Finaly got mine. Amazing beam, works like a charm. Did not expect that much from it. Just great
Just sharing regarding the Convoy C8. I suppose I’m even a more newbie than you, since you knew about Convoy flashlights at least 2 years ago. I first saw a Cree LED flashlight earlier this year (or actually, ‘fake Cree’ as I later find out. My “real Cree” LED flashlight is only a few months ago.)
But anyway, I’ve read about the Convoy C8 from here and purchased them when I saw them on sale in Banggood and GearBest.
So I got my Convoy C8 Clear with the new Biscotti firmware from Banggood. It uses XP-L Hi, SMO reflector and has AR lens. It appears to be exactly the same as it would have been in Simon’s AliExpress store (was $1 cheaper from BG during the flash sale, if I factor in discount request from Simon — I’ve bought from Simon directly twice, previously for the Convoy S2+ Desert Sand he gave a 15% discount for BLFers if you request; recently I ordered a different flashlight from him and he gave 7% discount for it, I suppose price increased or depends on model).
The next Convoy C8 I got was from GearBest recent flash sale (I could only get the ‘flash sale’ price, but not the ‘discount voucher’ prices which are slightly lower since the discount codes unfortunately didn’t work for my country.) — anyway, I just received it — it has XM-L2, SMO reflector, and non-AR lens, and the old (5/3-mode group) firmware.
I’m not familiar with fake Convoy C8s since I ordered only from Banggood, GearBest and also Simon’s AliExpress store (I got Convoy S2+ Desert Sand with Biscotti firmware from Simon directly).
The 7135x8 refers to how much amperes max current (it affects how much total light output), but from what I’ve learned (I think the available models are 7135x3, x4, x6, x8). Each is 0.35A, so:
7135x3: 1.05A
7135x4: 1.40A
7135x6: 2.10A
7135x8: 2.80A
That’s for the max light output. But of course, the flashlight can be set to lower modes, which will then use less than max current. Less current = more runtime.
Since you’re looking for a C8 most likely for a ‘thrower’ type of flashlight, I would think you’ll be looking at the higher amps versions (2.1A or 2.8A) for max throw — you can set to lower modes anyway.
For the “old” firmware (5/3-mode groups), I remember these are set to (percentage of max current):
Low = 5% Med = 40% High = 100%
(old firmware only allows changing between the group with (5-modes group) and without blinkies (3-modes group) )
For the “new” Biscotti firmware, the default 5-modes are:
0.1, 1, 10, 35, 100%
(Biscotti allows to be programmed to have the blinkies modes in the default cycling or others — check ‘Biscotti’ firmware elsewhere in the forum for more info, eg. battery check mode)
You can also select the tint from the official AliExpress store (BG and GB also has tint selection usually). I’ve grown to like a more neutral-white tint (3A or 3D), but the cool-white tint (1A) is slightly brighter.
Ok, sorry but I don’t think I answered your question: which flashlight is right for you…
a) XP-L Hi or XM-L2?
XP-L Hi + SMO reflector + AR lens = more focused hotspot (ie. light throws a bit further)
XM-L2 + OP reflector (no AR lens) = less focused hotspot (maybe slightly wider spill), but since it uses the same C8-sized reflector, it is still throwy (just slightly less than the one above)
b) new or old firmware?
The new versions of C8 (typically the “Clear” or also called “Silver Anodized”) already use the XP-L Hi + SMO + AR by default, and if ordered from Simon directly, it should be using Biscotti already (but verify to be sure).
If ordering from elsewhere (BG, GB, etc.), then you’ll need to check if it still uses the old firmware or not.
I would recommend the new firmware since it’s much more configurable (unless you don’t like too many modes — but those can be programmed in Biscotti),
c) tint
I think this is more personal and subjective… cool-white or neutral-white. There’s even a warmer white/yellow tint available (and seems slightly more expensive)
d) how much amps
7135x8 = max output (hotter), less runtime when used at max mode; but with Biscotti, you could program such that the “highest” mode is just 50% of max current
7135x6 = slightly less max output, if you don’t need
(not sure if there’s a 7135x3 and x4 for the C8 — these options are for the Convoy S2+ since some may not need max output for an EDC light, which the S2+ is. BTW, the Convoy S2+ also has the “new” and “old” versions, much like the C8. The “new” version will typically have XP-L Hi + SMO + AR and Biscotti — which combined makes for a smaller thrower; whereas the older one uses XM-L2 + OP + no-AR (typically available in “old” firmware only, unless you buy from Simon directly and ask him to use Biscotti on it), which is more of a flooder type)
And somewhat aside: there appear to be many other “C8”-type flashlights (ie. throwers) recently, which you may also want to check out, eg. the Emisar D1 or D1S — these are about twice the price of the C8 but has a better UI (judging from what I read here, as I don’t currently own one). (Emisar D1/D1S as of current pricing is around $40; Convoy C8 “new-type” around $20; Convoy C8 “old-type” around $14 with flash sale/discount codes)
You sure can if you message Simon. He’ll tailor any Convoy you want the way you want to the best of his abilities, even as far as switch boot color is concerned :nerd_face:
I received Convoy C8 from Aliexpress store and when I disassembled it because I wanted to replace the driver with FET version I found out that they used wood screws to “secure” the led :person_facepalming: I inspected holes in the flashlights head and they were threaded for metal screws as usual.
