Lexels Oshpark boards
I want to make on topic with my boards I have shared on Oshpark
The updated TA drivers are still pending as I want to test them before they get public
All build drivers can be bought in my sale topic or PM me
Q8 (12mm) side switch boards
order those in 2oz for right thickness
2 LED with balance resistors
2x2 LED with balance resistors
MF01/MF02 (11mm) side switch boards
Lighted tail switch board replacing the washer around the switch
For the exampke pink and warm white, other combinations possible the board with balance resistors could use more than 2 different colors
16mm
17mm
https://oshpark.com/shared_projects/yplKNhqL
16mm
17mm
https://oshpark.com/shared_projects/aqiAxQx1
20mm
https://oshpark.com/shared_projects/fWtrkfax
17mm Remote switch tail board with FET
16mm
https://oshpark.com/shared_projects/F096lqpK
for Osram IR emitters with Anode on thermal pad
Osram DTP driver Tripledown (TA Bistro/Bistro HD OTSM 3 Channel compatible)
Inverted FET + n 7135
Inverted Biscotti single channel
TA and Triple Board designs
15mm
new board . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . | . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . old board
17mm
20mm
21mm
22mm
30mm
new board
old boards
Made a 38.5/40mm design on my own, working in 3P or 4P hosts, 1S and 2S availiable
MT03
SRK board with fixed ground ring issue
MF01 v1 MCPCB 2S/9P
BLF Q8
untested 2S/2P
SRK/Q8 Tail board 2S/2P with switch
TN40, TN42 TA 2S/2P
not tested yet
Nice! Thanks Lexel!
Thank you for sharing! Lexel, I believe you also mentioned a driver for the Astrolux S42 in your review (that even included a charging circuit). Would it be too much of a bother to add that one to the list? I can understand if you do not want to share it.
I am considering different drivers for an incoming S42 and wanted to have a quick look at it.
Many thanks!
the standard 21mm fits the S42 just charging board cant be connected to it
In this mod there I simply shortened the brass bolts and glued the old bottom board on top of the driver, but it took a while and was really hard to make it fit
If you really want to keep charging I will have the S42 special board in my sales topic after it got tested successfully
I can send you the board or assembled driver if you want
I already have 3 of them (mt03 mf01 L6) and output is very good.
Ui with ramping so cool.
Thanks Lexel for the details
I’ll be buying my next driver here for sure.
Thanks for designing and sharing these.
I got a few of both Q8 side SW boards for other projects.
Tail board without balance resistors tested successfully
Pink and warm white in the 2 I tested
3x3mm Potentiometers will take a while from China
Nice work Lexel!
Do you use Leaded Solder or Lead free
I heard that Leaded solder is banned in europe (ROHS) ?
Great! Thanks Lexel!
leaded paste, but on the reflow plate it stays a lot longer hot so it is not shiny as with solder iron
17, 21, 30mm and MT03 boards tested now and with active link to Oshpark
Thank you Lexel for sharing these. Appreciate your input.
I found an error on the 17mm Tail LED board with balance resistors
its fixed now and added 20mm version
20mm TA board checked successful and shared
Great to find them in one place. Can you make some time a FET+1x7135 17mm design that is the same as Q8 but on a 17mm board?
I want to build one for the Sofirn C8F host so it need led pad for the side switch indicator leds like the Q8. Or is there a board available somwhere like what I need?
on the 17mm board Narsil is running fine, the indicator LED output is there, just no extra pad for a SMD resistor dedicated to it
The link was not working for that board but I found it. Which pad I should solder the indicator led?
where R1 and R2 are sharing same pad with pin 7
Thank you!
