Got mine in couple of days ago.
It’s big.
Unfortunately the section with the tail cap threads is not really wide enough to widen the inner diameter for a 20700, let alone a 21700.
I changed the switch assembly too, you had to really push the button deep for the switch to click.
I wish to swap the LED too, with the high Vf of the XP-L the light is running out of breath pretty fast.
Other than that, i like it.
It’s got its own style.
Think I might get 4 of these to give as gifts to the guys on my bowling team. GB has an email sales price of $19.99 for the 6000-6500K version. The 4500-5000K version is $22.99.
I just got my F1 and I mus say I’m pretty disappointed. Anodization is very thig, flashlight itself is very light even with battery inside (thin walls) and it’s … massive! It’s one of the thickest 18650 light I own:
It has pretty deep reflector, emitter sits even below which ends up as a very narrow spill and moderate brightness. Switches don’t have much feel, side swith is cheap, plasticky and slightly loose. They say it also has MicroUSB charging point covered by the metal ring. Maybe they were ashamed of it because in mine it’s impossible to twist the ring without damaging the flashlight itself. I don’t know if it’s lube or glue, but the latter one would explain everything:
Phantom, that’s pretty harsh don’t ya think? I mean, come on, it’s the first light they produced and as such, it’s a darn nice one! How much do you work for? $10 an hour? Can you make one of these in an hour? Not even considering materials cost, just time, the anodizing process alone takes pretty much that entire hour. An emitter will cost you a slick $6 easy, not seeing how there’s monies left for a nice mirror finished reflector to be made.
I found it to be a very nice interesting and unique entry for Gearbest, it works fine, handles fine, and as such it does what it was made to do. You show it beside lights costing much much more, are those your comparison level? Not really a fair test now is it?
I get a distinct feeling that I’m glad I’m not YOUR supervisor…
Still waiting for the 2 that I ordered to arrive. The 6500K shipped last week, but the 5000K isn’t supposed to ship until next week (fingers crossed). The sale price on these was attractive enough for me to order based on favorable reviews I’d read, and their USB charging port seems like a much better design than the ones that have the silicone type flap covering the port. Not expecting them to match up against some of my higher priced lights, but hopefully they are a good bang for the buck. I’ll keep the best one and gift the other.
So… wait… is it massive and the thickest light you have, or are the walls thin and very light? You sure you’re looking at the same light both times?
All the other stuff, no idea what you’re referring to. The switches on all of mine are nice and have a crisp snap to them, not loose at all. The ring over the usb port is tight by design, as it’s got an O-ring under the entire inner circumference, to seal out water.
I’ve endlessly bitched about the overly green beam, but construction-wise, and the whole overall design, is among the best I’ve seen in this category.
Zanflare F1 switch is as smooth as my other flashlight like Utorch, Olight, Fenix or Haikelite.
It is very well designed and built. Price is unbeatable.
‘DB Custom’
Maybe my expectations were too high after reading some reviews. For $10 it’s alright but not more (they charged $40 at the beginning). Ultrafire level.
‘Lightbringer’
Empty space. It could easily fit 20mm cell inside. Walls seem hollow. MicroUSB cover is not just tight - I failed to move it at all. And ‘DENGOH’ - in my example rear clicky feels like a piece of stiff rubber, like there was no spring at all. Side switch clicks nicely, but it has some sideways movement and it’s made of thinnest and cheapest piece of plastic I’ve ever seen. Maybe they reduced the quality of the latest batch to make more money? It would be a typical chinese move.
In practice, it wouldn’t make any difference. Even on turbo flare, it won’t draw so much as to stress out the sanny-A, and most times it likely will be used in lower modes.
I’m currently burning down ancient laptop pulls, still lights up fine in all modes.
Get 35E. No, the light won’t benefit from high discharge cell. 35E has marginally larger capacity than GA and costs less. The difference in power is marginal too, meaningless in this case.
Everything was nigh perfect. Okay, the ring over the usb port was tight, but not “glued”. Did split the “outer” O-ring (nearer the tail), though. Replaced.
Switches, perfect. Crisp feel, no wiggle. LED was a hair off-center. Not much green at all (improved!), or maybe I just won the tint-lottery. Yellow corona.
I’ll give my brothers my barely-used Sanyo GAs, for the extra capacity, rather than my brand-new 30Qs.
The GAs are the cheapest cells I’ve found locally - AU $16 for two, including postage. I’ll keep an eye out for 35Es, as I think the only light I have that draws more than 3A is a BLF A6.
I was looking into rebuilding some Makita 18v packs recently, and if you believe the seller’s claims about the cells inside it’s not worth doing yourself, unless you salvage the cells from a couple of bad packs to make one good one.
8 AUD is around 6 USD at the moment. The 30Qs cost me 9.75 AUD/7.35 USD. Once you factor in postage that’s competitive with AliExpress, with the bonus that you get the cells in two days rather than two months.
I just found out why it was so tight. The o-ring closer to the swith is bigger than the other one. Now I cannot close the ring, it just doesn’t go over the secondo-ring. I lubed it up, didn’t help much.
Just received my first F1 in the post today, CW, got a NW on the way as well. It is certainly much larger and more tinny feeling than an S2 or A6, though the UI is quite nice. Nice moonlight and high, but the mode spacing is not even and flare not impressively brighter than high.
I thought the ring over the USB was supposed to twist off, and it is marked that way, but it just pushes over, and on mine is very loose and flimsy feeling, it was open in the box.
It is good value for the $10-13 I paid, I suppose, but I must say I am disappointed. I remember when it first came out people were saying it was like a $100 light and a bargain at $40. If mine is anything to go by that is utter nonsense. The BLF A6 at $16-$22 is miles better in every way, only missing a USB.
