Emisar D1 / D1S review
576 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 2 weeks 3 days ago
With the exception, Joe, of the Q8, right? Wink
Bob_McBob
Last seen: 1 hour 7 min ago
I was curious about the D1S runtime, so I’ve been playing around with zak’s ceiling bounce app in my NIST-certified integrating bedroom closet. Even set to a very high thermal limit, the D1S throttles down pretty hard after about 5-7 minutes and takes more than 20 minutes longer to settle at a stable output level. With a lower limit, or a higher drain cell like the VTC6 (“d1s test”), the “hump” is even more pronounced. I will repeat the tests with a proper shoebox setup soon, but I was surprised the D1S couldn’t handle a bit more since I almost exclusively use it outside where it’s cool enough the thermal throttling never engages.
In contrast, the D1 also drops down, but manages to stabilize fairly quickly.
For reference, Convoy C8 and Manker U21.
DB Custom
DB Custom's picture
Guess I’ll have to build a copper helping hand for my D1S….
(if/when I see it, that is. 25 days and counting)
DB Custom
DB Custom's picture
Can someone who has both a D1S and a decent pair of calipers give me an idea of the overall diameter of the head? I’ll see if I can get a chunk of Tellurium copper to beat my D1S home…
goshdogit
goshdogit's picture
Last seen: 6 hours 59 min ago
My cheap digital calipers are far from “decent,” but here’s what I got:
Bezel is 50.09mm diameter.
Switch area is 35.97mm diameter.
Bezel to start of taper is 35.47mm.
Bezel to end of taper is 41.14mm.
Bezel to end of head is 64.23mm.
Hope this helps! Big Smile
DB Custom
DB Custom's picture
I always get ahead of myself… in the beginning of this thread the 35mm diameter is quoted… so I ordered a piece of TeCu 38.2mm in diameter by 76.3mm in length. Tonight was the last night of a nice discount, so I hurried. Sad
It’ll be all right though, I want to start the copper just above where the emitter shelf is so I can cut threads and inset the new emitter shelf. Wink
DB Custom
DB Custom's picture
Thanks for those numbers… know any mojo to get my D1S to arrive? Big Smile
DB Custom
DB Custom's picture
Ah, I see what I did…. I got the 35mm bezel diameter of the D1… oh well, I’ll make it work, just need the diameter where the emitter shelf is and that should be around 36mm at best guess, 38.2 will have to do.
And no, I’m not planning on using the entire 3” on this light, I have some other things needing this copper. Wink
goshdogit
goshdogit's picture
I think it involves chanting “Emisar,” in a darkened room with a few lights running Andúril’s ‘Lightning Storm’ mode. Party
No problem, just order a D1 too. Problem solved! Big Smile
Yeah, we know! Wink
DB Custom
DB Custom's picture
Oh, I’ve got a D1, and a D4 (or two) and the grey D1S should be here someday. And then I’ll probably make it look something like this, albeit a bit less disjointed…
joechina
DB Custom
Smile
yup, but I assume the reason for the Q8 petals are the four LEDs.
Trevi_lux
Trevi_lux's picture
Last seen: 2 years 5 months ago
Arrived now D1S gray, 3 minutes in my hands. Love
Wow, wow, nice!!
DB Custom
DB Custom's picture
Joe, I was referring to the smooth mirror finished reflector cups in the Q8. Wink The flat sides of the XP-L are due to the fact that the die is XM-L sized on an XP substrate, so the dome had to be flat sided to fit. These flat sides cause 4 “petals” in the beam profile of a mirror finished reflector. It’s a reflection of the emitter in the shiny coating.
atbglenn
atbglenn's picture
My gray D1S just shipped from Mountain Electronics. I should have it in a couple of days Smile
Boycott Nike
contactcr
Last seen: 19 hours 10 min ago
Can we get some more D1 vs D1S beam shots?
DrDevil
DrDevil's picture
Last seen: 3 hours 57 sec ago
Sure, you have to take a look in the German Flashlight Forum (TLF) Smile
A review from Wiestom with Beamshots from Underground
http://www.taschenlampen-forum.de/threads/emisar-d1s-pocketthrower-review.59797/
Or you can have a look at Bluzies Beamshot Series in his garden center (in alphabetical order) for comparison
http://www.taschenlampen-forum.de/threads/lampenliste.53366/
Coscar
Coscar's picture
Last seen: 7 hours 29 min ago
Go ahead….. twist the knife, will soon be a month since I ordered from Neal and shipping only says “has been processed through a facility in China” Ughh
I know its not Neal’s fault but it would be nice to have better updates from the shipping……….. like “its on the boat” ……. surely they dont use air freight or it would already be here.
Im not a Pessimist …. just an Optimist with a lot of experience
A little John Prine
xCentrino
xCentrino's picture
Last seen: 2 years 6 months ago
My overseas packages are almost always 13-15 days. My D1S was delivered in14 days. It was 9 days between “has been processed through a facility in China” to “Processed Through Facility
ISC LOS ANGELES CA”
Mine was shipped on the 15th.
When was your shipped/accepted?
contactcr
My D1S from Neal was Nov6 first tracking in China and it took 20 days to show up with a Chicago entry to US and finally it should be in your neck of the woods (“Gulf Coast”) by tomorrow (via USPS). I know DB Custom is having a similarly long experience and also from TX. I think it’s just taking longer than usual right now.
Coscar
Coscar's picture
Purchased on the 4th – Processed on the 12th.
I think the wait is worse than normal because I ordered both D4 & D1s.
Everything is copacetic Crazy
A little John Prine
Thetasigma
!{width:25%}http://imagizer.imageshack.us/v2/1280×1024q90/923/CQWrVt.jpg!
You’d have to cut the head in half to do that, the head is all one single piece.
Finally received mine yesterday, 20 days to hit Chicago, 3 more days for delivery once stateside.
DB Custom
DB Custom's picture
Cutting the head in separate sections and threading each section to accept the copper is completely within the plan. Big Smile
The more difficult the plan, the greater the challenge. Thus, the higher reward for a successful mod. Wink
contactcr
Got my D1S finally. My first emisar with the new coating that was talked about in this thread. A more accurate texture description is like a smooth ceramic garden pot or a gun cerakote. It takes some getting used to for sure but ultimately i think i prefer regular smooth anno.
The beam and throw are nothing short of excellent. If they come out with an anodized one id probably pick it up in 4000k just to have a 2nd tint but the 5000k is nice and matches my D1
xCentrino
xCentrino's picture
That is spot on, didn’t even think about it like that. Compared to my other anodized lights, the D1S does offer noticeable more grip. It’s different but I like it.
Deputy Dog
Deputy Dog's picture
I just received my D1S 10 minutes ago. I love how it works, but… I HATE the texture of the finish. It feels like a chalkboard. I think I going to have to coat it with something.
atbglenn
atbglenn's picture
Deputy Dog wrote:
I just received my D1S 10 minutes ago. I love how it works, but… I hate the texture of the finish! It feels like a chalkboard.
I got mine today as well. I love the way it feels and looks. To each his own I guess.
Boycott Nike
Deputy Dog
My hands feel dirty after I put it down. Anyone know what type of clear paint to try?
DB Custom
DB Custom's picture
I wouldn’t coat it, would try sanding with a 2000 grit or something, maybe 1500, if you just have to smooth it down.
I like em myself, adds to the grip factor.
Edit: The reason is any coating you put on it will be peeling off almost immediately.
Deputy Dog
As rough as it feels you would think most paints would stick well.
DB Custom
DB Custom's picture
Might stick, but won’t wear well. Wear and tear will quickly have the coating in tatters.