Before this I received one with one cracked AMC chip, almost split in half!
Lack of quality check
Somewhat related, Banggood recently released a Astrolux C8 light with a FET + 1 driver. I review the light here:
From what I can tell, it appears identical in external construction to the Convoy C8, but it uses a FET driver for 60% more output (and throw). So, it doesn’t appear that mods are necessary to get a FET driver in a C8 host, anymore.
What mods were necessary before? I can only think of making sure the emitter is on a DTP copper mcpcb in order to handle the heat.
Well, I saw lots of people buying Convoy C8’s and replacing the 8x7135 driver with a FET driver. This one comes with the FET driver, so you get the extra brightness. But, you have to be more careful of heat, of course.
Oh, you meant changing the driver as a mod. I wasn’t counting that. :confounded:
This is not good at all. Convoy is not the only one doing this. I’ve noticed Sofirn is doing this too, and worse - they’re using longer, round headed screws.
The screw thing is not of any concern. It is still able to do its job of staying in place and not letting the mcpcb rotate when you screw the bezel on.
99.9% of all customers don’t even see that screw, much less take it out.
I am speaking of a personal observation, not a consensus. Take a good look. I don’t know about you and I couldn’t care less about the 99.9% customers who don’t see the screws, much less take it out…but I don’t like my flashlight built this way and I am certainly not buying a flashlight with cheap wood screws inside. I think I am not the only one who doesn’t agree with this cheap practice.
The screws are less to hold the mcpcb in place than to keep it from rotating when tightening the bezel. Rotation would/could damage the emitter or it’s power leads. With the reflector sitting on top of those screws they cannot possibly back out, so they are indeed doing the job intended. Since you took your light apart it is no longer in warranty anyway, so I guess if it’s that bothersome you can source the proper screws and replace the factory ones while you are inside.
While this discussion is open, this IS the CONVOY C8 thread, so it might be prudent to post your concerns about Sofirn’s doing’s somewhere else.
While you’re probably correct, I don’t understand why wood screws would be used if the plate is threaded for metal screws. Aren’t the screws the same cost? Actually, I don’t understand why wood screws would be stocked in any factory that doesn’t build with wood components. ?
Maybe it makes no difference, but it seems a strange choice.
Oh well, my Convoys seem well built and do their job, so I’m not complaining. Just seems odd, that’s all.
That is a really good question, why would the assemblyline have wood screws in the first place? Perhaps they ran out of stock and had to use what could be found in order to make quota or something.
I have 4 Sofirn lights and they’ve all been exemplary. Of course, my Convoy lights have also been exceptionally well made. Truly though, I’ve been impressed with Sofirn for the level of quality I’ve been seeing, comparing favorably with Simon’s production and not left behind by any of the big names, in truth they have taken comments and criticism and come out with new upgraded product that is really nice and well thought out.
I would have been pleased to see Simon come out with a triple C8, but indeed it was Sofirn that brought it out and then made the necessary changes to make it a very nice light indeed!
I made a comment about a post made by Hunter; i.e., “I received Convoy C8 from Aliexpress store and when I disassembled it because I wanted to replace the driver with FET version I found out that they used wood screws to “secure” the led (Facepalm) I inspected holes in the flashlights head and they were threaded for metal screws as usual.”
My post was a reaction to his comment about using wood screws in his CONVOY C8. I think my post is explicit enough - that it is not only Convoy that does this in their C8 products. You can’t label my point as off topic because I was clearly reacting to a post about a CONVOY C8. I merely cited Sofirn and their very own CONVOY C8 equivalent to give some perspective. And by the way, the picture is not mine. It belongs to Barkuti in his review that I mentioned.
Lol, don’t stress out on it, I only pointed out that opening up a light voids the warranty, any light, any maker. Sofirn is using a C8 design that goes way back, does anyone know where it really started? Convoy is probably the most famous one now, and of course this IS a Convoy thread. You want to talk about Sofirn or Trustfire or Ultrafire or whatever, start a thread. This is STILL the Convoy C8 thread started by jdub who represents Convoy here.
If you’ve seen C8 clones with issues, simply state you’ve seen it before. Remember that all these lights that have crossed the line all worked right up until somebody cracked em open…. regardless, this IS a thread started to show that Convoy was listening and is making a clear anodized C8 for the masses.
Just FYI, you’re very new here and probably don’t know that BLF is the King of hijacked threads.
Amen to that
Jack, remember when they used to quote quoted quotes quoting quoted quotes? They’d run like 30 deep in a post, take up an entire page. It got a bit crazy there for a while… lol
Oh, by the way, I FEEL that guys pain every time I see him hit the floor! UGH! hahahahaha
Hope it ain’t a dumb question, but are youse sure those are wood screws and not sheet-metal screws?
Still not too swift using them instead of what the holes are properly threaded for, but maybe they were thinking, “Hey, the shelf is fairly thin aluminum… can’t find my M-whatever screws… might as well use sheet-metal screws.” or something to that effect.
Yep, that was one fun thread I accessed it on mobile only, and the white part of the page was barely a fifth of the total horizontal length of the page! Fun times.
Hardwood, meet teeth! :smiling_imp:
