Get 35E. No, the light won’t benefit from high discharge cell. 35E has marginally larger capacity than GA and costs less. The difference in power is marginal too, meaningless in this case.
Everything was nigh perfect. Okay, the ring over the usb port was tight, but not “glued”. Did split the “outer” O-ring (nearer the tail), though. Replaced.
Switches, perfect. Crisp feel, no wiggle. LED was a hair off-center. Not much green at all (improved!), or maybe I just won the tint-lottery. Yellow corona.
Quite nice, as expected.
Thanks Lightbringer and Afro.
I’ll give my brothers my barely-used Sanyo GAs, for the extra capacity, rather than my brand-new 30Qs.
The GAs are the cheapest cells I’ve found locally - AU $16 for two, including postage. I’ll keep an eye out for 35Es, as I think the only light I have that draws more than 3A is a BLF A6.
Yoiks! Sounds cheaper to buy a battery pack and rip it open for the cells… unless those, too, are obscenely priced.
I was looking into rebuilding some Makita 18v packs recently, and if you believe the seller’s claims about the cells inside it’s not worth doing yourself, unless you salvage the cells from a couple of bad packs to make one good one.
8 AUD is around 6 USD at the moment. The 30Qs cost me 9.75 AUD/7.35 USD. Once you factor in postage that’s competitive with AliExpress, with the bonus that you get the cells in two days rather than two months.
I just found out why it was so tight. The o-ring closer to the swith is bigger than the other one. Now I cannot close the ring, it just doesn’t go over the secondo-ring. I lubed it up, didn’t help much.
Just received my first F1 in the post today, CW, got a NW on the way as well. It is certainly much larger and more tinny feeling than an S2 or A6, though the UI is quite nice. Nice moonlight and high, but the mode spacing is not even and flare not impressively brighter than high.
I thought the ring over the USB was supposed to twist off, and it is marked that way, but it just pushes over, and on mine is very loose and flimsy feeling, it was open in the box.
It is good value for the $10-13 I paid, I suppose, but I must say I am disappointed. I remember when it first came out people were saying it was like a $100 light and a bargain at $40. If mine is anything to go by that is utter nonsense. The BLF A6 at $16-$22 is miles better in every way, only missing a USB.
I have no idea what a $100, or even a $40, light is like. I suspect though that unless you have very specific specs/needs, the gap between a $100 light and a $40 light is pretty small, and mostly in accessories that are probably only worth $10/tops.
I’ve got them both at hand right now, and I’d say the BLF A6 and the Zanfare F1 (received ~1week ago) are pretty comparable.
F1 is, indeed, a bit larger than the A6, certainly enough to notice in a pocket. F1’s anodization is a little glossier, but it isn’t clear that it is any thicker or thinner. The F1’s anodization is definitely more consistent — under strong light, none of the pieces on my A6 quite match. The F1’s clip feels less substantial.
I agree the F1s tail switch is a little mooshy feeling, a compromise, I’d guess, to make the tailcap shorter. Given that the switch is only used to turn the light on or off, I think that was a reasonable tradeoff.
The F1’s tube definitely has a bit more clearance, but the A6 seems like it would have trouble fitting the diameter of a thicker double-wrapped protected 18650 (I don’t have one to check with). The walls of the F1s tube seem as thick as the A6. They did do something interesting though, they have increased the inner diameter of the tube in the middle section, under the knurling. I’d guess the wall thickness is about the same throughout though; the knurled section has a larger outer diameter. I suspect this was done to reduce the weight. It might also reduce heat transfer from the head to the 18650 cell. I think it does contribute to the battery feeling like it has more play.
The microUSB cover on my F1 was very hard to loosen the first couple of times, but now it turns while still remaining securely snug.
The beam of the A6 is probably better closer up, as well as being slightly “cleaner”
I think I’ll end up using the F1 more, for two reasons. First, I like having the side switch. Second, the USB charging makes it much more self contained, which makes it more useful in many situations.
