Seems to be a (lower quality it seems) copy of the Lansky Blade Medic, which is a good sharpening tool for me (of course you have to use the carbide side carefully not to remove too much blade steel)
Haven’t tried the Lansky, is the ceramic fairly smooth? The smith’s feels like pumice compared to my old ceramic rods.
Yes, for me it is smooth, no problem.
merci
I just got one, it arroved along the Sanrenmu 7010. first impressions - built like a rock. Much heftier and wider than the 7010 (pictures don’t do the justice) and because of that blade feels a bit too short. Both are very difficult to open using the thumbstud, both have pretty stiff axis locks but in the 7056 it’s definitely way too stiff - I played with it for a couple of minutes and my finger hurts.
Open next to pictures and compare them side by side:
PS. Does anyone have both Ganzo FB7601/7603 and Sanrenmu 910/9103/9104?
You meant frame-lock I suppose.
I have the Ganzo FB7601 G10 & CF + all of those Sanrenmus.
Of course I meant frame lock and I wad reminding myself to wrote the right type instead of axis lock. Didn’t work out
Can you please make side by side picture with the 7601 ans 9103? Which one feels better/smaller in your hand?
Here you are! The SRM 9103 feels smaller in the hand (slightly smaller size and much thinner handle).
Sanrenmu 910+, Ganzo FB7601 and SRM 9103:
Thanks. Ordering 9103 seems like a good choice. Hopefully it won’t be too big for my tiny hands.
I’ve got rather small hands, S-M or glove size 8 in Europe and the 910+ fits perfectly, it’s my workday edc.
I’d carry it at the weekends, too, but then I wouldn’t have any reasons to buy new knives…
That looks so cool. I remember your original post on that mod and wondered how you would feel about removing the liner after using it for awhile. Sounds like it worked out great. Did you need to shorten any of the spacers to pull that off?
I use it since I made it and it works like a charm. Didn’t have to change anything in the original hardware, just had to sink them right into the cf.
I think ball bearings greatly reduce the force on the pivot are and also make it easier to get a centerered blade. I just made such a single scale for a CRKT Swindle using “rosewood” (generic term, not sure what it is, but it’s very dense). There again the ball bearings make it easier, even when they are sunk a bit too much, the blade is straight if the hole is straight. Just sand the inside and it’s perfect.
I refined it a bit, sinking the insert and polishing/waxing the handles, just have to take new pics.
The best thing is that it reduced the weight from 110 g to 78 g.
The 9103 is so pretty. Looks way more expensive. How does the 910+ compare to the 9103?
It’s basically the same thing but with the G10 handle (and liner lock).
Hi all!
Not sure my question fits in this thread as i’m looking for advice regarding kitchen (chef) knives. Although i’ve long had a liking for pocket knives with wooden handles i’m quite a newbie regarding blades, but it’s growing on me…
I’d like to get myself a couple decent kitchen knives but have no idea which brands can be trusted… Imagine knowing nothing about Li-Ion cells and looking at 8000mAh 18650s on ebay or else.
I don’t want them cheap nor do i seek something fancy. Just knives that will do the job and that will take it for a while.
What would you recommend?
Thanks.
PS: I’m in Europe. I’m used to order from china or else.
A number of years ago my wife bought me a VG-10 laminated blade kitchen knife. I’ve long since forgotten the brand of the knife, but VG-10 blades do very nicely in the kitchen. Very stainless. Takes a great edge. Easy to sharpen.
Search Aliexspress for VG-10 kitchen knife. I’m not certain about the differences between the different brands, but the ones they offer should be a great bargain in the under 30 euro price range.
I’m no professional chef, but I know a chiffon cake from a chiffonade, and the only knives I’ve trusted over time are Henckels and Wüsthof.
Amazingly, though, check out “chinese cleaver” on Amazon. For 10bux you can get a rather nice and beefy mini-cleaver (“chinese” not based on origin but on style) that does everything from smashing garlic (on its side, nice heft) to whacking through a big-ass melon or squash.
Anyway, to start with knives, generally you do NOT need a whole set. A chef’s knife, paring knife, and serrated-/bread-knife are all you need for like 95% of your cutlery needs.
Instead of a regular Norman-Bates-type chef’s knife, I got one of those sodoko style ones or whatever it’s called. (Can never remember that name…). I got that one as a gift, liked the style and technique, and never went back. Ymmv.
Followed by the VG-10S knife, then the SF36…
C’mon, I had to say it…
The 910+ feels a bit bulky at first as it’s somewhat thicker than the 9103/4.
On the other hand the G10 gives more traction than the ground steel surface of the 9103/4.
A good compromise could be the 910 Exclusive (which should be called 9103 Exclusive), steel handle with milled in lines.
https://messerundco.de/Sanrenmu-Land-910-Plus-Exclusive-Taschenmesser-Silber-12C27-Frame-Lock
The 9103/4 seems to be more of a gent’s knife that you forget in your pocket as it’s so thin whereas the 910+ is the worker that you might get in your way while sitting.
(I didn’t like it before my mod, it was too bulky and hurt me while driving, I don’t think that would be an issue with the steel handle.)
Grab them at flash sales for $10 each and see what you like more, 2 great knives for $20, nothing you can do wrong.
