Yes, a few pages ago there we discussed the matter a bit
I like almost all kwaiken knives, that böker looks very well (i would know the model). But i miss a bigger guard for safety.
I just got my Sanrenmu 9103 from Gearbest and I’m pretty disappointed. First - unlike every other Sanrenmu it came in a generic white box. Second - it’s big. I’m a bit surprised how much bigger it is compared to the 7056 or Ganzo F753M1. I know it’s not knife’s fault but it’s a bit uncomfortable.
The most important flaw is that it came scratched and maybe even used (blade look wiped):
It’s pretty difficult to open, after that ball bearing does the job. I’m actually quite afraid of closing it because right after unlocking the blade falls down on my fingers. That’s my first knife with ball bearings so I’m not used to that.
Some things:
It is Land 9103, not Sanrenmu (even making it Sanrenmu). All Land knives come in a horrible white box, again Land knives, not Sanrenmu. But Land knives are very good, it does not matter the box.
About the size, you must see the measures before buying. And again, Sanrenmu makes little knives, but that is Land, that make bigger knives than Sanrenmu.
They’re sold as Sanrenmus so I was expecting a similar packaging.
I knew it was bigger but it’s also the smallest out of those bigger ones (with ~9cm blade). My dad’s Ganzo G7142 felt slightly more compact. It’s not an issue, more like personal preference. My biggest gripe is the quality itself, all those scratch marks.
lol :nerd_face:
The scratches are from the stonewash finish and its completely normal. This knife is one of the best from china for the price. The steel is also much better than the usual chinese steels.
I’ve seen a lot of pictures (and videos) of this knife and that’s the first with such scratches.
I don’t know about it but I’ll keep my eyes open.
Mine is exactly like yours, its normal.
I wouldn’t say it’s normal, it’s a stonewash done wrong. Nothing like that is happening in more expensive knifes and being cheap is not an excuse (I also looked for high quality pics and vids of the 9103 and there were no scratches either, the finish itself also looked better).
Today i received a Ganzo firebird 7511 and it was quite of bit bigger than i thought it was going to be. Kind of a bummer.
Going to get a smaller Sanrenmu but dont know what kind yet.
Couldn’t decide between the green or black so I got both :person_facepalming:
Where did you buy it? Gearbest maybe? Send them your pics, complain, get a refund.
Or polish/etch/re-sandwash it or stop crying about extra scratches on a stonewashed surface on a $10-$16 knife which would be $40 with Real Steel brand or $60 with Böker+.
Use it for a while and you’re own scratches will hide these horrible manufacturing marks.
I was a bit surprised about the size of my 910+, too, but I got used to it and don’t want it smaller.
Even though I’d like a 710+, 7103/4, same materials, same f+f, a bit smaller.
About opening with CRK thumb lugs, don’t try to push out the blade, press the thumb studs to the front and it will fly open easily.
Yes, I found out after some experimenting that if you grip you are working against yourself, curl your fingers around the edge of the knife and push the thumb stud sideways only instead of down and sideways, and it glides open easily. Any pressure applied in a squeezing manner seems to be forcing the detent to grip harder, making it more difficult to open.
Got my Mora :+1:
https://www.amazon.com/dp/B009NZVZ3E?ref=emc_b_5_t
Very sharp out of the box, will be perfect for my camping trips!
Too bad it had couple deep scratches on the blade, one can tell it was from the factory. The scratches are deep eough for my fingernail to get “stuck” in them
i want an EDC knife, doenst need sharpening often, medium size for edc, has quick flip ( dont know what it’s called)
i am new to knife, so, can someone help me, thanks
my budget is about 50$
you want an automatic knife or just an assisted opening flipper? also check your local laws
i want an assited opening flipper( the automatic one look quite dangerous to me, i think i can accidentally put the hand in front of the knife and push the button)
the law is not a problem here as long as i dont show the knife to public
Kershaw makes some nice assisted-opening folders, look here
Check out the Sanrenmu Land 910 series.
910+ with black or green G10, 9103 and 9104 (blackwash) all steel construction.
For $10-$20 (up to seller/flash sale) you one of the best budget knives available at the moment with a steel better than on many Kershaw/CRKT/Spyderco/etc. in their budget lines till $40 - $60.
It’s not assisted but it has ball bearings and flips out just as fast as an Auto or an A/O (assisted opener) but it doesn’t have an extra spring that can break eventually.
http://steelreviews.blogspot.ch/2017/05/review-sanrenmu-land-910-9103-and-9104.html
