200 lumen at 4A is really good. Strange things sometimes happen with led tests. I have done tests on the XHP70.2 that have a maximum at much lower current than TA and Koef3, I blamed that on for my (for that immense power) insufficiently cooled ledmount, but it could have been something else too, I never really found out. Perhaps in your case the thicker phosfor layer which also has a different composition is to blame.
CRI70 version of the LH351D topped off at about 6 amps with two different heatsinks and fans. The heatsink shouldn’t be to blame since I also tested an XP-L2 CRI70 and it went nicely all the way up to 10A with more output and better efficacy than in TA’s test. No idea about the binning of my sample since it came from Kaidomain. Could also be the nondescript MCPCB I used for the Samsungs. Kaidomain Cu DTP for the XP-L2.
eas
eas's picture
Last seen: 12 months 9 hours ago
The differences in Vf between the 70CRI and 90CRI are interesting and substantial, even at low test currents, where resistive effects are minimized.
That suggests to me that the 70CRI are using a shorter wavelength die to emit higher-energy photons. I’m not sure how commonplace this is for other manufacturers and emitter families.
Caleb
Caleb's picture
Last seen: 4 hours 9 min ago
maukka, thank you for taking the time to do all your testing. I must admit that I need to learn how to interpret your results. What must seem obvious to some is lost on me. Can you point me to a website that will help me decipher your CRI charts and graphs?
