He quoted $3.83/ea which is the same price he sells two of the non-coated filters for now. He says they need to be produced (manufactured) and will get back to me. Will keep you informed
Iām interested in a couple at least. I have two Nichia NVSU233A-U365 1030mW chips on the way right now. My first uv emitters so Iām trying not to get too excited.
Yes,on aliexpress there is a mix of offers with random thickness and diameter, sometimes more offers, sometimes hardly any. Usually tens of dollars for anything more than 25mm.
Pardon a dumb question. I ordered a set (2pcs) of ZWB2 filters from Simonās Convoy store in AliExpress and it just arrived a few days ago. Iām wondering when I place the ZWB2 filter inside the Convoy S2+ UV Nichia flashlight, can I place it behind the existing plain glass lens (which is what I just did ā so it has a plain glass lens in front, and the ZWB2 filter just behind it), or do I need to remove the plain glass lens altogether (ie. only the ZWB2 filter)?
When shining some other light on the ZWB2 filter, it looks like it has concentric circles/rings, though I donāt notice the concentric rings when using the Convoy UV w/ ZWB2 flashlightā¦
Yeah, when 2 pieces of glass get close enough that thereās a very small air-gap, you get funky optical properties. Some places would be in contact, some places would have a clear air-gap, others would be in that twilight zone in-between where itād essentially be a vacuum (ie, other than maybe H2, no molecules would be able to fit.
So what youāre seeing is a sort of standing-wave of the 2 distinctly different interfaces: glassāglass, glassāair, and glassāvacuum, and the different refractive funkiness of each zone.
Thatās why I donāt even like to keep the original glass when refitting with a TIR. Weird things can happen.
ā
Oh, wait a secā¦ you mean just the nekkid ZWB2 filter and no other glass on/under it? Hmm, never really noticed that. Will have to look.
^ ah, now I see what rings were meant (they are called Newton rings, an interference effect between layers close to each other, close to parallel but not exact.)
Learned something new today. Yes, Newton rings are indeed what Iām seeing.
Thus by placing 2 pieces of glass (the non-AR-coated glass lens and the ZWB2 filter) close together, there is indeed an air-gap between them that causes these Newton ringsā¦ I wonder which one is the slightly convex curved glass ā the plain glass lens or the ZWB2 filter ā more likely the ZWB2 filter?
Just reread this post - forgot to update -sorry. Upon further investigation I was told that AR coatings are not really efficient for UVA and result in a significant transmission loss, so I just dropped it (sadly donāt remember the details). Of course Iām sure there are specialty houses which can create very efficient coatings, but at a very inefficient price (I was quote a couple hundred for one piece, and a setup charge as I remember).
