[Review] Astrolux S42 4xNichia 219C Rechargeable Mini LED Flashlight supplied by Banggood
Astrolux S42 driver designed
Running NarsilM
FET+6+1
sale topic
This is one strange flashlight ! - I wanted it as a pocket rocket, so the 18350 was the attraction for me. And then all the frustration started. - I bought unprotected Soshine 18350 and later Keeppower IMR 18350, and was pretty sure the light was defective. I could only do turbo 2- 3 times before it stopped working. zak.wilson´s Aspire INR 1300 mAh advice saved me. After 2-3 months of jumping through a lot of hoops, I finally succeeded in getting these and now the light works as expected. Banggood advised to use the Keeppower, but they do seem to know what they are talking about. The UI is also strange, now I finally realized, that you can not shut off the light from moonlight mode, it goes only into turbo. The light also taught me, that I do not like a light with as little throw as this…. How I love me favorite Thorfires VG15, VG 25 and the new giant killer TK15S, which Aliexpress is selling for at little as $ 15, what a bargain. They have the perfect balance between flood and throw, the VG15 a bit too floody maybe, so you get a thick white cloud in front of you, if there is much moisture in the air. - Wonder if you guys could make the pocket rocket work properly with other batteries than Aspire ?
As an aside note, those Aspire 18350 are not being made any longer.
What?
I thought they are only relabeled to Aspire 1100mAh ?
Both Aspire and KeepPower 18350 cells have stopped production.
You can read more about it here.
I don’t know anything about the 1100 mah cells. I don’t even use 18350, but I remembered reading about them.
Banggood has offered me the chance to help them improve the driver in this light.
So the plan is to make a replacement lower driver with a Texas Avenger layout and use Narsil.
The issue comes from the charging, it looks like if we want the charging to work, we have to put up with a 1ma drain or no indicator LED’s?
Tough choice.
That is unless someone has experience with USB charging circuits, I have never messed with them myself but if we could come up with our own circuit that would be even better.
Smart choice from Banggood. Now I might actually buy one of these.
Is it the side switch indicator led that is causing the drain? This seems higher than usual. Normally it would be about a 1/5 of that, 0.200 milliamp.
Or is it something to do with the charing circuit that causes it to be so high? I’m unclear on this. Frankly, driver design is a bit over my head so I’m probably not much help.
I can tell you that on the 2 lights I use everyday (in my sig) the lack of the Narsil “indictator” function is not an issue. Having some type of light is helpful though, as it shows when power is connected. If they have some clear switch covers then a small led light shining through should be doable at a low parasitic drain.
A note can be added to the manual that if you don’t want any drain, turn the tail cap 1/4 turn and make sure the light turns off. Simple.
I actually have no idea where the drain is coming from since I broke the driver when trying to remove it from the S42. So I can’t test it to figure it out.
I am just going on what Lexel reported earlier in this thread.
1ma is about right for an active MCU though, so it kind of figured that would be right.
At this point the simplest option is to leave the charging circuit alone and just deal with the 1ma drain, still a massive improvement to get Narsil and a good LED driver.
I do not have the S42 but would consider it with upgrades specified.
For charging boards I recently finished a light using one. I get 0.350mA drain with one green indicator LED in the SW button. There is also a red for charge indicator.
And forget the Micro USB plug too, I want to see a Waterproof magnetic connector like I have integrated into my Lil’ light.
The ME4056 Nanjing Micro One Electronics Inc. Charge controller chip is on the little board I used. It shuts off to a Low current state state.
I do not understand most of the technical electronics stuff but here is a link to a post I made on the boards I bought. Datasheets are linked too.
ME4056 Tiny charge board similar to TP4056
Link to the Clone M3 build specs in post #11
Interesting, it is simple enough to use, the question is how reliable is it? I suppose it won’t be worse then the existing charge controller on the S42.
I wish that TI or a more mainstream manufacture had a chip like this, I would trust it a lot more. I could not find anything when search though. Course I am swamped with the GT GB right now.
Can’t speak for reliability but it does have 10+ charges on it. I didn’t thermally sink the chip in the light at all. It does not get hot while charging, mildly warm.
My Clone M3 original charge circuit died on the first use.
Charge chip is made by the same Co that makes the supposedly better 7135 with the claw marking. The TopPower charge chip TP4056 is cloned to death. At least these would be original manufacturer. Minimal parts needed with it as the tiny design shows.
It looks like it has a 1% tolerance, so it could charge up to a max of 2.42v, a bit high for my liking but not totally unacceptable. About what most cheap chargers out there do and getting a better chip would add a lot of cost.
If anyone knows of a better chip like this, please let me know. Otherwise I will look into this chip a bit deeper and see if I can just remake the charging circuit from scratch. It says the chip itself has a very low parasitic drain.
I’m curious about the Astrolux S42 (Nichia 219C) compared to the Astrolux S41 (Nichia 219B) — any idae if using the same 18650 and setting to turbo mode, would their light output be similar? Or are the 2 have different drivers (the have the same BLF A6 UI, except the S42 uses a side e-switch?)
I measured here with very thick cables on my mod 18A on a fresh 18650 cell
Just got mine today, great little light but the UI really is quite annoying. Would definitely be interested in an upgraded driver!
I was just curious. Did you do any work with HaikeLite to help improve their drivers? They are saying their MT09R and recent versions of the MT03 are using a new TA based FET driver, but their own UI. I didn’t know if you assisted them or if they just “borrowed” your driver design.
Kinda sorta. They did ask me if they could use the design in their lights and I offered to help them but they decided to do it on their own and use custom firmware. Why, I have no idea.
I then got a message the other day asking for some kind of help with the drivers, so I am not real sure what is going on with them at the moment. I am hoping that I can talk them into using Narsil at least.
Finally heard back from Banggood on the S42 so I could start work on the driver. They want to use the LY4057 charging circuit which looks like it will work.
Got the main driver almost laid out, then start work on the charging pcb. I am not sure what footprint the USB connector is, still got to track that down.
Tell them how much a success narsil was on the Q8. I’m sure it would increase sales. It’s like a factory custom light. What could I do to mod it? Nothing! Lol
Well, if people were to start contacting them asking for Narsil to be used with the drivers it sure would help the chances of it being used.
Tell them I am happy to help them get it working, they have seemed hesitant to use outside help for some reason.
Narsil would be amazing, hope they are reading this thread?
