I’m nuts, (as in I have too many lights!), but at $40.00 I couldn’t pass up getting a D1. Looks like one of the best 18650 lights ever especially for the price. It was great that mtnelectronics carries them.
Can anyone tell me if the D1 accepts BOTH flat top and button top 18650’s?
Stick with flat tops. I have some button top MH1s that just barely fit in my D1, but my button top MJ1s don’t fit at all. Protected cells won’t fit and won’t meet the current needs.
I did spring bypasses in my D1S and it stiffened up the springs to the point that the flat top 30Q was a problem. So I simply removed the driver spring and solder blobbed it. Works great now. Enjoyed the candlelight mode quite a lot last night.
Thanks to you too Thetasigma. Even though I have plenty of spare 18650’s, I realized all of them are protected cells except for two cheapie lower capacity unprotected flat tops. This light deserves better so I ordered two new Efest 3000 mAh cells from Ebay at a great price to be used exclusively in the D1.
I had checked with Richard at mtnelectronics but he was out of them. The seller on Ebay lists the Efest cells as the new version cells and calls them Li-MN instead of Li-ion. Whats that all about? I’ve never heard of Li-MN. Typo or what?
Some time back Powerizer made a 26650 that was Li-Ni-Mn-Co and really rocked, the later tech is Li-NiMn in chemical construction and as safe as they been able to make them as far as I know. They might vent but are highly unlikely to explode.
Got mine (D1Svn) yesterday and that darn Olson Black is frikkin’ awesome! Moonlight throws more than 200 feet. My yard isn’t even close to big enough to let this light shine. Gonna have to take to the river!
Love the dry finish on the black D1S. Very dry feeling and you can hold on to the thing quite well. Never got hot but with 650 lumens it prolly wasn’t going to.
I thought my D1 threw pretty well, well the Olson makes it look like a AA Maglite! Can’t wait to try it with the Giggles GT when it comes.
That’s your opinion.
For me, a “nuke” is if a flashlight has a side switch and a tail switch. You have to handle the light before you can switch the modes - that’s annoying as…
As a lockout - OK, but not as a on/off switch
for me
I think, the big Emisar Thrower would benefit a lot from a 26650 Battery tube.
It just looks too thin on the battery-end.
“The next C8”?
I don’t think so.
The C8 is a very cheap (y15:money_mouth_face: yet very good flashlight.
Unless the Emisars drop to under 20$, they are not a replacement.
Missing Tailswitch - how many buyers of flashlights are security-guards and policemen? Maybe 2-5%?
For the throwers, maybe 95%: including hunters and army personel ofc
You cant mount that torch too, thats another minus too
Plus, its quite hard to find that side switch in the dark, plus you can always misclick the side button
A 26650 based flashligt is quite a different story- As other said Ut20 is quite good and in that condition Emisar 50mm thrower covers it, yet Ut20 is 30$ and easy moddable too
By default C8 isnt anyting specialy, XPg2 modded is quite a different story, but then again its not 15$
15-20$ price range for a D1S in a host form is quite reasobnable and affortable
Side switch only was the reason I got a D1S, I don’t want to use a flashlight with my fist up in the air or by my chest, I want to be able to change modes one handed with the light comfortably down by my side.
I also find with throwers that the further away the beam is from your eye, the less apparent backscatter.