The USB port also makes this more practical as a “muggle” If I given someone an F1+a battery, they can just use it.
Some of the descriptions sound a little like ‘quality fade’ to me actually…
“Tinny”, “flimsy” and “hollow” is not how i would describe mine which i got a couple of weeks (months?) ago.
Umm, yeah, it’s supposed to screw on, not push on. Think you got a borken one.
Dunno who said it was worth 100bux. I don’t think any light is worth 100bux unless it could light up Sputnik or something.
At this point, maybe I’m jaded or something, but I wouldn’t go out of my way to pay more’n 30bux for a light, and it’d have to be droolworthy for me to do it. Still kicking myself for paying 80bux for my Quarks way back when. I just didn’t know better, and thought it was a “premium” light. It is, but not 80bux worth.
So I’d put the F1 in the 20-25buk price-point. Still love the design, but, yeah, there’s a limit.
At 10bux if I can score another one, I will. I kinda sniff at the 12.99 coupons, though, like, “nah, I’ll wait for a 9.99 one before biting again”.
’Though I gotta say, with the exception of the green beam, all the ones I’ve gotten so far were nearly perfect.
I’d hope not, as that’s a surefire (haha) way to permanently damage the Zanflare name.
After that happens, they can design pure gold and no one’ll buy ’em.
Hi Y’all
I bought one of the first batch of these and liked it so much that I bought another one at the recent special price. It was delivered yesterday.
I don’t see any difference between the two. After playing with them for a while, I’m not sure which is the old one and which is the new one. Switches are both solid with a firm click. Finish is the same….it’s all the same.
For almost any single cell pocket style light that uses a single cree emitter, there is a clearance sale at LiionWholesale on the LG M26. It’s a flat top 2600mAh cell with a 10A rating, on sale for $2.99 each. Cheapest decent cell I could find.
They also have a protected button top in this cell for $4.49 each. And a clearance on Samsung 30Q button top for $5.09 ea. Worth looking into, if you’re in the US and in the market for a cheap cell or 10.
Push the ring up and over the o-ring, and then you can screw it. No point push and screw at the same time. Make it two steps is better in my opinion.
Mine came very tight, after unscrewed, i don’t screw it so tight.
Well, it is not perfect, but it is as good as all my other lights. In my case, UT01 and SC02 have more minor quality glitches compared to F1.
And i bought it last month.
On checking it again, it does seem to work like that. Maybe if mine had come fastened I would have realised. After working it a bit it managed to ride up over the second o-ring and tighten quite securely. I have been too harsh on this light. Now that the ring works the only thing actually broken is the lanyard end stop, it is a good light otherwise, just oversized for what it is and with poor mode spacing.
Mine was very tight that i have to search around my house for clothes that’s grippy in order to twist that damned ring. And i even search BLF to confirm it’s closewise or counter clockwise. Looks like the operator who assemble F1 has used up all his grips strength, that’s why yours is not fastened. :person_facepalming:
I wonder why every single Zanflare product is so extremely over-sized. Flashlights F1, F3, F2 as well as charger C4 are all very nice quality and well designed products, but why make them so unnecessarily humongous. :person_facepalming:
An the tube light in question here, the built in charging takes up extra space. It would be quite close to the A6 or S2+ without the charging section.
My new Zanflare F2 2xAA light is very nice, the beam profile is much to my liking and I think they did a good job with this one. Sleek and stylish, firm clicky switch, nice design, with an indicator for low battery.
Received my CW F1, and I’m impressed. Finish is good, nice beam, and I had no problem accessing the USB port. I actually like the UI quite a bit. I would like to see a little more aggressive knurling as it feels a little slick, but not a big deal. It’s a keeper for me, and definitly worth the money I paid. The USB charging & port design are a plus for me. I’ll recommend this light to my friends.
I got one of these in today in good working order. Did not find anything “tinny” about it. In fact the tube is considerably thicker than my A6. It is larger than I care for but I intend to give it to a friend because of the USB charging ability. I am well pleased for the price
